adlar
Struggling with enable device mode and pull image
Sun Mar 05, 2023 7:01 am
I met two problems.
1,I need to install CHR on vps. Some vps provider do not provide hard reset or power off functions so that I find noway to enable container device mode. Could Mikrotik remove the limit about "press of the reset button, or a cold reboot"?
2,The newest version dockers can not be pulled. The error message is 'error response getting manifests: 404'. There is no problem on older version. I doubt that there maybe some features upgraded on docker file and RouterOS doesn't support yet.
Could Mikrotik expert fix these problem? Thank you.
adlar
Re: Struggling with enable device mode and pull image
Sun Apr 02, 2023 10:42 am
Are my questions too naive to answer?
Have to hard reset to enable container device mode is rediculous on a remote vps. Does Mikrotik have any plan to remove this rule?
soonwai
Wed Apr 19, 2023 9:31 am
For #2, see this thread: viewtopic.php?t=193727
Hopefully fix will be in 7.10beta. Meanwhile, pull to PC and save as tarball for upload to RouterOS and import.
Users browsing this forum: No registered users and 4 guests
