jimlill
Port Forwarding seemed simple, but...
Fri Mar 10, 2023 1:40 pm
I want to forward inbound connections from the public WAN on a specific port to the same port on a specfic machine on my LAN. I have found/used several rules to do this but they must be incorrect as they affect outbound stuff too.
Assuming my public IP is 64.232.1.29
Port to forward is 8073
IP and Port on LAN machine is 192.168.1.73 8073
what is the correct /ip firewall nat command I should use?
Sorry if this seems simple and a redundant question but none of the examples or guidance I found so far work
Jim
anav
Re: Port Forwarding seemed simple, but...
Fri Mar 10, 2023 1:50 pm
check out Para E - viewtopic.php?t=182373
jimlill
Fri Mar 10, 2023 1:56 pm
Thank You!....
jimlill
Fri Mar 10, 2023 4:40 pm
that guidance lead me to try
/ip firewall nat add chain=dstnat dst-port=8073 action=dst-nat protocol=tcp to-address=192.168.1.73 to-port=8073
but that is what I already had that doesn't work as I need
That interferes with outbound traffic, whereas I only want to forward inbound.
anav
Fri Mar 10, 2023 5:47 pm
No the guidance certainly did not!!
Where is the dst-address=WANIP of the router for fixed//static WANIP OR
where is the out-interface-list=WAN for dynamic wanip or any variation needed for hairpin NAT.
jimlill
Fri Mar 10, 2023 6:09 pm
Thanks again.... let me re-read that again.....
anav
Fri Mar 10, 2023 6:17 pm
Thanks again.... let me actually read the reference.....
Fixed it for ya
(another clue that you didnt is the fact that you still have both dst-port and to-port LOL )
jimlill
Fri Mar 10, 2023 6:26 pm
fixed....
Users browsing this forum: forthal, grayfoxbsd, Irish9 and 85 guests
