samdoru
LoRa messages to MQTT server
Wed Mar 08, 2023 10:30 pm
Hello everyone,
I'm pretty new to LoRa and MQTT. I hope I have open the topic in the right section.
I have a Mikrotik Knot LR8 Gateway and 10 lora sensors connected to it. I can see the sensor data on Gateway and TTN without any problem.
What I want to do is to forward LoRa sensors payloads from Gateway to a MQTT server.
Some examples which sensor data is sending to a MQTT server can be found in Mikrotik documentation and on the internet, but they are using Bluetooth sensors.
For this, you need to write a script.
for example:
https://youtu.be/XKbfg-yTt2I
https://help.mikrotik.com/docs/pages/vi ... d=63045633
I know I cannot use the same example for my LoRa sensors. Anyone have any ideas how can i do this?
Thanks..
denissMT
Re: LoRa messages to MQTT server
Tue Mar 21, 2023 9:42 am
Unfortunately, it is not possible to push LoRa payloads via MQTT.
LoRa payloads can only be sent to LoRa servers.
Users browsing this forum: adimihaix and 26 guests
