schamock
Trouble reading temperature via SNMP in RouterOS 7.8
Sat Mar 04, 2023 11:57 am
Hi everyone,
I'm trying to read out the temperature via SNMP on a CRS309-1G-8S+ and CRS326-24G-2S+ both running RouerOS 7.8.
While reading data via SNMP is no problem at all, I can't find the temperature in the whole dataset (using snmpwalk).
I tried to explicitly fetch the oid I got with
[admin@CRS326] > system/health print oid
but it seams like this oid simply doesn't exist?!
Am I doing anything wrong here?
(Just figured out: Same problem with a CSS610-8G-2S+ running SwOS Lite 2.14)
iustin
Re: Trouble reading temperature via SNMP in RouterOS 7.8
Mon Mar 06, 2023 1:28 am
This is strange. Same CRS309 with ROS 7.8, and:
[admin@sw] /system/health> print
Columns: NAME, VALUE, TYPE
#  NAME             VALUE  TYPE
0  cpu-temperature     29  C
[admin@sw] /system/health> print oid
 0 name=.1.3.6.1.4.1.14988.1.1.3.100.1.2.17 value=.1.3.6.1.4.1.14988.1.1.3.100.1.3.17
   type=.1.3.6.1.4.1.14988.1.1.3.100.1.4.17
And yes, I can read this over SNMP.
schamock
Fri Mar 17, 2023 1:40 pm
I just found out that I can read the temperature on the CRS devices when using snmpget. But snmpwalk won't output the temperature. This seams to be strange, but at least I can access the temperature now :)
On the CSS610 there seams to be no possibility. At least the same OID doesn't work.
Does anyone know if there is possibility to read the temperature from the CSS610?
Users browsing this forum: dgel27, Google [Bot], GoogleOther [Bot], sstefanov and 131 guests
