adrianb
Routing to another VLAN through VPN
Thu Mar 09, 2023 4:24 pm
I have an IPSec VPN connecting mikrotik (10.7.7.0) and other router (192.168.42.0).
The VPN itself working flawlessly, but the other router has two (untagged, port based) VLAN's:
- VLAN1 (192.168.42.0)
- VLAN2 (10.1.1.0)
... and there is configured a (working) static route on that remote router as follows:
- 10.1.1.0/24 => 10.1.17.0/24 through 10.1.1.2 (another remote side's "local" router, with its own VLANs presumably)
Is there any possibility of connecting from 10.7.7.10 to 10.1.17.122?
Thanks in advance!
adrianb
Re: Routing to another VLAN through VPN
Mon Mar 27, 2023 2:41 pm
So, I understand that it is not possible?
erlinden
Mon Mar 27, 2023 2:49 pm
I would expect a route Dst. Address [10.1.17.0/24] with Gateway [Wireguard interface].
If the above isn't working...please add a diagram of all involved IP addresses.
anav
Mon Mar 27, 2023 5:38 pm
As stated, a diagram well labelled for context and full config to marry up words and pictures with actual evidence.
/export file=anynameyouwish ( minus router serial number and any public WANIP information )
adrianb
Re: Routing to another VLAN through VPN  [SOLVED]
Sat May 27, 2023 8:51 am
I've totally forgot this post, as the wireguard is not an option here, and I have to look for another solution (and solved it by myself).
For anyone who might need details, I have to made two IPSec tunnels:
- the main (10.7.7.0/24->192.168.42.0/24) left intact, save for 'level' change from 'require' to 'unique', for better handling of SA's
- second IPSec tunnel with dst-address 10.1.17.0/24 (as above, level: unique)
- proposals, peers, identities, profiles remains unchanged
- no other changes (firewall, etc) required
Users browsing this forum: Amazon [Bot], consoletotherescue, yourproblem and 56 guests
