Tommmyz
NTP client not syncing
Wed Mar 08, 2023 1:20 pm
MikroTik NTP Client won't sync.
Message from log (ntp debug on):
Mar/08/2023 03:18:46 ntp,debug Checking peer (a.b.c.d). Peer is: NOT FIT, because rootDist(7.941359) > 1.000960
What is the problem and how to solve it ?
(Windows clients syncs correctly also SNTP Client from RoS v6 has no problem with it.)
RoS:
model: CRS326-24G-2S+
revision: r2
firmware-type: dx3230L
upgrade-firmware: 7.6
krzysztofciupala
Re: NTP client not syncing
Mon Aug 21, 2023 9:29 am
Here you have the solution viewtopic.php?p=1019852#p1019852
Tommmyz
Thu Aug 24, 2023 11:06 am
This solution works when you implement it on the NTP server side. In the above solution, the w32time service in MS Windows is configured accordingly. Unfortunately, the problem I described concerns another NTP server to which configuration I don't have access. Ideally, you could configure the limit value of the rootDist parameter (> 1.000960) in the MikroTik NTP client so that it would accept time frames from such a server.
krzysztofciupala
Thu Aug 24, 2023 1:48 pm
Tommmyz, you're right. In your case, either the administrator of the server you are using will change this parameter, or maybe (someday...) Mikrotik will add an option in the NTP client that allows you to change the unfortunate "rootDist (> 1.000960)" parameter to a higher one, e.g. 15 seconds ...
Regards.
Users browsing this forum: BenceLK, Bing [Bot], ejaka2s, Kevdevon, Majestic-12 [Bot], Qanj72, smirgo and 182 guests
