mevara
Wireguard: how to configure this network?
Thu Mar 09, 2023 9:54 am
Hello! I started with Mikrotik not so long ago and still have a poor understanding of routes and other things. Please help me create a network configuration like this:
There are 3 networks and a server with Wireguard installed. I need:
  • Users from the network 172.20.21.0/24 have access to the server and network 172.20.20.0/24
  • Users from the network 172.20.20.0/24 have access to the server and network 172.20.21.0/24
  • Users from the 172.20.22.0/24 network can access servers and networks on both 172.20.20.0/24 and 172.20.21.0/24
Additional Internet access (by routing marks):
  • Users from network 172.20.20.0/24 via VPS
  • Users from network 172.20.21.0/24 via VPS
  • Users from network 172.20.22.0/24 via router 0 (priority 1) and via VPS (priority 2)
VPS Wireguard config like this:
[Interface]
Address = 10.66.66.1/24,fd42:42:42::1/64
ListenPort = 12345
PrivateKey = xxxxx
PostUp = iptables -I FORWARD -i eth0 -o wg0 -j ACCEPT
PostUp = iptables -I FORWARD -i wg0 -j ACCEPT
PostUp = iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
PostDown = iptables -D FORWARD -i eth0 -o wg0 -j ACCEPT
PostDown = iptables -D FORWARD -i wg0 -j ACCEPT
PostDown = iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
[Peer]
PublicKey = xxxxx
PresharedKey = xxxxx
AllowedIPs = 10.66.66.2/32,fd42:42:42::2/128
[Peer]
PublicKey = xxxxx
AllowedIPs = 10.66.66.3/32,fd42:42:42::3/128
[Peer]
PublicKey = xxxxx
AllowedIPs = 10.66.66.4/32,fd42:42:42::4/128
anav
Re: Wireguard: how to configure this network?
Thu Mar 09, 2023 6:10 pm
Since I dont know what VPS is the diagram makes no sense to me.
Why do all routers have a hard connection to this magical VPS
What is a square box not named a router.
It appears you have two different devices wired together with connections to the internet.
Nothing makes sense to me.;
mevara
Sun Mar 12, 2023 7:49 pm
Sorry, I fixed: square box is Router #1
VPS: Virtual Private Server, external web-server with white IP address, where I run WG and my branches (2/3 with grey IPs) connected to. And it is not a hard connections, it thorugh the internet, sorry for my diagram
anav
Sun Mar 12, 2023 9:21 pm
I still dont see which routers have internet access directly it appears at the moment only Router 0 ???
anav
Sun Mar 12, 2023 9:22 pm
Is VPS the only wireguard device? If not would need config of all MT devices (full)
anav
Mon Mar 13, 2023 1:24 am
VPS Discussion
(1) Looking at the VPS it is seemingly configured properly as a WG Server for the initial handshake. The only comment I would make is ensure the single peer on the local Routers, to the VPS uses the nomenclature for wireguard as follows: 10.66.66.0/24.
(2) I dont see any allowance for any of the routers using WG to reach subnets on other routers other than via wireguard IP.
Not sure how iptable handles the wireguard to wireguard traffic but this single rule covers ALL what I would call RELAY traffic through the VPS, both wireguard and subnet!! If you do end up using other subnets across routers, then the below rule also covers that.
add action=accept chain=forward in-interface=WG-interface out-interface=WG-interface
(3) If using wg to reach subnets on other routers, then you need more work on VPS but not for firewall routes but for routes.
Every subnet that is remote to the VPS coming over wireguard needs a route into the tunnel this covers both destination traffic and return traffic.
add dst-address=172.168.20.0/24 gwy=wireguard-interface table=main
add dst-address=172.168.21.0/24 gwy=wireguard-interface table=main
add dst-address=172.168.22.0/24 gwy=wireguard-interface table=main
(4) If you want to be able to configure the VPS from any router or even a REMOTE wireguard user ( aka admin from laptop at hotel etc.)
On VPS
add chain=input action=accept in-interface=wireguard-interface src-address-list=Authorized
/ip firewall address
add address=10.66.66.5 list=Authorized comment="remote RW connection laptop"
add address=10.66.66.6 list=Authorized comment="remote RW connection ipad/iphone"
add address=172.16.20.X list=Authorized comment="router0 admin Desktop IP"
add address=172.16.21.Y list=Authorized comment="router1 admin Desktop IP"
add address=172.16.22.Z list=Authorized comment="router2 admin Desktop IP"
Note for each PEER on VPS then logically you would add the IP allowed address.......
[Peer - RO]
AllowedIPs = 10.66.66.2/32,172.16.20.X, fd42:42:42::2/128
[Peer-R1]
AllowedIPs = 10.66.66.3/32,172.16.21.Y,fd42:42:42::3/128
[Peer-R2]
AllowedIPs = 10.66.66.4/32,172.16.22.Z,fd42:42:42::4/128
[Peer-RW1]
AllowedIPs = 10.66.66.5/32
[Peer-RW2]
AllowedIPs = 10.66.66.6/32
Other Routers - simply ensure that the adminIP or the subnet the admin is on, can access the local wireguard interface via a forward chain rule.
If traversing VPS towards other remote subnets, or remote subnets are coming to your local router, then you will need similar routes as VPS ones, but on the local router.
(5) If you want to be able to configure Other Routers (assuming all MT) via WG then nothing else is required on VPS.
On each router you would need to add the two other subnets as allowed IPs on the single local PEER to the VPS. This would permit traffic both ways as well.
On each router you would need probably the same firewall list=Authorized for a local input chain rule with in-interface=wireguard-interface
As you can see its a matter of ensuring............. forward chain rules allow traffic, ip routes direct traffic, wg rules allow matching to a peer outbound(enter tunnel) and filtering a peer inbound (exit tunnel)
Last is the internet access needs. Need more clarity on the requirements to complete.........
Almost there but there are potential complications.
Q1 - some users from R0 need internet via VPS or entire subnet? if some, how many?
Q2 - some users from R1 need internet via VPS or entire subnet? if some, how many?
Q3. For R2 router, is there only one group of users needing special routing or two?
Q4. If it is only one group is it some users or the entire subnet?
Q5. If one, what do you mean priority 0 to R0 and priority 1 to VPS, ie, primary and secondary in case R0 is not linked to VPS for some reason and not reachable???
Q6. if two, which users are going to R0 and which are going to VPS?
mevara
Mon Mar 13, 2023 8:03 pm
I made a simpler diagram. All routers are connected to the internet. All routers are connected to the VPS using WireGuard over the internet.
The VPS is a Debian based server with Wireguard software (not a ROS based device). I pointed the circle as the gate that should provide Internet access (in green or purple direction)
All routers now configured as:
add address=10.66.66.x/24 interface=wireguard1 network=10.66.66.0
/interface wireguard
add listen-port=12345 mtu=1420 name=wireguard1
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=VPS_IP endpoint-port=12345 interface=wireguard1 public-key=xxxxxx
Also I added each subnet to the [PEER] section on the VPS config almost as you wrote (I used full subnet /24 here):
[Peer - RO]
AllowedIPs = 10.66.66.2/32,172.16.20.0/24, fd42:42:42::2/128
[Peer-R1]
AllowedIPs = 10.66.66.3/32,172.16.21.0/24,fd42:42:42::3/128
[Peer-R2]
AllowedIPs = 10.66.66.4/32,172.16.22.0/24,fd42:42:42::4/128
Now I can ping, for example server 172.20.20.8 from VPS 10.66.66.1. But can not reach it from the 172.20.22.0/24 subnet.
Entire subnet 172.20.2x.0/24 need internet via VPS (with address-lists and routing marks)
Also the entire subnet, but priority is to have access through P0, and in second place through the VPS (just distance=1 and distance=2: VPS as backup route)
Entire subnet as above
Yes, if R0 not connected to the internet, R2 users will user VPS-route.
anav
Mon Mar 13, 2023 10:20 pm
Good to know, we can probably dispense with any mangling!!
Any issues with pinging is at your VPS see below!
(1) As indicated you need to ensure you have an equivalent rule on VPS
add action=accept chain=forward in-interface=wireguard-interface out-interface=wireguard-interface
(2) Route to all subnets on VPS
(3) Route for wireguard IPs if the VPS does provide automagic routes like MT.
MT--> <dac> dst-address=10.66.66.0/24 gateway=wireguard-interface table=main
anav
Mon Mar 13, 2023 10:36 pm
R0 - Three items ( table, route, routing rule)
/routing table add fib name=useVPS
add dst--address=0.0.0.0./0 gateway=RO-WAN table=main
add dst-address=0.0.0.0/0 gateway=wireguard-interface table=useVPS
/routing rule add action=lookup src-address=172.16.20.0/24 table=useVPS
Note1: If you didnt want the subnet to fall back to main table and find RO WAN, change action to action=lookup-only-in-table
Note2: If there are other subnets on R0 that the current subnet needs access to prior to being forced out WG for internet, then you need
to add another routing rule prior to the WG one, that is very similar except it states dst-address=othersubnet table=main
SAME ON R1
add dst--address=0.0.0.0./0 gateway=R1-WAN table=main
/routing rule add action=lookup src-address=172.16.21.0/24 table=useVPS
Notes1&2 also apply.
R2 - A different Beast
In this case you want all users to use R2 WAN as per normal.
You dont want to force users to use VPS for WAN, so its more of acting as a secondary WAN.
Hence, I believe this should do it.
add distance=5 dst-address=0.0.0.0/0 gateway=R2 WAN table=main check-gateway=ping.
add distance=10 dst-address=0.0.0.0/0 gateway=wireguard interface table=main
No mangling, marking required on MT routers.
mevara
Mon Mar 20, 2023 10:37 am
Excuse me, I think you misunderstood me. All routers access the Internet through their regular WAN. But: everyone has an ADDITIONAL way to get Internet through the VPS. So it seems to me that this rule is not quite suitable for me, if I understand ROS correctly.
About the mangles, I meant this option:
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=to-useVPS-list in-interface=bridge-local new-routing-mark=useVPS passthrough=yes
anav
Mon Mar 20, 2023 12:38 pm
Can you clarify Router2. It seems you want it to be able to go out internet via 3 locations, local, vps and Router 0.
Do you mean different subnets on Router2 or the same single subnet?
If the latter this will not be possible I dont think.
If router2 requests internet, its first peer to peer link will be to VPS.
VPS has no way to distinguish an incoming internet request ( should it go out VPS or router 0 )
You would need a separate WG interface on VPS to handle that requirement to avoid overlap issues.
mevara
Wed Mar 22, 2023 11:21 am
Router 2 should have three routes (main and two "marked"):
1. Main WAN 0.0.0.0/0
2. Through VPS, with "vpn-mark" routing mark and distance 2
3. Through router 0 with "vpn-mark" routing mark and distance 1
It is enough that I can manually select which of the "marked" routes the "marked" traffic will go through.
Is it possible to use one WG interface in such a configuration, or is it better to make 2 WG interfaces: for connecting to the VPS and for connecting to router 0?
anav
Wed Mar 22, 2023 1:19 pm
separate wg interface.
Users browsing this forum: AndHe, Boulder08, Google [Bot], jaclaz and 25 guests
