mplit
No CAPsMAN button in Winbox
Sat Mar 04, 2023 8:09 pm
I'd like to start setting up CAPsMAN on my router, but the menu button is missing (via Winbox). I'm stumped. Any insights would be appreciated.
Things I've tried:
* Reset router configuration to defaults.
* Googling (if the answer's here I missed it).
* Accessed WebFig to check if menu item was unchecked (does not exist there either).
* Downloaded ARM64 Extra packages to attempt to install the wireless-cm2 package, but it was not in zip. Does this package need to be sourced from another location? Does wifiwave2 supersede this package?
* /interface/wifiwave2/capsman set enabled=yes interfaces=bridgeWiFi (print shows it's enabled with certificates)
Board Name: hAP ax^3
/system package print
0 routeros 7.8
1 wifiwave2 7.8
SaltyCaptain
Re: No CAPsMAN button in Winbox
Wed May 03, 2023 9:38 am
Same problem here. I'm trying to follow the tutorials but there is no CAPsMAN option in the menu. There is also no wireless or other packages to install, found they were merged in the routeros package since version 7, but dont know how to activate. My router is hAp AC. I think I missed some basic config.
twiki
Wed May 10, 2023 9:17 pm
CAPsMAN: WinBox -> Wireless -> Last tap "Remote CAP" -> Button CAPsMAN -> Enabled
Regards
andyn1
Fri Aug 18, 2023 12:59 pm
Same problem. No Capsman button.
This did not resolved problem (it was first that i done before visiting forum).
routerOS 7.11
Mikrotik hAP ax (C53UiG+5HPaxD2HPaxD)
holvoetn
Fri Aug 18, 2023 10:11 pm
There is no capsman button for wifiwave2 devices.
Check under wireless.
This is clearly indicated in help page for wifiwave2. You might want to read that.
holvoetn
Fri Aug 18, 2023 10:12 pm
Load capsman package on hap ac.
It's separate.
bleier
Wed Nov 15, 2023 10:58 pm
For me it worked with /system package uninstall wifiwave2; /system reboot;
normis
Thu Nov 16, 2023 9:08 am
There is capsman button for devices with wifiwave2 package. See above pictures
Users browsing this forum: No registered users and 38 guests
