hirosandwich
CRS309 stuck in "default" after every reboot
Fri Mar 10, 2023 3:53 am
Every reboot falls back to:
RouterOs: 7.7
router identity: MikroTik
router mode
static: 0.0.0.0
netmask 255.0.0.0/8
uname: admin
psswd: <no psswd>
Currently at RoS 7.7 recently upgraded from 6.48.6. Unit purchased new two weeks ago.
Failures:
"damaged user-manager package: bad image" (v7.7)
Downgrade
uninstall packages
disable packages
Hard reset
Soft reset
default configuration
Netinstall (invalid IP 0.0.0.0)
IDK, seems like the current defaults are etched in non-volatile memory and config writes only to volatile memory? If anyone has any ideas, I'd appreciate a lead.
FWIW, I already own two CRS305s and have had no issues.
I also have supout.rif if it helps
thanks
Users browsing this forum: Amazon [Bot], Google [Bot], RBrogen and 131 guests
