akira463
Cant set ppp secret comment
Wed Mar 08, 2023 4:32 am
Hello sir, im having a trouble setting up the comment for all expired ppp users, here's my code
/ppp secret
:foreach accName in=[find where profile="EXPIRED"] do={
        :local date [/system clock get date]
        :local name [get $accName name]
        :local comm [/ppp secret get [find name=$accName] comment]
        :local prof [/ppp secret get $accName profile]
        :local accNum [:pick $comm ([:find $comm "Number: "] + 8) [:find $comm " Plan:"]]
        :local plan [:pick $comm ([:find $comm "Plan: "] + 6) [:find $comm " Monthly"]]
        :local monthlyBill [:pick $comm ([:find $comm "Bill: "] + 6) [:find $comm " Contact:"]]
        :local contact  [:pick $comm ([:find $comm "Contact: "] + 9) [:find $comm " Date"]]
        :local dateInstalled [:pick $comm ([:find $comm "Installed: "] + 11) [:find $comm " Last"]]
        :local lastPayment [:pick $comm ([:find $comm "Payment: "] + 9) [:find $comm " Expired"]]
        :local balance [:pick $comm ([:find $comm "Bal: "] + 5) ([:len $comm])]
        :local newComm "Acc Number: $accNum Plan: $plan Monthly Bill: $monthlyBill Contact: $contact Date Installed: $dateInstalled Last Payment: $lastPayment Expired Since: $date Bal: $total"
       set $name comment=$newComm
please help me, thankyou!
rextended
Re: Cant set ppp secret comment
Wed Mar 08, 2023 10:02 am
A snipplet can not suffice, for example $total is missing and miss also what happen before and later
->         :local comm [get $accName comment]
->        :local prof [get $accName profile]
->        set $accName comment=$newComm
Never use field names as variable names....
Also a nice formatted code help to understand and debug, is not only visual improvement:
fixed code
/ppp secret
# commented lines are unused
#       :local aName         [get $accName name   ]
#       :local prof          [get $accName profile]
        :local accNum        [:pick $comm ([:find $comm "Number: "   ] +  8) [:find $comm " Plan:"  ]]
        :local plan          [:pick $comm ([:find $comm "Plan: "     ] +  6) [:find $comm " Monthly"]]
        :local monthlyBill   [:pick $comm ([:find $comm "Bill: "     ] +  6) [:find $comm " Contact"]]
        :local contact       [:pick $comm ([:find $comm "Contact: "  ] +  9) [:find $comm " Date"   ]]
        :local dateInstalled [:pick $comm ([:find $comm "Installed: "] + 11) [:find $comm " Last"   ]]
        :local lastPayment   [:pick $comm ([:find $comm "Payment: "  ] +  9) [:find $comm " Expired"]]
#       :local expiredSince  [:pick $comm ([:find $comm "Since: "    ] +  7) [:find $comm " Bal"    ]]
        :local balance       [:pick $comm ([:find $comm "Bal: "      ] +  5) [:len  $comm           ]]
        :local newComm "Acc Number: $accNum \
                              Plan: $plan \
                      Monthly Bill: $monthlyBill \
                           Contact: $contact \
                    Date Installed: $dateInstalled \
                      Last Payment: $lastPayment \
                     Expired Since: $date \
                               Bal: $balance"
This code is corrected only against compiler errors, except $total that probably is defined before or is on reality $balance ???
akira463
Thu Mar 09, 2023 3:04 am
Thankyou sir rextended , so much amazing! it works, i hope you never get tired of teaching us! long live !!!!
akira463
Thu Mar 09, 2023 7:57 am
Sir rextended i change some of the code, but the problem i does not work? ive been so dumb, cant figure out what could be wrong
my goal here is when expired since = "blank" then add current date, else rewrite the date since it was expired
/ppp secret
        :local expiredSince  [:pick $comm ([:find $comm "Since: "    ] +  7) [:find $comm " Bal:"   ]]
    :if ($expiredSince = "") do={
                              Plan: $plan \
                           Contact: $contact \
                               Bal: $balance"
    } else={
                              Plan: $plan \
                           Contact: $contact \
                     Expired Since: $expiredSince \
                               Bal: $balance"
rextended
Thu Mar 09, 2023 10:24 am
Is not needed to duplicate all the string creation and
just write it one time at the end of if /else
If :pick not find any to pick, return nil, instead of one empty string,
nil can not be copared with empty string "", not work.
You add : after Bal because some field can be confused? i suppose
revised code
/ppp secret
        :if ([:typeof $expiredSince] != "str") do={
            :set expiredSince [/system clock get date]
                              Plan: $plan \
                           Contact: $contact \
                               Bal: $balance"
akira463
Thu Mar 09, 2023 5:30 pm
Thankyou again Sir! now it works !!!
Rubens0184
Wed Jun 14, 2023 3:50 pm
Hello
I need help to integrate my payment solution to mikrotic to generate automaticaly the tickets.
hunterleouser
Thu Jun 15, 2023 1:54 am
Sir rextended please help me too here is my problem
this is what will be in the scheduler On event
:local secretName "15_36_0";
:local expirationDateTime [/system scheduler get [find name=my_house] comment];
:if ([:len $expirationDateTime] > 0) do={
  :local expirationDate [:pick $expirationDateTime 0 10];
  :local expirationTime [:pick $expirationDateTime 11 19];
  :local currentTime [/system clock get date];
  :if ($expirationDate <= $currentTime) do={
    /ppp secret set [find name=$secretName] profile=lablab;
    /ppp active remove [find name=$secretName];
    /system scheduler disable [find name=my_house];
    :log info ("Scheduler [my_house] has expired. Profile changed to [lablab] and PPP connection removed.");
This is what is in the comment
06/14/2023 05:01:00
what this should do. is it will run every 5 minutes. extract comment date info in the scheduler comment section, and compare it to current date&time. if the comment is lesser it will disable remove and change profile of the said PPP and disable the current schedule. but its not working please help
rextended
Thu Jun 15, 2023 6:35 am
Ask ChatGPT for help, since you like it so much.
I don't even consider that shit.
viewtopic.php?p=1007642#p1007642
viewtopic.php?p=1007818#p1007818
And I don't even reply to those who spam the forum.
hunterleouser
Thu Jun 15, 2023 6:44 pm
Thank you rextended. and its not wrong to ask chatgpt for help.. cause i dont know anything about mikrotik, but im trying.
I apologize for the spam post guys. had been little desperate to have an answer. tried to delete some for it not to spam but it doesn't allow me
Users browsing this forum: No registered users and 30 guests
