spyghost
Hex GR3 POE standards
Fri Mar 10, 2023 2:52 pm
I've read somewhere (can't remember where) that Mikrotik does POE differently? Reason why I'm asking is that I wanted to power 2 devices via POE as it will give me a better route for decluttering my cables. See attached image. My plan is to use the RGBPOE between my ISP provided modem and Mikrotik Hex gr3 ether1. The Hex in turn will be used to power the TPlink OC200 via ether5. The stock power adapter that came with the hex will be used for the RGBPOE. The rest of the hex ports will be used for my Proxmox lab (ether3) server and AP (ether4).
With that setup in mind, any risks of toasting something or something not powering up?
Znevna
Re: Hex GR3 POE standards
Fri Mar 10, 2023 3:59 pm
Why don't you read the documentation and device specifications for each device mentioned by you above?
Instead of relying on "something" that you've read "somewhere".
https://mikrotik.com/product/RB750Gr3#f ... ifications
https://www.tp-link.com/en/business-net ... ifications
spyghost
Sat Mar 11, 2023 4:38 am
I think I may have made a mistake... hex gr3 doesn't have POE out... should have been hex poe (not lite).
carl0s
Sat Mar 11, 2023 7:00 pm
Also, the PoE 'out' is never 802.3af/at, so that would not work anyway. The PoE out is always 'passive poe', which is sometimes all that they support on PoE-in as well (some devices support 'real' PoE on input though).
AidanAus
Mon Apr 03, 2023 10:12 am
incorrect there are af/at compliant devices, example: https://mikrotik.com/product/rb5009upr_s_in
Hex S supports passive up to 57v most of the PoE in af/at devices will support passive in as long as the correct voltage is applied, ie hex S at 24 volts wont work but a hex S at 48v will
Users browsing this forum: No registered users and 58 guests
