andres0528
Wireless Router for Hotspot?
Wed Mar 08, 2023 10:56 pm
Hey, im setting up a hotspot for some ethernet and wifi connections. Ethernet connections are working as expected. Im having problems with the wireless conections. Im using an Asus Router to provide Wifi. When I connect any device to this Wifi, the hotspot authentication works well, but when another device connects to the wifi, it doesn't ask for authentication. Even when I disconnect the first device, any other device can connect to the Wifi without authentication...
What I guess is going on is that, when the first device authenticates, the Router is now "Unlocked" and any device can connect without authentication, as if the router was making the authentication instead of the device connecting to it. I don't know how to fix this, wether its something I have to change on the HS configuration or on the Router itself. I need help as soon as possible since is the last thing I have to figure out to finally put it all to work. Thanks
Users browsing this forum: Bing [Bot], darthgizm0, stebrony and 25 guests
