Luposky
Netwatch icmp incoherent status
Wed Mar 08, 2023 7:10 pm
I have enabled Netwatch icmp using this command on routerOS 7.8:
/tool netwatch add disabled=no host=10.100.24.24 interval=2h10m10s type=icmp
the ip 10.100.24.24 is online, I can ping it with success:
[admin@ServerMK-03] /tool> ping 10.100.24.24
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 10.100.24.24                               56  64 72ms305us
    1 10.100.24.24                               56  64 72ms550us
    2 10.100.24.24                               56  64 72ms739us
    3 10.100.24.24                               56  64 72ms717us
    4 10.100.24.24                               56  64 72ms490us
    sent=5 received=5 packet-loss=0% min-rtt=72ms305us avg-rtt=72ms560us max-rtt=72ms739us
but sometimes I got the netwatch status 'down' and the strange (for my understanding) situation in image1 (with response count = 10, but status = down)
I'm missing something obvious?
LP
eworm
Re: Netwatch icmp incoherent status
Thu Mar 09, 2023 5:20 pm
Perhaps because the last check is too long ago? Why is your check interval more than two hours?
Amm0
Re: Netwatch icmp incoherent status  [SOLVED]
Thu Mar 09, 2023 6:04 pm
Or the default values for the ICMP check are getting applied. And one of the RTT check is exceeding a "hidden" default. Didn't test but one idea.
e.g.
ICMP probe options
packet-interval (Default: 50ms) The time between ICMP-request packet send
packet-count (Default: 10) Total count of ICMP packets to send out within a single test
packet-size (Default: 54 (IPv4) or 54 (IPv6)) The total size of the IP ICMP packet
thr-rtt-max (Default: 1s) Fail threshold for rtt-max (a value above thr-max is a probe fail)
thr-rtt-avg (Default: 100ms) Fail threshold for rtt-avg
thr-rtt-stdev (Default: 250ms) Fail threshold for rtt-stdev
thr-rtt-jitter (Default: 1s) Fail threshold for rtt-jitter
thr-loss-percent (Default: 85.0%) Fail threshold for loss-percent
thr-loss-count (Default: 4294967295(max)) Fail threshold for loss-count
AND, at 154ms for rtt-avg ... that bigger than the 100ms default. So it should fail – although initially confusing. You can use simple ping check if you don't care ;)
Users browsing this forum: Bing [Bot], Google [Bot], mkx, Sddaw and 192 guests
