Hi I have a problem with hAP ac². Not sure HW or SW. Basically port 2 is not syncing to 1gbit. To remove issues with Cable or Device. I have a PS4 and 1gbit switch. If I connect the ps4 to port 2 max is 100mbit. If I switch to port 2 also 100mbit, and if I switch to port 3, the port gets 1gbit. So cable or device should not be a problem. I tried to recheck config from ports 2 and 3 and they are the same.
Any ideas?
Thanks!
