IbanezSandy
Upgraded to 7.8 now cannot get into Webfig! Says loading
Thu Mar 09, 2023 6:40 pm
Recently attended a webinar with an ISP who ran through some upgrading methods. Our microtiks were on 6.4.7 Stable . Instructed to upgrade to 7.8 as they were fairly outdated from being shipped but sadly cannot get past loading screen when entering 192.168.88.1
Any help please?
Thanks! :)
Znevna
Re: Upgraded to 7.8 now cannot get into Webfig! Says loading
Sun Mar 12, 2023 1:08 pm
Yeah, get your money back.
Nobody should recommend upgrades from ancient v6 versions to bleeding edge v7 versions.
Netinstall.
aoakeley
Wed Mar 15, 2023 11:45 pm
Any help please?
Thanks! :)
Does Winbox work?
Did you upgrade to latest v6 OS and Firmware before upgrading to v7?
Netinstall is probably your way out of this.
Amm0
Thu Mar 16, 2023 12:00 am
winbox supports layer2, so you can always try the MAC address of the unit.
If you plug your laptop directly into a LAN ports (e.g. typically NOT ether1), wait 10 seconds, it might show up in winbox's discovery window & from there you can double-click the MAC address (if it shows up) to connect. May save the trouble of netinstall if that works.
Once in you can then do a /system/reset-configuration save-users=yes to get the 7.8 defaults if needed. Or see what's wrong in the config it got and/or error messages in logs.
Users browsing this forum: No registered users and 20 guests
