I peered my phone and my router at home with WireGuard.
Now my phone can access to my router successfully with address 172.16.0.1, and I can ping my phone success at router using wireguard interface.
But I can't access my computer in LAN of home such as 172.16.0.10, also my computer can't access to my phone.
Here is my config. The wireguard interface wg4 is for phone to peering, others is for site to site tunnel which is not configed yetl.
Code: Select all
# mar/04/2023 14:15:19 by RouterOS 7.5
# software id = IURD-U9F3
# model = RB750Gr3
add name=LAN_Bridge
add name=lo
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-wan
set [ find default-name=ether3 ] name=ether3-lan
set [ find default-name=ether4 ] name=ether4-lan
set [ find default-name=ether5 ] name=ether5-lan
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether2-wan name=pppoe-out4 \
user=**********
/interface vrrp
add interface=ether1-wan name=vrrp1
add interface=ether1-wan name=vrrp2 vrid=2
add interface=ether1-wan name=vrrp3 vrid=3
add disabled=no interface=vrrp1 name=pppoe-out1 user=**********
add disabled=no interface=vrrp2 name=pppoe-out2 user=**********
add disabled=no interface=vrrp3 name=pppoe-out3 user=**********
/interface wireguard
add listen-port=42232 mtu=1420 name=wg0
add listen-port=42233 mtu=1420 name=wg1
add listen-port=42234 mtu=1420 name=wg2
add listen-port=42235 mtu=1420 name=wg3
add listen-port=42236 mtu=1420 name=wg4
add listen-port=42237 mtu=1420 name=wg5
/routing table
add fib name=PCC_ROUT1
add fib name=PCC_ROUT2
add fib name=PCC_ROUT3
add disabled=no fib name=PCC_ROUT4
add disabled=no fib name=WG_ENTRY
add bridge=LAN_Bridge ingress-filtering=no interface=ether3-lan
add bridge=LAN_Bridge ingress-filtering=no interface=ether4-lan
add bridge=LAN_Bridge ingress-filtering=no interface=ether5-lan
/interface wireguard peers
add allowed-address=172.16.129.2/32 comment=Laptop interface=wg4 \
public-key="********"
add allowed-address=172.16.129.3/32 comment=Phone interface=wg4 \
add allowed-address=0.0.0.0/0 endpoint-address=******** endpoint-port=\
59980 interface=wg2 public-key=\
42333 interface=wg3 public-key=\
add allowed-address=0.0.0.0/0 endpoint-address=******** \
endpoint-port=65535 interface=wg0 public-key=\
47417 interface=wg1 public-key=\
45679 interface=wg5 public-key=\
add address=172.16.0.192/26 interface=ether1-wan network=172.16.0.192
add address=172.16.0.193/26 interface=vrrp1 network=172.16.0.192
add address=172.16.0.194/26 interface=vrrp2 network=172.16.0.192
add address=172.16.0.195/26 interface=vrrp3 network=172.16.0.192
add address=172.16.0.196/26 interface=ether2-wan network=172.16.0.192
add address=172.16.0.1/25 interface=LAN_Bridge network=172.16.0.0
add address=172.16.255.1 interface=lo network=172.16.255.0
add address=172.16.128.1/24 interface=wg0 network=172.16.128.0
add address=172.16.128.2/24 interface=wg1 network=172.16.128.0
add address=172.16.128.3/24 interface=wg2 network=172.16.128.0
add address=172.16.128.4/24 interface=wg3 network=172.16.128.0
add address=172.16.129.1/24 interface=wg4 network=172.16.129.0
add address=172.16.128.6/24 interface=wg5 network=172.16.128.0
add action=accept chain=forward in-interface=wg4
add action=accept chain=forward out-interface=wg4
add action=accept chain=input comment="allow WireGuard" dst-port=42232 \
protocol=udp
add action=accept chain=input dst-port=42233 protocol=udp
add action=accept chain=input dst-port=42234 protocol=udp
add action=accept chain=input dst-port=42235 protocol=udp
add action=accept chain=input dst-port=42236 protocol=udp
add action=accept chain=input dst-port=42237 protocol=udp
add action=accept chain=input comment="allow WireGuard traffic" in-interface=\
wg0
add action=accept chain=input in-interface=wg1
add action=accept chain=input in-interface=wg2
add action=accept chain=input in-interface=wg3
add action=accept chain=input in-interface=wg4
add action=accept chain=input in-interface=wg5
/ip firewall mangle
add action=change-mss chain=forward comment="MSS Change" new-mss=\
clamp-to-pmtu passthrough=yes protocol=tcp tcp-flags=syn
add action=change-mss chain=output new-mss=clamp-to-pmtu passthrough=yes \
add action=mark-connection chain=prerouting comment=PCC1 dst-address-type=\
!local in-interface=LAN_Bridge new-connection-mark=PCC1 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:4/0
add action=mark-routing chain=prerouting connection-mark=PCC1 in-interface=\
LAN_Bridge new-routing-mark=PCC_ROUT1 passthrough=yes
add action=mark-connection chain=prerouting comment=PCC2 dst-address-type=\
!local in-interface=LAN_Bridge new-connection-mark=PCC2 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:4/1
add action=mark-routing chain=prerouting connection-mark=PCC2 in-interface=\
LAN_Bridge new-routing-mark=PCC_ROUT2 passthrough=yes
add action=mark-connection chain=prerouting comment=PCC3 dst-address-type=\
!local in-interface=LAN_Bridge new-connection-mark=PCC3 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:4/2
add action=mark-routing chain=prerouting connection-mark=PCC3 in-interface=\
LAN_Bridge new-routing-mark=PCC_ROUT3 passthrough=yes
add action=mark-connection chain=prerouting comment=PCC4 dst-address-type=\
!local in-interface=LAN_Bridge new-connection-mark=PCC4 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:4/3
add action=mark-routing chain=prerouting connection-mark=PCC4 in-interface=\
LAN_Bridge new-routing-mark=PCC_ROUT4 passthrough=yes
add action=mark-connection chain=input comment=WG_ENTRY_IO disabled=yes \
in-interface=wg4 new-connection-mark=WG_ENTRY passthrough=yes
add action=mark-routing chain=output connection-mark=WG_ENTRY disabled=yes \
new-routing-mark=WG_ENTRY passthrough=yes
add action=mark-connection chain=input comment=PCC_IO1 in-interface=\
pppoe-out1 new-connection-mark=PCC1 passthrough=yes
add action=mark-routing chain=output connection-mark=PCC1 new-routing-mark=\
add action=mark-connection chain=input comment=PCC_IO2 in-interface=\
pppoe-out2 new-connection-mark=PCC2 passthrough=yes
add action=mark-routing chain=output connection-mark=PCC2 new-routing-mark=\
add action=mark-connection chain=input comment=PCC_IO3 in-interface=\
pppoe-out3 new-connection-mark=PCC3 passthrough=yes
add action=mark-routing chain=output connection-mark=PCC3 new-routing-mark=\
add action=mark-connection chain=input comment=PCC_IO4 in-interface=\
pppoe-out4 new-connection-mark=PCC4 passthrough=yes
add action=mark-routing chain=output connection-mark=PCC4 new-routing-mark=\
add action=masquerade chain=srcnat comment=PPPoE out-interface=pppoe-out1
add action=masquerade chain=srcnat out-interface=pppoe-out2
add action=masquerade chain=srcnat out-interface=pppoe-out3
add action=masquerade chain=srcnat out-interface=pppoe-out4
add action=masquerade chain=srcnat comment=Wireguard disabled=yes \
dst-address=172.16.129.0/24 src-address=172.16.0.0/25
add action=masquerade chain=srcnat disabled=yes dst-address=172.16.0.0/25 \
src-address=172.16.129.0/24
add disabled=no dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-table=\
PCC_ROUT1
add disabled=no dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-table=\
PCC_ROUT2
add disabled=no dst-address=0.0.0.0/0 gateway=pppoe-out3 routing-table=\
PCC_ROUT3
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out2
add disabled=no distance=3 dst-address=0.0.0.0/0 gateway=pppoe-out3
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out4 \
routing-table=PCC_ROUT4 suppress-hw-offload=no
add disabled=no distance=4 dst-address=0.0.0.0/0 gateway=pppoe-out4 \
routing-table=main suppress-hw-offload=no
