I have configured IKEv2 VPN to a VPN provider following the steps provided on their site. The VPN is reconecting every few seconds, the max uptime I have seen was 15 seconds. Seems that the PH2 is established but it drops and reconnects.
I have the same issue on Chateau LTE12 and on Hyper V (unlicenced for testing purpose), are running version 7.8.
The drop and reconnection logs are the below.
The full logs are below.12:26:27 ipsec payload seen: ID_R (33 bytes)
12:26:27 ipsec payload seen: CERT (1116 bytes)
12:26:27 ipsec payload seen: CERT (1465 bytes)
12:26:27 ipsec payload seen: AUTH (264 bytes)
12:26:27 ipsec payload seen: EAP (9 bytes)
12:26:27 ipsec processing payloads: NOTIFY (none found)
12:26:27 ipsec ike auth: initiator finish
12:26:27 ipsec processing payload: ID_R
12:26:27 ipsec ID_R (FQDN): uk-lon.prod.surfshark.com
12:26:27 ipsec processing payload: AUTH
12:26:27 ipsec processing payloads: CERT
12:26:27 ipsec got CERT: CN=uk-lon.prod.surfshark.com
I have followed the configuratons from the provider's site# mar/10/2023 12:26:37 by RouterOS 7.8
# software id =
12:26:27 ipsec,debug => SK_ei (size 0x10)
12:26:27 ipsec,debug fcf13ab6 ce1d6416 3137d57b 674fbca7
12:26:27 ipsec,debug => SK_er (size 0x10)
12:26:27 ipsec,debug a4d5af84 cd810298 6ab27b76 fbae4614
12:26:27 ipsec,debug => SK_pi (size 0x14)
12:26:27 ipsec,debug 473cd74b d47b3979 957d9c60 7ef83107 cf119078
12:26:27 ipsec,debug => SK_pr (size 0x14)
12:26:27 ipsec,debug 56720ae1 02c1f888 95681ac7 ed3928ef 80217ef7
12:26:27 ipsec,info new ike2 SA (I): FRBD 192.168.50.154[4500]-138.199.29.195[4500] spi:cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec notify: NAT_DETECTION_SOURCE_IP
12:26:27 ipsec notify: NAT_DETECTION_DESTINATION_IP
12:26:27 ipsec notify: IKEV2_FRAGMENTATION_SUPPORTED
12:26:27 ipsec notify: MULTIPLE_AUTH_SUPPORTED
12:26:27 ipsec (NAT-T) LOCAL
12:26:27 ipsec KA list add: 192.168.50.154[4500]->138.199.29.195[4500]
12:26:27 ipsec fragmentation negotiated
12:26:27 ipsec init child continue
12:26:27 ipsec offering proto: 3
12:26:27 ipsec proposal #1
12:26:27 ipsec enc: aes256-cbc
12:26:27 ipsec enc: aes192-cbc
12:26:27 ipsec enc: aes128-cbc
12:26:27 ipsec auth: sha1
12:26:27 ipsec ID_I (DER DN): C=VG, O=Surfshark, CN=Surfshark Root CA
12:26:27 ipsec adding payload: ID_I
12:26:27 ipsec,debug => (size 0x47)
12:26:27 ipsec,debug 00000047 09000000 303d310b 30090603 55040613 02564731 12301006 0355040a
12:26:27 ipsec,debug 0c095375 72667368 61726b31 1a301806 03550403 0c115375 72667368 61726b20
12:26:27 ipsec,debug 526f6f74 204341
12:26:27 ipsec cert: C=VG, O=Surfshark, CN=Surfshark Root CA
12:26:27 ipsec adding payload: CERT
12:26:27 ipsec,debug => (first 0x100 of 0x556)
12:26:27 ipsec,debug 00000556 04308205 4d308203 35a00302 01020209 00cb3d4b 77eac2ff a6300d06
12:26:27 ipsec,debug 092a8648 86f70d01 010b0500 303d310b 30090603 55040613 02564731 12301006
12:26:27 ipsec,debug 0355040a 0c095375 72667368 61726b31 1a301806 03550403 0c115375 72667368
12:26:27 ipsec,debug 61726b20 526f6f74 20434130 1e170d31 38303331 34303835 3932335a 170d3238
12:26:27 ipsec,debug 30333131 30383539 32335a30 3d310b30 09060355 04061302 56473112 30100603
12:26:27 ipsec,debug 55040a0c 09537572 66736861 726b311a 30180603 5504030c 11537572 66736861
12:26:27 ipsec,debug 726b2052 6f6f7420 43413082 0222300d 06092a86 4886f70d 01010105 00038202
12:26:27 ipsec,debug 0f003082 020a0282 020100c4 18c363d1 a8ac33ad e84a4995 27264f69 85fb68fb
12:26:27 ipsec adding notify: INITIAL_CONTACT
12:26:27 ipsec,debug => (size 0x8)
12:26:27 ipsec,debug 00000008 00004000
12:26:27 ipsec adding payload: SA
12:26:27 ipsec,debug => (size 0x44)
12:26:27 ipsec,debug 00000044 00000040 01030405 03da150c 0300000c 0100000c 800e0100 0300000c
12:26:27 ipsec,debug 0100000c 800e00c0 0300000c 0100000c 800e0080 03000008 03000002 00000008
12:26:27 ipsec,debug 05000000
12:26:27 ipsec initiator selector: 0.0.0.0/0
12:26:27 ipsec adding payload: TS_I
12:26:27 ipsec,debug => (size 0x18)
12:26:27 ipsec,debug 00000018 01000000 07000010 0000ffff 00000000 ffffffff
12:26:27 ipsec responder selector: 0.0.0.0/0
12:26:27 ipsec adding payload: TS_R
12:26:27 ipsec preparing internal IPv4 address
12:26:27 ipsec preparing internal IPv4 netmask
12:26:27 ipsec preparing internal IPv6 subnet
12:26:27 ipsec preparing internal IPv4 DNS
12:26:27 ipsec preparing internal DNS domain
12:26:27 ipsec adding payload: CONFIG
12:26:27 ipsec,debug => (size 0x30)
12:26:27 ipsec,debug 00000030 01000000 00010004 00000000 00020004 00000000 000d0008 00000000
12:26:27 ipsec,debug 00000000 00030004 00000000 00190000
12:26:27 ipsec <- ike2 request, exchange: AUTH:1 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec,debug,packet => outgoing plain packet (size 0x665)
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 23202308 00000001 00000665 25000047
12:26:27 ipsec,debug,packet 09000000 303d310b 30090603 55040613 02564731 12301006 0355040a 0c095375
12:26:27 ipsec,debug,packet 72667368 61726b31 1a301806 03550403 0c115375 72667368 61726b20 526f6f74
12:26:27 ipsec,debug,packet 20434129 00055604 3082054d 30820335 a0030201 02020900 cb3d4b77 eac2ffa6
12:26:27 ipsec,debug,packet 300d0609 2a864886 f70d0101 0b050030 3d310b30 09060355 04061302 56473112
12:26:27 ipsec,debug,packet 30100603 55040a0c 09537572 66736861 726b311a 30180603 5504030c 11537572
12:26:27 ipsec,debug,packet 66736861 726b2052 6f6f7420 4341301e 170d3138 30333134 30383539 32335a17
12:26:27 ipsec,debug,packet 0d323830 33313130 38353932 335a303d 310b3009 06035504 06130256 47311230
12:26:27 ipsec,debug,packet 10060355 040a0c09 53757266 73686172 6b311a30 18060355 04030c11 53757266
12:26:27 ipsec,debug,packet 73686172 6b20526f 6f742043 41308202 22300d06 092a8648 86f70d01 01010500
12:26:27 ipsec,debug,packet 0382020f 00308202 0a028202 0100c418 c363d1a8 ac33ade8 4a499527 264f6985
12:26:27 ipsec,debug,packet fb68fb19 b73b31a3 a9baa795 ad6b7306 012a2bc9 1b01b916 87e9555a d1fc1b23
12:26:27 ipsec,debug,packet 59f0e6e6 f2c64b9a 35ae2fdf 31d5c2e4 aae85d69 f12f35d7 ed583f56 affa3a83
12:26:27 ipsec,debug,packet 70cca88c 7d2e8d94 8721c6ff 8b92ed68 7357050d ea378f02 73bb2a06 74c8205a
12:26:27 ipsec,debug,packet 666f91ed 850ff8a5 6f9af366 f582e339 7591ec87 babe2ca4 032069af b4cb4ed7
12:26:27 ipsec,debug,packet e3449e68 fcd41029 15aca268 3d6082fc 03238c7b a3f63792 c7d64821 e7a971b2
12:26:27 ipsec,debug,packet ab34852e 1f10b90a d3996526 f3860718 5c68235f fc00a748 c95a01e8 18dc68c2
12:26:27 ipsec,debug,packet ad2acfe9 6dcb64ea f9339987 f45e61a8 bc328f40 5e8cc147 a47212e3 07981204
12:26:27 ipsec,debug,packet d9e9b524 3d90d827 4cbaa2d0 ea52c08e a2c57e76 2acbdae9 433c3f4d 59221599
12:26:27 ipsec,debug,packet eae6bf4f fb40ae03 83cb9259 316fa943 503a2f46 fb7a021e 821a702a 73d11bee
12:26:27 ipsec,debug,packet 42ce03b4 279504ea 0bf4d349 aa6e60b7 09b892f3 18b6c6e3 60aee032 6368543a
12:26:27 ipsec,debug,packet 857dfc1b 817aff2d b44e590a c247dd89 46e8db5b 67d84f73 ad468814 b1f0d267
12:26:27 ipsec,debug,packet 5f9407c8 29df89cf d7f3b792 4ff6a666 c64200e2 79bf810f 49a2ab22 db7e1eb1
12:26:27 ipsec,debug,packet 05599408 ab87c998 724d35b6 2f5b3084 d3c00bfb 9ffa67e9 716ff066 ddd6a9c7
12:26:27 ipsec,debug,packet 6cdd8add f1d9efa6 8861de92 e884f254 160f4ad7 0f8f93fa 70d18b75 fe932b7c
12:26:27 ipsec,debug,packet 131ffca9 18947eb8 acad21c5 cd5311ba 78083067 4ef4eff3 088345ad bef06a19
12:26:27 ipsec,debug,packet b83ea536 7f5d99f5 34423935 dc890203 010001a3 50304e30 1d060355 1d0e0416
12:26:27 ipsec,debug,packet 0414611a 5b430c83 6a12cc37 7176a27c b7f94a8e 60e8301f 0603551d 23041830
12:26:27 ipsec,debug,packet 16801461 1a5b430c 836a12cc 377176a2 7cb7f94a 8e60e830 0c060355 1d130405
12:26:27 ipsec,debug,packet 30030101 ff300d06 092a8648 86f70d01 010b0500 03820201 009fdcd5 ec5fd756
12:26:27 ipsec,debug,packet 714d6611 c5aedd19 4b562acf ea8cf42a 232e68b2 6e530587 4a7bb7e1 e1f95295
12:26:27 ipsec,debug,packet 80cc2bcf 42f00c7e 14b0ea2c 5c0dbc78 93e679c8 7afdb8df ca69285c 84b2fcd5
12:26:27 ipsec,debug,packet 124c5a54 0a118ef5 169b186c 49b13e1d ba03b0f4 c3da2156 5f7e7cb8 a9839cfe
12:26:27 ipsec,debug,packet b5c35c34 9f1766fe df4de52c f238df2f 6aa1ed28 c99d6fb6 4fd4286e f916459f
12:26:27 ipsec,debug,packet 154a2018 d6e93a4b b3f9eb79 63468812 2ca0d328 7afe5e50 e61f3eca 89b41d99
12:26:27 ipsec,debug,packet d110786a 89e19b91 a18a2e4c aeef3438 0f8b512b f98185df 27bfed3d 1ad3c41b
12:26:27 ipsec,debug,packet e0f92cf6 da6c5571 2a304c3f 8569db85 ae4943aa 7064ac51 11debdac 0f5417e0
12:26:27 ipsec,debug,packet 9acc5fd5 40a37a56 88c2781d 87a59f34 24576b94 103d04ca b9b42f92 f5ce3420
12:26:27 ipsec,debug,packet dd866757 41c72745 7d672568 4f622d28 9df7ef8e c5947f3b 51ca9b0a cd7e1dbc
12:26:27 ipsec,debug,packet cf64ef19 c8706486 127082e1 10a0b755 226488fb 7eb70232 cb1b03ab c9f6768c
12:26:27 ipsec,debug,packet d2cec917 b37754a7 8726da9e d4e0911c c6275946 6df6faea 5fa22820 79590a82
12:26:27 ipsec,debug,packet e5bf7f70 156f5037 17a57003 8255b0fe d7d319d1 95edecb8 ad8c8a9e ef21795b
12:26:27 ipsec,debug,packet 10d0378c 6bbb4f3b 1734381d f8fb787d 5234b2f2 299900d5 e79c8e64 688bf3a8
12:26:27 ipsec,debug,packet a80b7b69 f4a7c2d4 0bb4c51c d9b40383 aac7b790 b47b8742 2ea3fff4 f1994d22
12:26:27 ipsec,debug,packet 62c26b51 1c9fcde6 a616221f 63bbcdc0 3ef2e6fc 01814d1d a95e68fd 1b729d54
12:26:27 ipsec,debug,packet e929202e cbdf9748 eb6ddc48 40b74375 19badb04 9bf52996 c3210000 08000040
12:26:27 ipsec,debug,packet 002c0000 44000000 40010304 0503da15 0c030000 0c010000 0c800e01 00030000
12:26:27 ipsec,debug,packet 0c010000 0c800e00 c0030000 0c010000 0c800e00 80030000 08030000 02000000
12:26:27 ipsec,debug,packet 08050000 002d0000 18010000 00070000 100000ff ff000000 00ffffff ff2f0000
12:26:27 ipsec,debug,packet 18010000 00070000 100000ff ff000000 00ffffff ff000000 30010000 00000100
12:26:27 ipsec,debug,packet 04000000 00000200 04000000 00000d00 08000000 00000000 00000300 04000000
12:26:27 ipsec,debug,packet 00001900 00
12:26:27 ipsec fragmenting into 2 chunks
12:26:27 ipsec adding payload: SKF
12:26:27 ipsec,debug => (first 0x100 of 0x494)
12:26:27 ipsec,debug 23000494 00010002 46659544 b65e0f94 dd5b0523 6cb19147 fce3280c 22362108
12:26:27 ipsec,debug a6b17c3f e6765bbc 026e1628 60f4d181 b8ffa7d2 9c7b4c0b b85cdd36 7c231e5d
12:26:27 ipsec,debug 2367157f b6a430fc 4b6cedf6 4e1f8a5c 83a44ae2 77d40fa2 f9df4177 0f24086d
12:26:27 ipsec,debug 45301879 a833dd67 a8173123 3ca23ee8 29683f64 d94120c6 73511284 bdf7ff7e
12:26:27 ipsec,debug 7a7f0cee e118e612 d691d3bc 862050c4 a7a6dbeb c3c2b2e7 82738ccf c0e28732
12:26:27 ipsec,debug d14bd090 1c33b49a 5eeea7b8 c670a80e be993138 80380675 93412e4f 82547987
12:26:27 ipsec,debug bbee7578 a30c316c c2493596 13347add d9e90ad3 32d538f4 83479734 f03f979e
12:26:27 ipsec,debug 36e7bd90 5d3e75b5 3ce8047b bc9b84c1 8eca9183 e4062829 8ed29547 5aa00e58
12:26:27 ipsec,debug => (first 0x100 of 0x2b4)
12:26:27 ipsec,debug 000002b4 00020002 46659544 b65e0f94 dd5b0523 6cb19147 52d54614 3111f36b
12:26:27 ipsec,debug 0210938c 405d44ab 130fba75 0cd5a353 93051116 137d4895 b0132193 76269dc5
12:26:27 ipsec,debug 5418d5eb 8b90c8e3 e5886a80 ec3867a7 a64ab0d6 1c71310f b16162b5 010d5400
12:26:27 ipsec,debug 16fbdc39 2df76037 fa12faf9 0da53b7d a3b3c8a4 9178ccda 80a891e0 8e4a72e3
12:26:27 ipsec,debug 07827bf0 6bc4a441 aa4a37e2 a284503f 0c830292 75c0d0a9 6bf2427c 9ab2778e
12:26:27 ipsec,debug b1b66945 52868f2d 1183cc36 590415bd 733e4784 320ca61e de486c38 8a26768e
12:26:27 ipsec,debug 32f8037a 7a7a7966 fb89947d a648aaa0 43345e7d e48766c3 1d3bd716 52b51cb4
12:26:27 ipsec,debug 8cd757e8 7ac4853b 3e8efc3b 99bec4ac 3ca91feb dd8ebe23 02244dbb 14273bdb
12:26:27 ipsec,debug ===== sending 1200 bytes from 192.168.50.154[4500] to 138.199.29.195[4500]
12:26:27 ipsec,debug 1 times of 1204 bytes message will be sent to 138.199.29.195[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 35202308 00000001 000004b0 23000494
12:26:27 ipsec,debug,packet 00010002 46659544 b65e0f94 dd5b0523 6cb19147 fce3280c 22362108 a6b17c3f
12:26:27 ipsec,debug,packet e6765bbc 026e1628 60f4d181 b8ffa7d2 9c7b4c0b b85cdd36 7c231e5d 2367157f
12:26:27 ipsec,debug,packet b6a430fc 4b6cedf6 4e1f8a5c 83a44ae2 77d40fa2 f9df4177 0f24086d 45301879
12:26:27 ipsec,debug,packet a833dd67 a8173123 3ca23ee8 29683f64 d94120c6 73511284 bdf7ff7e 7a7f0cee
12:26:27 ipsec,debug,packet e118e612 d691d3bc 862050c4 a7a6dbeb c3c2b2e7 82738ccf c0e28732 d14bd090
12:26:27 ipsec,debug,packet 1c33b49a 5eeea7b8 c670a80e be993138 80380675 93412e4f 82547987 bbee7578
12:26:27 ipsec,debug,packet a30c316c c2493596 13347add d9e90ad3 32d538f4 83479734 f03f979e 36e7bd90
12:26:27 ipsec,debug,packet 5d3e75b5 3ce8047b bc9b84c1 8eca9183 e4062829 8ed29547 5aa00e58 97c79a75
12:26:27 ipsec,debug,packet fc3c2071 57af6e24 584b21d1 269bfd42 2ca92a4f 692ee958 b4a257ca 8216a29c
12:26:27 ipsec,debug,packet d2b3e776 5a73ecd8 65d2c0e8 bdb4e9cc 89618f70 c7d40dc9 ba7e3342 c81e0344
12:26:27 ipsec,debug,packet 49ff44fb 7ce3226d b771ae31 b813f485 3576c8fa 9d9d33ab 2cde54a6 c68171c4
12:26:27 ipsec,debug,packet 8bf1b15a 84d5db7e 6cf0de90 95bdf760 62e0e135 7eb76a68 c317cb03 a656a2dc
12:26:27 ipsec,debug,packet 96dd4186 ae31474c e96aeb80 63175e1e 97c77c93 f13a0442 30da3b6b 939b8176
12:26:27 ipsec,debug,packet fddd0ce0 f00ba658 f6759ddf 4f0fa17a 46ab41d2 05a2b757 679f2990 292ca833
12:26:27 ipsec,debug,packet 956a4385 1d1603fe 33040262 0d408677 4b8afc34 013963e1 5752e18e 1952b2d8
12:26:27 ipsec,debug,packet 4c6dea5a afdb1ec9 57c95228 1586b4ef 78a13144 b2994a64 82b792e1 0c1a9b21
12:26:27 ipsec,debug,packet fffb3a56 6e3b444c d76ded3e 00a506f2 776d66f6 2a7e2e08 6d8b3aba ef078be5
12:26:27 ipsec,debug,packet b2b02e26 ba348d88 1be722ce c36e20e5 fa2d0aad 2553ca8f 00ed0a24 4ef375e8
12:26:27 ipsec,debug,packet ea194baf cc580861 5d375fc5 9fc431b0 ddedd5f1 d79b1afc 00462e9e f65ff3e8
12:26:27 ipsec,debug,packet 101e89b4 92d9d08a 19aa09ad a3a55e1b 0f9caeef 057933ac 9b3fc737 26eae40b
12:26:27 ipsec,debug,packet 5606b5f1 25f5441f 9b2a6cf5 636922c7 f8f4f96c d09f20c1 ea7e5d0e fad41580
12:26:27 ipsec,debug,packet 6c4d7dfe 12eddc05 e00374d5 f6c272c4 0025bf47 11146202 d40f7d2a 444588ca
12:26:27 ipsec,debug,packet 6d0f5388 7a949e8f d6ef3e45 519c8147 87f020f3 f9459e74 15d974f8 d974863b
12:26:27 ipsec,debug,packet ca2d9a21 3a3ce3f3 a4564ff1 afa94f01 6948bab5 7b41596b efee7598 674bda19
12:26:27 ipsec,debug,packet 49f115b5 ebe66b02 00c44628 649a3e43 ba7d75ae 8cd67948 95f4ba06 b8ed828a
12:26:27 ipsec,debug,packet 61fabb41 0fea9b4f aae2264f 77673d31 e681adbc ec5717f7 19a31bb4 793a1625
12:26:27 ipsec,debug,packet 1f8ced3f 72caed47 e77c6eee 06c9e892 b6f430e5 6da7d65d 22eaa4a8 c3d68160
12:26:27 ipsec,debug,packet 23006c86 ce141de0 f9abfb01 51878c34 3f5b9b7b e6df300b 50762544 ea4357e2
12:26:27 ipsec,debug,packet 94c16cf4 bedab7ab 9075cc63 5ba744b6 4344189e 9132aff2 9320df49 f8ffaf8b
12:26:27 ipsec,debug,packet 72e215dc 1f9d6703 eb3691a7 0c2ff76c d8f73ed3 caaa02ea 4ea82c9b 122a2b1a
12:26:27 ipsec,debug,packet e0bceb1a 86a6d6cd fd6aeb00 2743ab82 eed11385 7aef19aa bec09ddb a32ed1c8
12:26:27 ipsec,debug,packet 4491ab1f fabb8f95 f9812aa7 1734e2cf c5cf6666 b5033c96 53a87da6 5b870a9b
12:26:27 ipsec,debug,packet 0c951ff9 53c6e3f1 5d76675b f06172b6 e099e3d5 08227d06 9634dfb2 53ff8217
12:26:27 ipsec,debug,packet 12a94cd8 282d6bbb d9007578 b5390aed 08875c3c b21a315e 38256be2 6a606b6b
12:26:27 ipsec,debug,packet dfd5b19e 7c9df9d5 88130ebb cdb38091 920d7e60 bb537274 b564d986 21e818a0
12:26:27 ipsec,debug,packet 6d8cf4bf 63ea96d7 a018271c d00cca1c f753682b c62593ba ec6c029c 609c24ee
12:26:27 ipsec,debug,packet fe596129 383ac29d 4d3f4575 93f13ee2
12:26:27 ipsec,debug ===== sending 720 bytes from 192.168.50.154[4500] to 138.199.29.195[4500]
12:26:27 ipsec,debug 1 times of 724 bytes message will be sent to 138.199.29.195[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 35202308 00000001 000002d0 000002b4
12:26:27 ipsec,debug,packet 00020002 46659544 b65e0f94 dd5b0523 6cb19147 52d54614 3111f36b 0210938c
12:26:27 ipsec,debug,packet 405d44ab 130fba75 0cd5a353 93051116 137d4895 b0132193 76269dc5 5418d5eb
12:26:27 ipsec,debug,packet 8b90c8e3 e5886a80 ec3867a7 a64ab0d6 1c71310f b16162b5 010d5400 16fbdc39
12:26:27 ipsec,debug,packet 2df76037 fa12faf9 0da53b7d a3b3c8a4 9178ccda 80a891e0 8e4a72e3 07827bf0
12:26:27 ipsec,debug,packet 6bc4a441 aa4a37e2 a284503f 0c830292 75c0d0a9 6bf2427c 9ab2778e b1b66945
12:26:27 ipsec,debug,packet 52868f2d 1183cc36 590415bd 733e4784 320ca61e de486c38 8a26768e 32f8037a
12:26:27 ipsec,debug,packet 7a7a7966 fb89947d a648aaa0 43345e7d e48766c3 1d3bd716 52b51cb4 8cd757e8
12:26:27 ipsec,debug,packet 7ac4853b 3e8efc3b 99bec4ac 3ca91feb dd8ebe23 02244dbb 14273bdb dca05177
12:26:27 ipsec,debug,packet 57d7ef9c 4182e08f 20fb6f45 54df9a84 a859f246 e9368762 bfc8d82f e14a7d73
12:26:27 ipsec,debug,packet 665e2eb3 6dd8b3a8 8327f27d 5455a338 200570e2 98bd876c 3fef1241 7ba91571
12:26:27 ipsec,debug,packet 0067258a 9e2c176b ca6e1cc6 c816f2b2 27790580 6fb817b3 1ef58ac1 d8233c65
12:26:27 ipsec,debug,packet 34198784 c535fa31 a832e048 e506480e ba43077d ba971284 81042e8b 2b09de73
12:26:27 ipsec,debug,packet 5d2ed9ac d5327907 3eecd030 08c6ca16 a112f6f9 54bf4691 8015478a b2818bd3
12:26:27 ipsec,debug,packet 2c1fbf5a c7eecff2 4ded096e 6ab0102b 0ffa5289 5c7e2704 e5e98849 092fa04a
12:26:27 ipsec,debug,packet 32fc3b75 63d17a11 a6ee8377 2ea0915f 981fbbed 641512bf f99d4501 7f19100a
12:26:27 ipsec,debug,packet a4392009 06088a4e 34b6f67a 0330ad23 4333904e bb319ecc 16d81948 86865873
12:26:27 ipsec,debug,packet 3990943d 473adf41 738f5dcf 3062f6b8 07ee0d1c a8bb4498 bd29deff f76357cd
12:26:27 ipsec,debug,packet bae7b122 0e111df9 7c6d1ee3 84a15968 2d585405 8201ca69 c07008b2 5f25ece2
12:26:27 ipsec,debug,packet fd5822f4 0fc88071 74df4c12 56a98e2e 388ef234 bb30b259 683e34f7 aa5d6113
12:26:27 ipsec,debug,packet 6bf4d789 97177a08 4f0705c4 2386f358 e9a9a127 17e61b01 bee38067 5ead342d
12:26:27 ipsec,debug,packet 00423129 a720e171 8ccc1d5d 944993e4 bfd318cc 8a0c7ae2 49d63600 56c4c970
12:26:27 ipsec,debug,packet a3160395 de4124d0 814a44b2 434d0f3e
12:26:27 ipsec,debug ===== received 1248 bytes from 138.199.29.195[4500] to 192.168.50.154[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 35202320 00000001 000004e0 240004c4
12:26:27 ipsec,debug,packet 00010003 0da4d230 cee41db9 c813fa4f 4e76412f 2115889e 8f9da8fb a8ede7bd
12:26:27 ipsec,debug,packet 77f4b84c c36a085e b3400f58 ac70cbeb fada3ad6 aafbc120 1293a989 a0ae6294
12:26:27 ipsec,debug,packet 08d985ae d488a347 bc989ce7 fbe016fd 5647d758 582c4997 8c754f7e 3ab7ee20
12:26:27 ipsec,debug,packet 5d88dfe7 bc6ed4f3 8605f967 9a10a536 e1f11c84 fc6c7fe8 a28018d7 24cb6097
12:26:27 ipsec,debug,packet 63dd0b09 759870e0 97c147dd e0893e39 a0f8180f 0685d75e e65325a2 3433322c
12:26:27 ipsec,debug,packet 50dab182 29856216 3552f4e8 2143f01e f488b150 9241f8db fbda908d 7bbb3ca2
12:26:27 ipsec,debug,packet f204bddf 4fcbbbec b5cfca4e 71c5535f 54f85f04 41ae26b9 092ecaa6 19d62e0d
12:26:27 ipsec,debug,packet f8fbf71f 1200e3e2 459c988c 451f2263 633cf417 9208accd b48b0728 f3fa9597
12:26:27 ipsec,debug,packet 475e177a 40831f48 36ec641b aec27ff8 baae2ea2 fe620ce1 0728e4c1 1d2ee65d
12:26:27 ipsec,debug,packet 0b4eeb25 c5d6b242 b3191aad 7bd922c3 917dc17c 830d223f a782296c b5023d47
12:26:27 ipsec,debug,packet d11b0f10 52fe8372 51c1d201 40bd71de e1f4c45d 01e1b616 060b2e96 a67eb156
12:26:27 ipsec,debug,packet b298480a 6f0be466 b0a7de19 adc27a49 a9f3576f 02d0f0d4 8867218f 54547622
12:26:27 ipsec,debug,packet 9aa59780 545124af 60f4fa63 920ba645 3cc1f445 628e7f90 9ee9132b 470a7ea5
12:26:27 ipsec,debug,packet dd993910 569fde99 b922a035 19438c0f 0f3396d6 a7abe726 bbee9c2c 8bdbcf10
12:26:27 ipsec,debug,packet 1efe92d3 f627f7ed de33c7b8 0e2411b6 3c88c026 4de47dde cadedf38 72761337
12:26:27 ipsec,debug,packet f0c6e2ae 239d0720 4d5586af 4f09e051 2f06c93b 3cc8d884 bcc4d330 ee0eb03f
12:26:27 ipsec,debug,packet c5853292 a9b4faa9 000fa6fc c8ad265d 4e8148d0 711745ae 69ce9580 f11f2428
12:26:27 ipsec,debug,packet c1de0be3 db550b2d 021ed07f d7d22002 e5afe7d8 73ad9cf8 ed269f24 0ebf76a6
12:26:27 ipsec,debug,packet 41043f1b a209ef74 292b6f4b fda119c7 08769fe1 c75be8f2 acf4e5a1 748276d2
12:26:27 ipsec,debug,packet b5008cf0 06f74d42 a5be3592 a887981e 31126e7d 97bc4f17 033af16b 6d9cde2e
12:26:27 ipsec,debug,packet 7f824810 6413f479 ed5502c5 7b41246f a89462de caa85a1e c06fec23 47ff12e9
12:26:27 ipsec,debug,packet 183f5bc6 6c307476 b7d9abd3 df0c9d2d 64e64b86 f0da4c14 5c05b643 7ce9314d
12:26:27 ipsec,debug,packet 02cb37af dc0b2af2 9d28b697 8f12642b 45ab93a4 b9319329 4ea200a0 ac85148a
12:26:27 ipsec,debug,packet e04267af aa318b5a 2a08fd72 d416a97a 71bb0550 1e752721 edbb8fa9 b0d050b5
12:26:27 ipsec,debug,packet 2854ff7f ab929bf4 95bd28bf 06d1b02a 56a881e4 8410539f 2ac431ea 8add96f1
12:26:27 ipsec,debug,packet 63dbab08 b02bb8ea dc62ce04 58dd294f acfa9d9f f5a30ca0 b9376b03 a22cb55e
12:26:27 ipsec,debug,packet 2dbe676b 43313bc2 ecbd3364 42dbf658 05f3ca7b 66b1925e 29ffbbb1 3cbf4830
12:26:27 ipsec,debug,packet d9e954b8 0daa95e1 00bf0ce1 d5282621 4a24c134 afbd7907 d83c5b33 c97b3c00
12:26:27 ipsec,debug,packet 8c915002 21b4c264 dac3f758 b29218bd 05d1ed64 6180c355 1a6cffa2 aeb368ae
12:26:27 ipsec,debug,packet 05136987 33c65430 ece59f0e c2d49781 cfafed2a eda15947 e5bc8d2e c9b7b23b
12:26:27 ipsec,debug,packet d02642cf e033b028 84ef6a3b ab8c1f62 548ea74c e7f05caa 13b56a00 98f7b2b6
12:26:27 ipsec,debug,packet b6c4bb5f dfb6f746 5ca646d9 4a4065cb d7429383 ed82551e 29fca329 db42e552
12:26:27 ipsec,debug,packet a6baabc1 096703a4 e8e8f9bc 63a426b7 9834596f 1cd15735 61dca650 67d27468
12:26:27 ipsec,debug,packet 33fcda8b 9a8d3a9f 07d90cba f6406cd9 477a3d12 8036492f 693c9fca 4145f1a5
12:26:27 ipsec,debug,packet aed62a71 5e584c1d 1a4e10a3 fd3b5dc6 affd15a0 4016990b 41a8a9a6 1a6657d6
12:26:27 ipsec,debug,packet c7d93cfa f8a24322 8cb51fce e5b50735 41cf7fbd 72ce6736 af911f99 3c5d3d66
12:26:27 ipsec,debug,packet 2b8d3260 b5fd183e b4f78e06 30a28bb6 f90a2e2f abe2eca0 9371cfd2 9d809932
12:26:27 ipsec,debug,packet e824fe8f 9978bc70 20ac0a77 124987d1 15208ec8 0f956aee 9c876427 69262ccb
12:26:27 ipsec -> ike2 reply, exchange: AUTH:1 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec payload seen: SKF (1220 bytes)
12:26:27 ipsec processing payload: ENC (not found)
12:26:27 ipsec processing payload: SKF
12:26:27 ipsec,debug => iv (size 0x10)
12:26:27 ipsec,debug 0da4d230 cee41db9 c813fa4f 4e76412f
12:26:27 ipsec,debug decrypted fragment 1 out of 3
12:26:27 ipsec,debug,packet => plain fragment (size 0x49f)
12:26:27 ipsec,debug,packet 25000021 02000000 756b2d6c 6f6e2e70 726f642e 73757266 73686172 6b2e636f
12:26:27 ipsec,debug,packet 6d250004 5c043082 04533082 023ba003 02010202 0816425d 839d67e8 e2300d06
12:26:27 ipsec,debug,packet 092a8648 86f70d01 010c0500 3045310b 30090603 55040613 02564731 12301006
12:26:27 ipsec,debug,packet 0355040a 0c095375 72667368 61726b31 22302006 03550403 0c195375 72667368
12:26:27 ipsec,debug,packet 61726b20 496e7465 726d6564 69617465 20434130 1e170d32 32313232 33303933
12:26:27 ipsec,debug,packet 3033335a 170d3233 31323233 30393330 33335a30 24312230 20060355 04031319
12:26:27 ipsec,debug,packet 756b2d6c 6f6e2e70 726f642e 73757266 73686172 6b2e636f 6d308201 22300d06
12:26:27 ipsec,debug,packet 092a8648 86f70d01 01010500 0382010f 00308201 0a028201 0100b83b 77d50c5f
12:26:27 ipsec,debug,packet 5ff715c8 f62dc712 db1fbd0f 9b59daa9 d93bd04a bc21545d 1961ca34 f794a9df
12:26:27 ipsec,debug,packet b059fdb2 6c20ff6e 27dd4b7e d7e2bee3 fd70df87 186ff024 f13c3047 52daa3b4
12:26:27 ipsec,debug,packet c1cf8dce ed2f779c c1873a4f ded22518 b95ac223 7be7e741 e7f5b1f6 2c090562
12:26:27 ipsec,debug,packet a27b42cd 87b9f10c 0cf09327 c199b9c1 0678e706 348d2468 0aeb4663 6bf06a42
12:26:27 ipsec,debug,packet 1cf7d1ce 47a9793c a8b3f4d8 a1414ec3 1c69dab8 7d2a1a0d 270a0dd7 31455004
12:26:27 ipsec,debug,packet 13237409 24381fb4 e0f50566 0aa22a4e d9b828be b8dce0da aee3ebc2 eed57aae
12:26:27 ipsec,debug,packet 08f224f6 0661f1aa 437a4744 40d63a4d e205d532 7b334a74 2e39241e ab1007fb
12:26:27 ipsec,debug,packet 6d988732 c8cc3ece 6bf0c51e 2854aa2b 2195d2b3 0c707d61 95f50203 010001a3
12:26:27 ipsec,debug,packet 68306630 1f060355 1d230418 30168014 1f6d8e4c 9e7ce5e3 32f588c3 66aa74fb
12:26:27 ipsec,debug,packet 34a8751a 30240603 551d1104 1d301b82 19756b2d 6c6f6e2e 70726f64 2e737572
12:26:27 ipsec,debug,packet 66736861 726b2e63 6f6d301d 0603551d 25041630 1406082b 06010505 07030106
12:26:27 ipsec,debug,packet 082b0601 05050802 02300d06 092a8648 86f70d01 010c0500 03820201 003feebd
12:26:27 ipsec,debug,packet 36d0b283 03ebd24b 921c5869 668dd0e7 0a0420ae f15f7d05 9fcbecb1 5a623c3d
12:26:27 ipsec,debug,packet cb7f86a4 b9b90752 d456033d 524fbdfe 555e1b3a ffd6049f d75c97c1 c393cf85
12:26:27 ipsec,debug,packet 0ce8b0ee 1c743269 50f82331 3fa91fbe 035c90c6 2de384bf ae77b1cd 01069dc2
12:26:27 ipsec,debug,packet f43a76b6 95ccaac1 b58d2785 25b5215a 96895254 f8e47440 0aaca74b 7fcac3e8
12:26:27 ipsec,debug,packet b3898129 6c1e5ba2 feffa4e5 34dfd895 8b5105d4 d8921387 a733e2b6 771aa489
12:26:27 ipsec,debug,packet 6c58faee 77101c65 e2a46e25 e5fa9fc1 a319d82b 9d675554 1ae27724 6a13c894
12:26:27 ipsec,debug,packet df71662c e2aadaa8 405b4815 5ca9f1a9 2626f6f1 d2e4baee a043128b 9a5a07c0
12:26:27 ipsec,debug,packet ca7fad57 9d04bc0c 18a52dd1 57104bcc ee939637 3d970598 9924c279 711bd832
12:26:27 ipsec,debug,packet 43e46be5 5fb562ef e790ff62 9ab6967a f9ab6501 de5e7cc7 dfd2761a 6bd01f73
12:26:27 ipsec,debug,packet feea6087 59fc83f5 102f7d19 14e90755 b694b28b b6eaeb25 438d03fa 3372b629
12:26:27 ipsec,debug,packet 75a0e67f 58b8880f 083b5920 44d71ee0 da984056 7e9b0595 363ab1e0 e6af91e8
12:26:27 ipsec,debug,packet b54ab15b de16bf79 750cc61b 250e858b c0a4d5ca a5535caf 91d2fb5c ffe874b0
12:26:27 ipsec,debug,packet dc84e47c 82453b4e 5070545d b1e435c0 715cca04 23b4a169 b35efd61 9bf2e636
12:26:27 ipsec,debug,packet 6a107f46 b9f2ce72 3ebb8461 b84d2d2a 41ba0ccb bb576e34 d84669c0 240759e1
12:26:27 ipsec,debug,packet 891fb412 2d3210e8 4a3029d8 4bb54a97 e0ec3d43 bf132bb6 c0519676 2a5ad346
12:26:27 ipsec,debug,packet 2815dea4 c772dfdb 8d8d53b0 b8791bbd bbfca8a2 d25436df ab1c36ff c3270005
12:26:27 ipsec,debug,packet b9043082 05b03082 0398a003 02010202 146427b3 bd442701 db0f26fb 44149b
12:26:27 ipsec,debug need more fragments
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 35202320 00000001 000004e0 000004c4
12:26:27 ipsec,debug,packet 00020003 16271cc0 0d3edd8d c455781c 51b6f36c a8f48daf c1e95cc3 9a834ca4
12:26:27 ipsec,debug,packet 419887cc 70cb7b88 729f1d90 e17c9363 cdf9a5d6 cdac4418 889c3658 e6a02a77
12:26:27 ipsec,debug,packet 5fc568c8 7821ef47 e3364924 68fafc9a b8b7c529 eba0ebce e0e5678f 26a1a103
12:26:27 ipsec,debug,packet 3ae9741d fcaba58e 80d000ff 20840e5b 451f2ad4 884fb0fb 35add129 20d6dffb
12:26:27 ipsec,debug,packet 0d4cd8a4 bd782edc b02fc579 e7c1d98e 4327efd8 19adf6f0 b3935914 9ccb3505
12:26:27 ipsec,debug,packet 4604450e 8e49cd71 eec4b03c 9893a2da 4912f31c 1f994273 8b5e98de 139f068f
12:26:27 ipsec,debug,packet 54977408 872fa370 5de292d0 6a3b3c33 d366f6e7 84a99c2f 2ce51f0b ef554fbf
12:26:27 ipsec,debug,packet c31e6b16 fc35c542 412041e3 5192d7ac a30a3023 01970025 cb86a2bf 689b653b
12:26:27 ipsec,debug,packet 196d4083 35e0a5b8 9370dfc9 a1bb1303 c683ab1c 07138e56 d671d850 e9ae0f98
12:26:27 ipsec,debug,packet 47f08973 2516049c 480f70c1 e61f8f2d 35e9440e bb8fdc2e b5eb8cbf 4529beeb
12:26:27 ipsec,debug,packet 7a3b7ed0 dae80629 798ba0b5 5ff812a8 9b7c0e94 d824b1f9 7e5da079 5dbcde4c
12:26:27 ipsec,debug,packet 4f7332e4 85ff42fc 3fb9a564 3977c52e 406006cd 690ad7f5 896a3f6f 1ed79d28
12:26:27 ipsec,debug,packet 36933ec5 44987ec5 5d08c4d2 bfb5fff7 f3d834cd 6787ff51 07e30ab3 b264ee9d
12:26:27 ipsec,debug,packet a42ab9dc c10ed93b a73f25fd a66a20ff 2e85da7b 8dfef3ea 54a0839b 5dfc157a
12:26:27 ipsec,debug,packet 93f1e13f 6c219e5a eb6155a2 736c9928 f0c36132 0cbde7cd dc8a26ec 58b19c00
12:26:27 ipsec,debug,packet 1ccfac3f e54ddcfe f5f7f9f2 177740de f0eb97bb a9056e93 816e94a7 fa777086
12:26:27 ipsec,debug,packet 054e9a85 f9291d94 e19b7ea9 57a0d9f3 3638fd1c 5596cffc 234dae2e 856dbc90
12:26:27 ipsec,debug,packet e7e5634f e45f4631 a676a7b4 8d2bf4cd ece981f4 bb55374a eb91fc1e 4cff5a78
12:26:27 ipsec,debug,packet 06e84112 cc024dd0 dfc38074 9116484a d90bc837 2125fe90 436350c3 fe42ed34
12:26:27 ipsec,debug,packet f2fcf624 0d467ba3 1139184e 8926bf5a 76984235 381dde98 6da18999 4bedbb1c
12:26:27 ipsec,debug,packet ff51fbeb 419ae8c3 675713ae 1cf4390c 47e6bb35 7e08d54e 4906ba00 0f23ac7a
12:26:27 ipsec,debug,packet 1b750adc bc7d9b84 11bb286c 6ee9bd2c 27f2471f 9b4463a2 6ae382a4 4af994e6
12:26:27 ipsec,debug,packet f9f935be 0b8694d2 292fc9aa 2737f17b d58b11fc 5f059797 47fe5876 d029b134
12:26:27 ipsec,debug,packet 3905fd96 26949f5f 14821677 abf962f2 3e7f5993 c1ec80ff 2ca62224 3a2a7493
12:26:27 ipsec,debug,packet ee94499c 75c347df e1c87a18 01837a4b 3f5997cb d1eeae67 6067712b 3c006f10
12:26:27 ipsec,debug,packet 9a6fdcae 48350553 69991ccf efedf4e1 344e8bae 26bdf767 b60b125c 669e94b6
12:26:27 ipsec,debug,packet 89e98c6d c7aa5eff 96fd3813 aaf04ab5 0d57ead0 465c56d6 571b30c5 7b2bb0d5
12:26:27 ipsec,debug,packet 9cf915fd c02a50cd 74870ada 03973949 9b72f1f2 3bd46200 41973793 53f0815e
12:26:27 ipsec,debug,packet 9ba817bd 997a9c99 fd14c743 dfacec98 c2837eb3 cc98cb66 dc64172e aa2cb160
12:26:27 ipsec,debug,packet ac2dca5e 2a45be66 86c57bb5 b8634bee f1c578d9 ce380bf1 48281698 288aebd9
12:26:27 ipsec,debug,packet c507d64b 52f18a28 9143fb32 b4b2e8f4 37a3b52f e70a4aaf e492d2f0 9c2eb0ea
12:26:27 ipsec,debug,packet 58bd6dbc 35d60d85 5608cf8f 914e2b6f c205d1dc f2ab98db 42914bdc 7238e20c
12:26:27 ipsec,debug,packet 1c0c63fc 934a8b99 cd0a3e3a 20ad08a5 928cd988 16e7f3e1 31950e31 e1504914
12:26:27 ipsec,debug,packet ca4a1329 331eb38f 66841db4 c2216a45 f6740b10 aea2a125 ee23adfa b7b9f30a
12:26:27 ipsec,debug,packet 6fc84f23 e33635a1 8123b9da 7194afe9 d2399067 f88938b2 38af09f3 00ba4717
12:26:27 ipsec,debug,packet 9d18496b bea2d4ec 2d9a1c06 c9152952 f8881757 5fa6348b 31beebce eb4ed2f0
12:26:27 ipsec,debug,packet 033b897d 583e92f3 49f98ebb 160742e6 7c2eb95d eac6d443 1d093c43 4c316912
12:26:27 ipsec,debug,packet ba1d56b5 a7d22a8b c65bf421 577032e5 dac9cf2c 70a0527b daa0ec6e 357aad18
12:26:27 ipsec,debug 16271cc0 0d3edd8d c455781c 51b6f36c
12:26:27 ipsec,debug decrypted fragment 2 out of 3
12:26:27 ipsec,debug,packet 408d039a e247300d 06092a86 4886f70d 01010b05 00303d31 0b300906 03550406
12:26:27 ipsec,debug,packet 13025647 31123010 06035504 0a0c0953 75726673 6861726b 311a3018 06035504
12:26:27 ipsec,debug,packet 030c1153 75726673 6861726b 20526f6f 74204341 301e170d 32323132 32303136
12:26:27 ipsec,debug,packet 32393434 5a170d32 33313232 30313632 3934345a 3045310b 30090603 55040613
12:26:27 ipsec,debug,packet 02564731 12301006 0355040a 0c095375 72667368 61726b31 22302006 03550403
12:26:27 ipsec,debug,packet 0c195375 72667368 61726b20 496e7465 726d6564 69617465 20434130 82022230
12:26:27 ipsec,debug,packet 0d06092a 864886f7 0d010101 05000382 020f0030 82020a02 82020100 b9583899
12:26:27 ipsec,debug,packet e4adfb00 fbc63eea 72b57dce 2adf35bb aef1c12d 5edac6ef bfb63a9c 1e952968
12:26:27 ipsec,debug,packet eb2fe2e9 f3cc9c58 764ddaa0 f43ec185 f578b814 18ec5428 b1033463 5dff297a
12:26:27 ipsec,debug,packet 0a5725b5 a4392edc aeb7867b 7ff093ec 4c7211b3 7d6a96b4 aa1be7b7 1aa39fcd
12:26:27 ipsec,debug,packet e3d90765 81fe6673 5d99b9d8 b222592b 8ff0db99 18b0cd4f 0d3b2b0b cf1ec2ed
12:26:27 ipsec,debug,packet 54078798 1bcc2cfb ac01e295 e99fef5b 12a523f4 90d6149e 7f040e95 77c1825c
12:26:27 ipsec,debug,packet d527aa2f 2491317f 6655b485 3505ea91 389a480f ad400a06 9355bfd4 7f5e9482
12:26:27 ipsec,debug,packet a4f33cb7 90f87584 9006d4d0 17248750 6f28ae44 c7836b9d 73b59aa2 c2abfeb7
12:26:27 ipsec,debug,packet 4291b1f1 a3042fec a82f1954 f61a4367 ac49f449 6c50b366 b0bd87de 96458a3e
12:26:27 ipsec,debug,packet 6b922389 2a37b4e7 266d003b dcdf62a3 30e1b4f9 d5bd2095 cb7f1ac6 91c125c0
12:26:27 ipsec,debug,packet cba524a8 c98f0b0d 4093fdbc dbd83d0f 106b6fb9 92b1f5b9 014bc595 d71703ba
12:26:27 ipsec,debug,packet ff01b66d acb3593d e34d151b 710cc7f8 eaa60806 a7d48d44 8bf184d0 720bd7cd
12:26:27 ipsec,debug,packet da97f97a 805495c2 c07ce5a1 c4e49053 6a6cca82 e3eb7558 90fac9e4 2ed1e8e6
12:26:27 ipsec,debug,packet 69ba6d29 ae4ecce6 75edaab1 8eef239e 4e8779a2 38cfba15 03c3471f 6c67a844
12:26:27 ipsec,debug,packet 3d369d59 55ac1faa 324306d2 5cd59482 3c23e1c0 4f359f77 91691d86 8110df84
12:26:27 ipsec,debug,packet 52c3d42c d57550a5 fdc7a818 168cf356 6401e0c7 cd818e58 43574b87 0432f8dd
12:26:27 ipsec,debug,packet 0676cd90 b8677032 407ad818 032c5180 948a74c9 798c370d 14c18011 02030100
12:26:27 ipsec,debug,packet 01a3819f 30819c30 1d060355 1d0e0416 04141f6d 8e4c9e7c e5e332f5 88c366aa
12:26:27 ipsec,debug,packet 74fb34a8 751a306d 0603551d 23046630 64801461 1a5b430c 836a12cc 377176a2
12:26:27 ipsec,debug,packet 7cb7f94a 8e60e8a1 41a43f30 3d310b30 09060355 04061302 56473112 30100603
12:26:27 ipsec,debug,packet 55040a0c 09537572 66736861 726b311a 30180603 5504030c 11537572 66736861
12:26:27 ipsec,debug,packet 726b2052 6f6f7420 43418209 00cb3d4b 77eac2ff a6300c06 03551d13 04053003
12:26:27 ipsec,debug,packet 0101ff30 0d06092a 864886f7 0d01010b 05000382 02010004 caca5024 b7ae2ffd
12:26:27 ipsec,debug,packet 908a9a1c f133d591 a88c67cd c4479fd9 975cab80 3ae8b8fd 2883e39f 5b4c4510
12:26:27 ipsec,debug,packet 635840a6 01e3fd03 d9d0536f 495bba53 18b65479 9e45f98f 1b37df99 03a57f43
12:26:27 ipsec,debug,packet d309b172 3851f489 aee9090c 5e7e265b 57b8d6ae 005f0571 36b895dd 8d30ba01
12:26:27 ipsec,debug,packet 88fbcb61 fedc8c79 08dcc7eb fc1f76e5 a0100cac 660c2f36 041268f7 83a28481
12:26:27 ipsec,debug,packet 8546c682 a50bf0cd f915daae 75613f37 baae827d 11fbe5b6 6f7cd827 7861727f
12:26:27 ipsec,debug,packet 1c2307bf c2b96e94 c0017237 297cbb10 d872c6bf 3a70f197 d5aa8d26 cf2ff93b
12:26:27 ipsec,debug,packet ca055cb2 2be5576d 70e40bd0 3d0f8077 86a0a5a3 ae70c52f 19232394 6bd1bc5d
12:26:27 ipsec,debug,packet be631ebf 9448c185 3b24a520 bd149a08 020a0c89 d1f53aa2 f538a6fb 978251
12:26:27 ipsec,debug ===== received 592 bytes from 138.199.29.195[4500] to 192.168.50.154[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 35202320 00000001 00000250 00000234
12:26:27 ipsec,debug,packet 00030003 7092d4e9 970fb7d1 17779f0a 5dafa1fb 0a8f6d29 4f21f525 13bad3fa
12:26:27 ipsec,debug,packet e1612814 39a1c273 a279c491 4c5cb7f7 a448903e d4bfe5ef 6c5aef95 bdfca0b7
12:26:27 ipsec,debug,packet 693e0585 b9ee381a 55aa8ffc 0c36b4ef f5ed6f53 136c01ca 5251b88f 566f22a0
12:26:27 ipsec,debug,packet cc9bccfa 470b5381 f554ba09 f7d89df7 d664ea20 1acad611 203f925f 77943deb
12:26:27 ipsec,debug,packet dec71553 38820200 b0122324 2c887731 6fd3edfb 05f16aca 6200ca85 74c627e9
12:26:27 ipsec,debug,packet 4f19a24d 20730853 f58739f2 0b783839 f9608958 e2910022 39df37bc f78cbef8
12:26:27 ipsec,debug,packet e9f28be1 74234ebf ef09caca 50518844 ce638ff1 cbd42489 df2f921a 6b56a282
12:26:27 ipsec,debug,packet c1880d45 ee6c37aa fc825aef 1983082f def58298 2c35f4a8 ebf51055 9f7715d0
12:26:27 ipsec,debug,packet a0050c61 39e403c8 4755e77c 47acc2ba d4a03867 e91dbf21 3bf07e56 377f2fac
12:26:27 ipsec,debug,packet 905cb03d ce558036 01b7cf59 6db00a60 66e475a0 45a6771d 5e903368 154d2e93
12:26:27 ipsec,debug,packet c719b07c f448f990 6dc3ebae 38f546c6 35b74da5 c872eae6 62492c83 c926345c
12:26:27 ipsec,debug,packet 2e753d2f 6b20f85e 91e55908 66ee6f02 dc28daf2 4a5b42d3 9023ba3c d8947b95
12:26:27 ipsec,debug,packet 54981354 504a3267 e77b7064 432e9795 f549ad6b 42650171 b97f3859 a5022af4
12:26:27 ipsec,debug,packet ecb07c20 eea80cc2 a7b2f63a 19e21970 3812d281 4fb3a20b 2cd6f834 9c562c41
12:26:27 ipsec,debug,packet f2076fcc 65ad36bb 71c910c2 b16f61a4 480087b6 62483e19 66055f31 21a4e8f8
12:26:27 ipsec,debug,packet 46b0788e 37d57c14 bccd4ca9 7cba975c 67c50858 40e3c126 962c9f4b 1de8ba92
12:26:27 ipsec,debug,packet f85e164e 29a937ec 628113be ed73f768 d72e3361 bf773c33 126155e7 73ddd6a4
12:26:27 ipsec,debug,packet cb354452 159fe714 3442f96d 00aa9077
12:26:27 ipsec payload seen: SKF (564 bytes)
12:26:27 ipsec,debug 7092d4e9 970fb7d1 17779f0a 5dafa1fb
12:26:27 ipsec,debug decrypted fragment 3 out of 3
12:26:27 ipsec,debug,packet => plain fragment (size 0x209)
12:26:27 ipsec,debug,packet fe5e5cd0 a9029399 6015bcb7 6aaa1b6c a9e05260 13a505a9 1fd37317 be125b0d
12:26:27 ipsec,debug,packet a88b177a 0222ee9b a808d1c2 88bff24b f750f6f7 b80565b8 61042ff6 c499452b
12:26:27 ipsec,debug,packet 612d9b30 65cf3e50 8a089ec7 c4c2f777 64f129bd 01de4c55 328ffa54 1d3987fa
12:26:27 ipsec,debug,packet 955fdf23 702c1cc4 2303020d 12f30712 65592364 5c7fdb52 3d62b093 e18f7733
12:26:27 ipsec,debug,packet b2ce8545 809a5042 04fb47cc 3f248290 2647e5b6 fe1f79b4 0fe9f677 1dab7662
12:26:27 ipsec,debug,packet 8177910a 597bc29d ec638340 2b90159b 3f7f3c6c 08152527 9e105d2e 41a52dc5
12:26:27 ipsec,debug,packet 1d7b1848 41549cf2 323828be e9a77eaa 47fda382 2a1f416d ede8f163 4e43a95a
12:26:27 ipsec,debug,packet 61264703 4415c488 6aacc387 3f6c0bf1 fca139ba fb6104ef 30000108 01000000
12:26:27 ipsec,debug,packet 8e937602 af8c331a 2e8091d7 adfa003e 929ed8e7 9010eae0 167ecab0 414d94e7
12:26:27 ipsec,debug,packet adf03dec 98022ee8 dd4570e9 9a714c03 9dcc853c 8c35172f a24f8113 6b0a082f
12:26:27 ipsec,debug,packet 112625f2 1dea9c05 d570de8b 08b9f98f 339dccc6 70ef81af 5a9dca27 fb96fb38
12:26:27 ipsec,debug,packet 3ef28ac6 2cda11d2 a97c37c2 9f2fa7e1 fe9847b1 38c79d90 e235da9f 8725b60e
12:26:27 ipsec,debug,packet 5222267e ca14aa16 6e9719f6 407b75bb dbaf966b bad3bd64 b5eda758 15f2e9b2
12:26:27 ipsec,debug,packet 0c2b255a 9a989fe9 4d90551d 72329ea8 6d25d5c9 3570ede0 1df34570 ad54621e
12:26:27 ipsec,debug,packet ecd84df6 81544146 62deaa5e 69f5f71b a9e1c955 ae4436f5 a0f64cc6 43812932
12:26:27 ipsec,debug,packet f61705f5 f0132866 9edc338b 23ee4d3d e07cc538 6547b935 62463c63 bb8411f6
12:26:27 ipsec,debug,packet 00000009 01000005 01
12:26:27 ipsec,debug reassembling fragments
12:26:27 ipsec,debug,packet => decrypted packet (size 0xb63)
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 24202320 00000001 00000b63 25000021
12:26:27 ipsec,debug,packet 02000000 756b2d6c 6f6e2e70 726f642e 73757266 73686172 6b2e636f 6d250004
12:26:27 ipsec,debug,packet 5c043082 04533082 023ba003 02010202 0816425d 839d67e8 e2300d06 092a8648
12:26:27 ipsec,debug,packet 86f70d01 010c0500 3045310b 30090603 55040613 02564731 12301006 0355040a
12:26:27 ipsec,debug,packet 0c095375 72667368 61726b31 22302006 03550403 0c195375 72667368 61726b20
12:26:27 ipsec,debug,packet 496e7465 726d6564 69617465 20434130 1e170d32 32313232 33303933 3033335a
12:26:27 ipsec,debug,packet 170d3233 31323233 30393330 33335a30 24312230 20060355 04031319 756b2d6c
12:26:27 ipsec,debug,packet 6f6e2e70 726f642e 73757266 73686172 6b2e636f 6d308201 22300d06 092a8648
12:26:27 ipsec,debug,packet 86f70d01 01010500 0382010f 00308201 0a028201 0100b83b 77d50c5f 5ff715c8
12:26:27 ipsec,debug,packet f62dc712 db1fbd0f 9b59daa9 d93bd04a bc21545d 1961ca34 f794a9df b059fdb2
12:26:27 ipsec,debug,packet 6c20ff6e 27dd4b7e d7e2bee3 fd70df87 186ff024 f13c3047 52daa3b4 c1cf8dce
12:26:27 ipsec,debug,packet ed2f779c c1873a4f ded22518 b95ac223 7be7e741 e7f5b1f6 2c090562 a27b42cd
12:26:27 ipsec,debug,packet 87b9f10c 0cf09327 c199b9c1 0678e706 348d2468 0aeb4663 6bf06a42 1cf7d1ce
12:26:27 ipsec,debug,packet 47a9793c a8b3f4d8 a1414ec3 1c69dab8 7d2a1a0d 270a0dd7 31455004 13237409
12:26:27 ipsec,debug,packet 24381fb4 e0f50566 0aa22a4e d9b828be b8dce0da aee3ebc2 eed57aae 08f224f6
12:26:27 ipsec,debug,packet 0661f1aa 437a4744 40d63a4d e205d532 7b334a74 2e39241e ab1007fb 6d988732
12:26:27 ipsec,debug,packet c8cc3ece 6bf0c51e 2854aa2b 2195d2b3 0c707d61 95f50203 010001a3 68306630
12:26:27 ipsec,debug,packet 1f060355 1d230418 30168014 1f6d8e4c 9e7ce5e3 32f588c3 66aa74fb 34a8751a
12:26:27 ipsec,debug,packet 30240603 551d1104 1d301b82 19756b2d 6c6f6e2e 70726f64 2e737572 66736861
12:26:27 ipsec,debug,packet 726b2e63 6f6d301d 0603551d 25041630 1406082b 06010505 07030106 082b0601
12:26:27 ipsec,debug,packet 05050802 02300d06 092a8648 86f70d01 010c0500 03820201 003feebd 36d0b283
12:26:27 ipsec,debug,packet 03ebd24b 921c5869 668dd0e7 0a0420ae f15f7d05 9fcbecb1 5a623c3d cb7f86a4
12:26:27 ipsec,debug,packet b9b90752 d456033d 524fbdfe 555e1b3a ffd6049f d75c97c1 c393cf85 0ce8b0ee
12:26:27 ipsec,debug,packet 1c743269 50f82331 3fa91fbe 035c90c6 2de384bf ae77b1cd 01069dc2 f43a76b6
12:26:27 ipsec,debug,packet 95ccaac1 b58d2785 25b5215a 96895254 f8e47440 0aaca74b 7fcac3e8 b3898129
12:26:27 ipsec,debug,packet 6c1e5ba2 feffa4e5 34dfd895 8b5105d4 d8921387 a733e2b6 771aa489 6c58faee
12:26:27 ipsec,debug,packet 77101c65 e2a46e25 e5fa9fc1 a319d82b 9d675554 1ae27724 6a13c894 df71662c
12:26:27 ipsec,debug,packet e2aadaa8 405b4815 5ca9f1a9 2626f6f1 d2e4baee a043128b 9a5a07c0 ca7fad57
12:26:27 ipsec,debug,packet 9d04bc0c 18a52dd1 57104bcc ee939637 3d970598 9924c279 711bd832 43e46be5
12:26:27 ipsec,debug,packet 5fb562ef e790ff62 9ab6967a f9ab6501 de5e7cc7 dfd2761a 6bd01f73 feea6087
12:26:27 ipsec,debug,packet 59fc83f5 102f7d19 14e90755 b694b28b b6eaeb25 438d03fa 3372b629 75a0e67f
12:26:27 ipsec,debug,packet 58b8880f 083b5920 44d71ee0 da984056 7e9b0595 363ab1e0 e6af91e8 b54ab15b
12:26:27 ipsec,debug,packet de16bf79 750cc61b 250e858b c0a4d5ca a5535caf 91d2fb5c ffe874b0 dc84e47c
12:26:27 ipsec,debug,packet 82453b4e 5070545d b1e435c0 715cca04 23b4a169 b35efd61 9bf2e636 6a107f46
12:26:27 ipsec,debug,packet b9f2ce72 3ebb8461 b84d2d2a 41ba0ccb bb576e34 d84669c0 240759e1 891fb412
12:26:27 ipsec,debug,packet 2d3210e8 4a3029d8 4bb54a97 e0ec3d43 bf132bb6 c0519676 2a5ad346 2815dea4
12:26:27 ipsec,debug,packet c772dfdb 8d8d53b0 b8791bbd bbfca8a2 d25436df ab1c36ff c3270005 b9043082
12:26:27 ipsec,debug,packet 05b03082 0398a003 02010202 146427b3 bd442701 db0f26fb 44149b40 8d039ae2
12:26:27 ipsec,debug,packet 47300d06 092a8648 86f70d01 010b0500 303d310b 30090603 55040613 02564731
12:26:27 ipsec,debug,packet 12301006 0355040a 0c095375 72667368 61726b31 1a301806 03550403 0c115375
12:26:27 ipsec,debug,packet 72667368 61726b20 526f6f74 20434130 1e170d32 32313232 30313632 3934345a
12:26:27 ipsec,debug,packet 170d3233 31323230 31363239 34345a30 45310b30 09060355 04061302 56473112
12:26:27 ipsec,debug,packet 30100603 55040a0c 09537572 66736861 726b3122 30200603 5504030c 19537572
12:26:27 ipsec,debug,packet 66736861 726b2049 6e746572 6d656469 61746520 43413082 0222300d 06092a86
12:26:27 ipsec,debug,packet 4886f70d 01010105 00038202 0f003082 020a0282 020100b9 583899e4 adfb00fb
12:26:27 ipsec,debug,packet c63eea72 b57dce2a df35bbae f1c12d5e dac6efbf b63a9c1e 952968eb 2fe2e9f3
12:26:27 ipsec,debug,packet cc9c5876 4ddaa0f4 3ec185f5 78b81418 ec5428b1 0334635d ff297a0a 5725b5a4
12:26:27 ipsec,debug,packet 392edcae b7867b7f f093ec4c 7211b37d 6a96b4aa 1be7b71a a39fcde3 d9076581
12:26:27 ipsec,debug,packet fe66735d 99b9d8b2 22592b8f f0db9918 b0cd4f0d 3b2b0bcf 1ec2ed54 0787981b
12:26:27 ipsec,debug,packet cc2cfbac 01e295e9 9fef5b12 a523f490 d6149e7f 040e9577 c1825cd5 27aa2f24
12:26:27 ipsec,debug,packet 91317f66 55b48535 05ea9138 9a480fad 400a0693 55bfd47f 5e9482a4 f33cb790
12:26:27 ipsec,debug,packet f8758490 06d4d017 2487506f 28ae44c7 836b9d73 b59aa2c2 abfeb742 91b1f1a3
12:26:27 ipsec,debug,packet 042feca8 2f1954f6 1a4367ac 49f4496c 50b366b0 bd87de96 458a3e6b 9223892a
12:26:27 ipsec,debug,packet 37b4e726 6d003bdc df62a330 e1b4f9d5 bd2095cb 7f1ac691 c125c0cb a524a8c9
12:26:27 ipsec,debug,packet 8f0b0d40 93fdbcdb d83d0f10 6b6fb992 b1f5b901 4bc595d7 1703baff 01b66dac
12:26:27 ipsec,debug,packet b3593de3 4d151b71 0cc7f8ea a60806a7 d48d448b f184d072 0bd7cdda 97f97a80
12:26:27 ipsec,debug,packet 5495c2c0 7ce5a1c4 e490536a 6cca82e3 eb755890 fac9e42e d1e8e669 ba6d29ae
12:26:27 ipsec,debug,packet 4ecce675 edaab18e ef239e4e 8779a238 cfba1503 c3471f6c 67a8443d 369d5955
12:26:27 ipsec,debug,packet ac1faa32 4306d25c d594823c 23e1c04f 359f7791 691d8681 10df8452 c3d42cd5
12:26:27 ipsec,debug,packet 7550a5fd c7a81816 8cf35664 01e0c7cd 818e5843 574b8704 32f8dd06 76cd90b8
12:26:27 ipsec,debug,packet 67703240 7ad81803 2c518094 8a74c979 8c370d14 c1801102 03010001 a3819f30
12:26:27 ipsec,debug,packet 819c301d 0603551d 0e041604 141f6d8e 4c9e7ce5 e332f588 c366aa74 fb34a875
12:26:27 ipsec,debug,packet 1a306d06 03551d23 04663064 8014611a 5b430c83 6a12cc37 7176a27c b7f94a8e
12:26:27 ipsec,debug,packet 60e8a141 a43f303d 310b3009 06035504 06130256 47311230 10060355 040a0c09
12:26:27 ipsec,debug,packet 53757266 73686172 6b311a30 18060355 04030c11 53757266 73686172 6b20526f
12:26:27 ipsec,debug,packet 6f742043 41820900 cb3d4b77 eac2ffa6 300c0603 551d1304 05300301 01ff300d
12:26:27 ipsec,debug,packet 06092a86 4886f70d 01010b05 00038202 010004ca ca5024b7 ae2ffd90 8a9a1cf1
12:26:27 ipsec,debug,packet 33d591a8 8c67cdc4 479fd997 5cab803a e8b8fd28 83e39f5b 4c451063 5840a601
12:26:27 ipsec,debug,packet e3fd03d9 d0536f49 5bba5318 b654799e 45f98f1b 37df9903 a57f43d3 09b17238
12:26:27 ipsec,debug,packet 51f489ae e9090c5e 7e265b57 b8d6ae00 5f057136 b895dd8d 30ba0188 fbcb61fe
12:26:27 ipsec,debug,packet dc8c7908 dcc7ebfc 1f76e5a0 100cac66 0c2f3604 1268f783 a2848185 46c682a5
12:26:27 ipsec,debug,packet 0bf0cdf9 15daae75 613f37ba ae827d11 fbe5b66f 7cd82778 61727f1c 2307bfc2
12:26:27 ipsec,debug,packet b96e94c0 01723729 7cbb10d8 72c6bf3a 70f197d5 aa8d26cf 2ff93bca 055cb22b
12:26:27 ipsec,debug,packet e5576d70 e40bd03d 0f807786 a0a5a3ae 70c52f19 2323946b d1bc5dbe 631ebf94
12:26:27 ipsec,debug,packet 48c1853b 24a520bd 149a0802 0a0c89d1 f53aa2f5 38a6fb97 8251fe5e 5cd0a902
12:26:27 ipsec,debug,packet 93996015 bcb76aaa 1b6ca9e0 526013a5 05a91fd3 7317be12 5b0da88b 177a0222
12:26:27 ipsec,debug,packet ee9ba808 d1c288bf f24bf750 f6f7b805 65b86104 2ff6c499 452b612d 9b3065cf
12:26:27 ipsec,debug,packet 3e508a08 9ec7c4c2 f77764f1 29bd01de 4c55328f fa541d39 87fa955f df23702c
12:26:27 ipsec,debug,packet 1cc42303 020d12f3 07126559 23645c7f db523d62 b093e18f 7733b2ce 8545809a
12:26:27 ipsec,debug,packet 504204fb 47cc3f24 82902647 e5b6fe1f 79b40fe9 f6771dab 76628177 910a597b
12:26:27 ipsec,debug,packet c29dec63 83402b90 159b3f7f 3c6c0815 25279e10 5d2e41a5 2dc51d7b 18484154
12:26:27 ipsec,debug,packet 9cf23238 28bee9a7 7eaa47fd a3822a1f 416dede8 f1634e43 a95a6126 47034415
12:26:27 ipsec,debug,packet c4886aac c3873f6c 0bf1fca1 39bafb61 04ef3000 01080100 00008e93 7602af8c
12:26:27 ipsec,debug,packet 331a2e80 91d7adfa 003e929e d8e79010 eae0167e cab0414d 94e7adf0 3dec9802
12:26:27 ipsec,debug,packet 2ee8dd45 70e99a71 4c039dcc 853c8c35 172fa24f 81136b0a 082f1126 25f21dea
12:26:27 ipsec,debug,packet 9c05d570 de8b08b9 f98f339d ccc670ef 81af5a9d ca27fb96 fb383ef2 8ac62cda
12:26:27 ipsec,debug,packet 11d2a97c 37c29f2f a7e1fe98 47b138c7 9d90e235 da9f8725 b60e5222 267eca14
12:26:27 ipsec,debug,packet aa166e97 19f6407b 75bbdbaf 966bbad3 bd64b5ed a75815f2 e9b20c2b 255a9a98
12:26:27 ipsec,debug,packet 9fe94d90 551d7232 9ea86d25 d5c93570 ede01df3 4570ad54 621eecd8 4df68154
12:26:27 ipsec,debug,packet 414662de aa5e69f5 f71ba9e1 c955ae44 36f5a0f6 4cc64381 2932f617 05f5f013
12:26:27 ipsec,debug,packet 28669edc 338b23ee 4d3de07c c5386547 b9356246 3c63bb84 11f60000 00090100
12:26:27 ipsec,debug,packet 000501
12:26:27 ipsec,debug => certificate (size 0x457)
12:26:27 ipsec,debug 30820453 3082023b a0030201 02020816 425d839d 67e8e230 0d06092a 864886f7
12:26:27 ipsec,debug 0d01010c 05003045 310b3009 06035504 06130256 47311230 10060355 040a0c09
12:26:27 ipsec,debug 53757266 73686172 6b312230 20060355 04030c19 53757266 73686172 6b20496e
12:26:27 ipsec,debug 7465726d 65646961 74652043 41301e17 0d323231 32323330 39333033 335a170d
12:26:27 ipsec,debug 32333132 32333039 33303333 5a302431 22302006 03550403 1319756b 2d6c6f6e
12:26:27 ipsec,debug 2e70726f 642e7375 72667368 61726b2e 636f6d30 82012230 0d06092a 864886f7
12:26:27 ipsec,debug 0d010101 05000382 010f0030 82010a02 82010100 b83b77d5 0c5f5ff7 15c8f62d
12:26:27 ipsec,debug c712db1f bd0f9b59 daa9d93b d04abc21 545d1961 ca34f794 a9dfb059 fdb26c20
12:26:27 ipsec,debug ff6e27dd 4b7ed7e2 bee3fd70 df87186f f024f13c 304752da a3b4c1cf 8dceed2f
12:26:27 ipsec,debug 779cc187 3a4fded2 2518b95a c2237be7 e741e7f5 b1f62c09 0562a27b 42cd87b9
12:26:27 ipsec,debug f10c0cf0 9327c199 b9c10678 e706348d 24680aeb 46636bf0 6a421cf7 d1ce47a9
12:26:27 ipsec,debug 793ca8b3 f4d8a141 4ec31c69 dab87d2a 1a0d270a 0dd73145 50041323 74092438
12:26:27 ipsec,debug 1fb4e0f5 05660aa2 2a4ed9b8 28beb8dc e0daaee3 ebc2eed5 7aae08f2 24f60661
12:26:27 ipsec,debug f1aa437a 474440d6 3a4de205 d5327b33 4a742e39 241eab10 07fb6d98 8732c8cc
12:26:27 ipsec,debug 3ece6bf0 c51e2854 aa2b2195 d2b30c70 7d6195f5 02030100 01a36830 66301f06
12:26:27 ipsec,debug 03551d23 04183016 80141f6d 8e4c9e7c e5e332f5 88c366aa 74fb34a8 751a3024
12:26:27 ipsec,debug 0603551d 11041d30 1b821975 6b2d6c6f 6e2e7072 6f642e73 75726673 6861726b
12:26:27 ipsec,debug 2e636f6d 301d0603 551d2504 16301406 082b0601 05050703 0106082b 06010505
12:26:27 ipsec,debug 08020230 0d06092a 864886f7 0d01010c 05000382 0201003f eebd36d0 b28303eb
12:26:27 ipsec,debug d24b921c 5869668d d0e70a04 20aef15f 7d059fcb ecb15a62 3c3dcb7f 86a4b9b9
12:26:27 ipsec,debug 0752d456 033d524f bdfe555e 1b3affd6 049fd75c 97c1c393 cf850ce8 b0ee1c74
12:26:27 ipsec,debug 326950f8 23313fa9 1fbe035c 90c62de3 84bfae77 b1cd0106 9dc2f43a 76b695cc
12:26:27 ipsec,debug aac1b58d 278525b5 215a9689 5254f8e4 74400aac a74b7fca c3e8b389 81296c1e
12:26:27 ipsec,debug 5ba2feff a4e534df d8958b51 05d4d892 1387a733 e2b6771a a4896c58 faee7710
12:26:27 ipsec,debug 1c65e2a4 6e25e5fa 9fc1a319 d82b9d67 55541ae2 77246a13 c894df71 662ce2aa
12:26:27 ipsec,debug daa8405b 48155ca9 f1a92626 f6f1d2e4 baeea043 128b9a5a 07c0ca7f ad579d04
12:26:27 ipsec,debug bc0c18a5 2dd15710 4bccee93 96373d97 05989924 c279711b d83243e4 6be55fb5
12:26:27 ipsec,debug 62efe790 ff629ab6 967af9ab 6501de5e 7cc7dfd2 761a6bd0 1f73feea 608759fc
12:26:27 ipsec,debug 83f5102f 7d1914e9 0755b694 b28bb6ea eb25438d 03fa3372 b62975a0 e67f58b8
12:26:27 ipsec,debug 880f083b 592044d7 1ee0da98 40567e9b 0595363a b1e0e6af 91e8b54a b15bde16
12:26:27 ipsec,debug bf79750c c61b250e 858bc0a4 d5caa553 5caf91d2 fb5cffe8 74b0dc84 e47c8245
12:26:27 ipsec,debug 3b4e5070 545db1e4 35c0715c ca0423b4 a169b35e fd619bf2 e6366a10 7f46b9f2
12:26:27 ipsec,debug ce723ebb 8461b84d 2d2a41ba 0ccbbb57 6e34d846 69c02407 59e1891f b4122d32
12:26:27 ipsec,debug 10e84a30 29d84bb5 4a97e0ec 3d43bf13 2bb6c051 96762a5a d3462815 dea4c772
12:26:27 ipsec,debug dfdb8d8d 53b0b879 1bbdbbfc a8a2d254 36dfab1c 36ffc3
12:26:27 ipsec got CERT: C=VG, O=Surfshark, CN=Surfshark Intermediate CA
12:26:27 ipsec,debug => certificate (size 0x5b4)
12:26:27 ipsec,debug 308205b0 30820398 a0030201 02021464 27b3bd44 2701db0f 26fb4414 9b408d03
12:26:27 ipsec,debug 9ae24730 0d06092a 864886f7 0d01010b 0500303d 310b3009 06035504 06130256
12:26:27 ipsec,debug 47311230 10060355 040a0c09 53757266 73686172 6b311a30 18060355 04030c11
12:26:27 ipsec,debug 53757266 73686172 6b20526f 6f742043 41301e17 0d323231 32323031 36323934
12:26:27 ipsec,debug 345a170d 32333132 32303136 32393434 5a304531 0b300906 03550406 13025647
12:26:27 ipsec,debug 31123010 06035504 0a0c0953 75726673 6861726b 31223020 06035504 030c1953
12:26:27 ipsec,debug 75726673 6861726b 20496e74 65726d65 64696174 65204341 30820222 300d0609
12:26:27 ipsec,debug 2a864886 f70d0101 01050003 82020f00 3082020a 02820201 00b95838 99e4adfb
12:26:27 ipsec,debug 00fbc63e ea72b57d ce2adf35 bbaef1c1 2d5edac6 efbfb63a 9c1e9529 68eb2fe2
12:26:27 ipsec,debug e9f3cc9c 58764dda a0f43ec1 85f578b8 1418ec54 28b10334 635dff29 7a0a5725
12:26:27 ipsec,debug b5a4392e dcaeb786 7b7ff093 ec4c7211 b37d6a96 b4aa1be7 b71aa39f cde3d907
12:26:27 ipsec,debug 6581fe66 735d99b9 d8b22259 2b8ff0db 9918b0cd 4f0d3b2b 0bcf1ec2 ed540787
12:26:27 ipsec,debug 981bcc2c fbac01e2 95e99fef 5b12a523 f490d614 9e7f040e 9577c182 5cd527aa
12:26:27 ipsec,debug 2f249131 7f6655b4 853505ea 91389a48 0fad400a 069355bf d47f5e94 82a4f33c
12:26:27 ipsec,debug b790f875 849006d4 d0172487 506f28ae 44c7836b 9d73b59a a2c2abfe b74291b1
12:26:27 ipsec,debug f1a3042f eca82f19 54f61a43 67ac49f4 496c50b3 66b0bd87 de96458a 3e6b9223
12:26:27 ipsec,debug 892a37b4 e7266d00 3bdcdf62 a330e1b4 f9d5bd20 95cb7f1a c691c125 c0cba524
12:26:27 ipsec,debug a8c98f0b 0d4093fd bcdbd83d 0f106b6f b992b1f5 b9014bc5 95d71703 baff01b6
12:26:27 ipsec,debug 6dacb359 3de34d15 1b710cc7 f8eaa608 06a7d48d 448bf184 d0720bd7 cdda97f9
12:26:27 ipsec,debug 7a805495 c2c07ce5 a1c4e490 536a6cca 82e3eb75 5890fac9 e42ed1e8 e669ba6d
12:26:27 ipsec,debug 29ae4ecc e675edaa b18eef23 9e4e8779 a238cfba 1503c347 1f6c67a8 443d369d
12:26:27 ipsec,debug 5955ac1f aa324306 d25cd594 823c23e1 c04f359f 7791691d 868110df 8452c3d4
12:26:27 ipsec,debug 2cd57550 a5fdc7a8 18168cf3 566401e0 c7cd818e 5843574b 870432f8 dd0676cd
12:26:27 ipsec,debug 90b86770 32407ad8 18032c51 80948a74 c9798c37 0d14c180 11020301 0001a381
12:26:27 ipsec,debug 9f30819c 301d0603 551d0e04 1604141f 6d8e4c9e 7ce5e332 f588c366 aa74fb34
12:26:27 ipsec,debug a8751a30 6d060355 1d230466 30648014 611a5b43 0c836a12 cc377176 a27cb7f9
12:26:27 ipsec,debug 4a8e60e8 a141a43f 303d310b 30090603 55040613 02564731 12301006 0355040a
12:26:27 ipsec,debug 526f6f74 20434182 0900cb3d 4b77eac2 ffa6300c 0603551d 13040530 030101ff
12:26:27 ipsec,debug 300d0609 2a864886 f70d0101 0b050003 82020100 04caca50 24b7ae2f fd908a9a
12:26:27 ipsec,debug 1cf133d5 91a88c67 cdc4479f d9975cab 803ae8b8 fd2883e3 9f5b4c45 10635840
12:26:27 ipsec,debug a601e3fd 03d9d053 6f495bba 5318b654 799e45f9 8f1b37df 9903a57f 43d309b1
12:26:27 ipsec,debug 723851f4 89aee909 0c5e7e26 5b57b8d6 ae005f05 7136b895 dd8d30ba 0188fbcb
12:26:27 ipsec,debug 61fedc8c 7908dcc7 ebfc1f76 e5a0100c ac660c2f 36041268 f783a284 818546c6
12:26:27 ipsec,debug 82a50bf0 cdf915da ae75613f 37baae82 7d11fbe5 b66f7cd8 27786172 7f1c2307
12:26:27 ipsec,debug bfc2b96e 94c00172 37297cbb 10d872c6 bf3a70f1 97d5aa8d 26cf2ff9 3bca055c
12:26:27 ipsec,debug b22be557 6d70e40b d03d0f80 7786a0a5 a3ae70c5 2f192323 946bd1bc 5dbe631e
12:26:27 ipsec,debug bf9448c1 853b24a5 20bd149a 08020a0c 89d1f53a a2f538a6 fb978251 fe5e5cd0
12:26:27 ipsec,debug a9029399 6015bcb7 6aaa1b6c a9e05260 13a505a9 1fd37317 be125b0d a88b177a
12:26:27 ipsec,debug 0222ee9b a808d1c2 88bff24b f750f6f7 b80565b8 61042ff6 c499452b 612d9b30
12:26:27 ipsec,debug 65cf3e50 8a089ec7 c4c2f777 64f129bd 01de4c55 328ffa54 1d3987fa 955fdf23
12:26:27 ipsec,debug 702c1cc4 2303020d 12f30712 65592364 5c7fdb52 3d62b093 e18f7733 b2ce8545
12:26:27 ipsec,debug 809a5042 04fb47cc 3f248290 2647e5b6 fe1f79b4 0fe9f677 1dab7662 8177910a
12:26:27 ipsec,debug 597bc29d ec638340 2b90159b 3f7f3c6c 08152527 9e105d2e 41a52dc5 1d7b1848
12:26:27 ipsec,debug 41549cf2 323828be e9a77eaa 47fda382 2a1f416d ede8f163 4e43a95a 61264703
12:26:27 ipsec,debug 4415c488 6aacc387 3f6c0bf1 fca139ba fb6104ef
12:26:27 ipsec requested auth method: RSA
12:26:27 ipsec,debug => peer's auth (size 0x100)
12:26:27 ipsec,debug 8e937602 af8c331a 2e8091d7 adfa003e 929ed8e7 9010eae0 167ecab0 414d94e7
12:26:27 ipsec,debug adf03dec 98022ee8 dd4570e9 9a714c03 9dcc853c 8c35172f a24f8113 6b0a082f
12:26:27 ipsec,debug 112625f2 1dea9c05 d570de8b 08b9f98f 339dccc6 70ef81af 5a9dca27 fb96fb38
12:26:27 ipsec,debug 3ef28ac6 2cda11d2 a97c37c2 9f2fa7e1 fe9847b1 38c79d90 e235da9f 8725b60e
12:26:27 ipsec,debug 5222267e ca14aa16 6e9719f6 407b75bb dbaf966b bad3bd64 b5eda758 15f2e9b2
12:26:27 ipsec,debug 0c2b255a 9a989fe9 4d90551d 72329ea8 6d25d5c9 3570ede0 1df34570 ad54621e
12:26:27 ipsec,debug ecd84df6 81544146 62deaa5e 69f5f71b a9e1c955 ae4436f5 a0f64cc6 43812932
12:26:27 ipsec,debug f61705f5 f0132866 9edc338b 23ee4d3d e07cc538 6547b935 62463c63 bb8411f6
12:26:27 ipsec,debug checking SAN: uk-lon.prod.surfshark.com
12:26:27 ipsec,debug => auth nonce (size 0x18)
12:26:27 ipsec,debug faf4eb16 d8756c01 2f10a512 845b487a 57141751 8ca7be8d
12:26:27 ipsec,debug => SK_p (size 0x14)
12:26:27 ipsec,debug => idhash (size 0x14)
12:26:27 ipsec,debug 42743997 d2b33928 3fd0c2e4 4f998f2c 390c1f94
12:26:27 ipsec,info,account peer authorized: FRBD 192.168.50.154[4500]-138.199.29.195[4500] spi:cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec processing payload: EAP
12:26:27 ipsec adding payload: EAP
12:26:27 ipsec,debug => (size 0x21)
12:26:27 ipsec,debug 00000021 0200001d 0133775a 70644d45 766a4650 67786566 714a4137 62765236
12:26:27 ipsec,debug 66
12:26:27 ipsec <- ike2 request, exchange: AUTH:2 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec,debug,packet => outgoing plain packet (size 0x3d)
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 30202308 00000002 0000003d 00000021
12:26:27 ipsec,debug,packet 0200001d 0133775a 70644d45 766a4650 67786566 714a4137 62765236 66
12:26:27 ipsec adding payload: ENC
12:26:27 ipsec,debug => (size 0x50)
12:26:27 ipsec,debug 30000050 a4cb3544 52159fe7 143442f9 6d00aa90 b4615b87 0f9bad02 4708226b
12:26:27 ipsec,debug c2272f06 be67580c bf5945a2 e5008b82 350db220 2c1431a4 7d6e750b 49744953
12:26:27 ipsec,debug 72475dc4 00000000 00000000 00000000
12:26:27 ipsec,debug ===== sending 108 bytes from 192.168.50.154[4500] to 138.199.29.195[4500]
12:26:27 ipsec,debug 1 times of 112 bytes message will be sent to 138.199.29.195[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202308 00000002 0000006c 30000050
12:26:27 ipsec,debug,packet a4cb3544 52159fe7 143442f9 6d00aa90 b4615b87 0f9bad02 4708226b c2272f06
12:26:27 ipsec,debug,packet be67580c bf5945a2 e5008b82 350db220 2c1431a4 7d6e750b 49744953 72475dc4
12:26:27 ipsec,debug,packet b32605f1 954a8b4d b41d2871
12:26:27 ipsec,debug ===== received 76 bytes from 138.199.29.195[4500] to 192.168.50.154[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202320 00000002 0000004c 30000030
12:26:27 ipsec,debug,packet 2810623b bde599e8 11f3f718 0b438e53 45d61cf0 8d7bf223 2b17e268 82925979
12:26:27 ipsec,debug,packet c92fb23e 91118be5 bc7a8e41
12:26:27 ipsec -> ike2 reply, exchange: AUTH:2 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec payload seen: ENC (48 bytes)
12:26:27 ipsec,debug 2810623b bde599e8 11f3f718 0b438e53
12:26:27 ipsec,debug decrypted packet
12:26:27 ipsec,debug,packet => decrypted packet (size 0x26)
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 30202320 00000002 00000026 0000000a
12:26:27 ipsec,debug,packet 01010006 1920
12:26:27 ipsec payload seen: EAP (10 bytes)
12:26:27 ipsec,debug => (size 0xa)
12:26:27 ipsec,debug 0000000a 02010006 031a
12:26:27 ipsec <- ike2 request, exchange: AUTH:3 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec,debug,packet => outgoing plain packet (size 0x26)
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 30202308 00000003 00000026 0000000a
12:26:27 ipsec,debug,packet 02010006 031a
12:26:27 ipsec,debug => (size 0xf0)
12:26:27 ipsec,debug 300000f0 68829259 79c92fb2 3e91118b e5bc7a8e 90141596 1b851c06 6cf5b7a1
12:26:27 ipsec,debug 3a2d1aa7 ef57580e 16edb6c5 455bd47c 16e6066b 76bedfd7 c0a6fd37 b3abcf3f
12:26:27 ipsec,debug ce836e36 5d0c1d62 5d3ec664 bd26a359 bb7ddfe7 facb0244 42fd4bbc 44243bc1
12:26:27 ipsec,debug eec7fd76 23b53040 5ffeb454 8bcf5191 3b61a80a 3a86fe94 7149d2fe 8a7b9b4f
12:26:27 ipsec,debug 693b5e00 f55d2d19 61149ec7 897710d4 67e01619 c69b1b15 4df644a9 eec5f74a
12:26:27 ipsec,debug a086bc20 1a90ccc5 5dc5c04c a8f0285d ac1c0f73 4a1ceab5 a3635b13 5e7e98f8
12:26:27 ipsec,debug 2f48082e 47fde3b9 4100da76 235e28fe 029c31f6 85c3ed02 961397b7 67fefa55
12:26:27 ipsec,debug 89e3be7a 00000000 00000000 00000000
12:26:27 ipsec,debug ===== sending 268 bytes from 192.168.50.154[4500] to 138.199.29.195[4500]
12:26:27 ipsec,debug 1 times of 272 bytes message will be sent to 138.199.29.195[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202308 00000003 0000010c 300000f0
12:26:27 ipsec,debug,packet 68829259 79c92fb2 3e91118b e5bc7a8e 90141596 1b851c06 6cf5b7a1 3a2d1aa7
12:26:27 ipsec,debug,packet ef57580e 16edb6c5 455bd47c 16e6066b 76bedfd7 c0a6fd37 b3abcf3f ce836e36
12:26:27 ipsec,debug,packet 5d0c1d62 5d3ec664 bd26a359 bb7ddfe7 facb0244 42fd4bbc 44243bc1 eec7fd76
12:26:27 ipsec,debug,packet 23b53040 5ffeb454 8bcf5191 3b61a80a 3a86fe94 7149d2fe 8a7b9b4f 693b5e00
12:26:27 ipsec,debug,packet f55d2d19 61149ec7 897710d4 67e01619 c69b1b15 4df644a9 eec5f74a a086bc20
12:26:27 ipsec,debug,packet 1a90ccc5 5dc5c04c a8f0285d ac1c0f73 4a1ceab5 a3635b13 5e7e98f8 2f48082e
12:26:27 ipsec,debug,packet 47fde3b9 4100da76 235e28fe 029c31f6 85c3ed02 961397b7 67fefa55 89e3be7a
12:26:27 ipsec,debug,packet 36044b4a 02120096 69d44210
12:26:27 ipsec,debug ===== received 108 bytes from 138.199.29.195[4500] to 192.168.50.154[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202320 00000003 0000006c 30000050
12:26:27 ipsec,debug,packet 7637654c c80e131f 5612b668 a8b9ed92 afe68ef9 b0e737cc 812fd79c a51376cd
12:26:27 ipsec,debug,packet 9e517349 689d1835 ce2bd2cb 55f131c3 f4ce8eae dd2b8d7a 14d9d92b db615e2d
12:26:27 ipsec,debug,packet fa07e164 e9c5bc24 adc27314
12:26:27 ipsec -> ike2 reply, exchange: AUTH:3 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec payload seen: ENC (80 bytes)
12:26:27 ipsec,debug 7637654c c80e131f 5612b668 a8b9ed92
12:26:27 ipsec,debug,packet => decrypted packet (size 0x4b)
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 30202320 00000003 0000004b 0000002f
12:26:27 ipsec,debug,packet 0102002b 1a010200 26106083 d18482dc 9df41232 d02d103d f7a76672 65657261
12:26:27 ipsec,debug,packet 64697573 2d332e30 2e3136
12:26:27 ipsec payload seen: EAP (47 bytes)
12:26:27 ipsec processing payloads: NOTIFY (none found)
12:26:27 ipsec,debug => (size 0x57)
12:26:27 ipsec,debug 00000057 02020053 1a020200 4e3186f9 e5676520 1aa97907 b0b12243 f66b0000
12:26:27 ipsec,debug 00000000 0000b9a8 211cd4e9 2e47c994 c3e3fe92 d270171d 401a9eed ea6a0033
12:26:27 ipsec,debug 775a7064 4d45766a 46506778 6566714a 41376276 523666
12:26:27 ipsec <- ike2 request, exchange: AUTH:4 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:27 ipsec,debug,packet => outgoing plain packet (size 0x73)
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 30202308 00000004 00000073 00000057
12:26:27 ipsec,debug,packet 02020053 1a020200 4e3186f9 e5676520 1aa97907 b0b12243 f66b0000 00000000
12:26:27 ipsec,debug,packet 0000b9a8 211cd4e9 2e47c994 c3e3fe92 d270171d 401a9eed ea6a0033 775a7064
12:26:27 ipsec,debug,packet 4d45766a 46506778 6566714a 41376276 523666
12:26:27 ipsec,debug => (size 0xc0)
12:26:27 ipsec,debug 300000c0 2bdb615e 2dfa07e1 64e9c5bc 24adc273 c41ef1e3 a1fbd2a3 62981d07
12:26:27 ipsec,debug 1f54d04a e204684c 7a358e1a 09a91253 bf3cf7f9 46eb5c0c bc02f67c a7959380
12:26:27 ipsec,debug 7275cf86 b1681a0a 5f0342c9 83880a1c 318e79b5 ad19f4f1 b477f167 39ce1149
12:26:27 ipsec,debug 79bf6eee f2543a95 a29312d0 ef36fa76 a4967936 4f683020 65438e1b 7e48d5a5
12:26:27 ipsec,debug a1723288 86f75037 8fb36718 18ad3efc e763face 99ffc977 418ee6bb bce32165
12:26:27 ipsec,debug 4184c3da e4ce5169 e354a042 ea91576e f0268ccb 00000000 00000000 00000000
12:26:27 ipsec,debug ===== sending 220 bytes from 192.168.50.154[4500] to 138.199.29.195[4500]
12:26:27 ipsec,debug 1 times of 224 bytes message will be sent to 138.199.29.195[4500]
12:26:27 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202308 00000004 000000dc 300000c0
12:26:27 ipsec,debug,packet 2bdb615e 2dfa07e1 64e9c5bc 24adc273 c41ef1e3 a1fbd2a3 62981d07 1f54d04a
12:26:27 ipsec,debug,packet e204684c 7a358e1a 09a91253 bf3cf7f9 46eb5c0c bc02f67c a7959380 7275cf86
12:26:27 ipsec,debug,packet b1681a0a 5f0342c9 83880a1c 318e79b5 ad19f4f1 b477f167 39ce1149 79bf6eee
12:26:27 ipsec,debug,packet f2543a95 a29312d0 ef36fa76 a4967936 4f683020 65438e1b 7e48d5a5 a1723288
12:26:27 ipsec,debug,packet 86f75037 8fb36718 18ad3efc e763face 99ffc977 418ee6bb bce32165 4184c3da
12:26:27 ipsec,debug,packet e4ce5169 e354a042 ea91576e f0268ccb 15fb2fe7 f0a71148 163ad439
12:26:28 ipsec,debug ===== received 124 bytes from 138.199.29.195[4500] to 192.168.50.154[4500]
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202320 00000004 0000007c 30000060
12:26:28 ipsec,debug,packet ebafc6b2 a0bd5f1b 3d72c5fc 6c5d53e1 b2448024 4e25983c 38826157 874cee81
12:26:28 ipsec,debug,packet f3c3e8c9 59529ffb 4f7e2403 636b517f 6513fa2a 9821eb81 8887a83f 39c1b9cf
12:26:28 ipsec,debug,packet 9c37ba3d e41c4fb4 de23fc57 6c913cab c2fef64e 7ffa1d6a 88b47e31
12:26:28 ipsec -> ike2 reply, exchange: AUTH:4 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:28 ipsec payload seen: ENC (96 bytes)
12:26:28 ipsec processing payload: ENC
12:26:28 ipsec,debug => iv (size 0x10)
12:26:28 ipsec,debug ebafc6b2 a0bd5f1b 3d72c5fc 6c5d53e1
12:26:28 ipsec,debug decrypted packet
12:26:28 ipsec,debug,packet => decrypted packet (size 0x53)
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 30202320 00000004 00000053 00000037
12:26:28 ipsec,debug,packet 01030033 1a030200 2e533d43 41443337 44384531 43463443 32324544 35373436
12:26:28 ipsec,debug,packet 36413933 35344333 34344536 37453846 463033
12:26:28 ipsec payload seen: EAP (55 bytes)
12:26:28 ipsec processing payloads: NOTIFY (none found)
12:26:28 ipsec processing payload: EAP
12:26:28 ipsec adding payload: EAP
12:26:28 ipsec,debug => (size 0xa)
12:26:28 ipsec,debug 0000000a 02030006 1a03
12:26:28 ipsec <- ike2 request, exchange: AUTH:5 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:28 ipsec,debug,packet => outgoing plain packet (size 0x26)
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 30202308 00000005 00000026 0000000a
12:26:28 ipsec,debug,packet 02030006 1a03
12:26:28 ipsec adding payload: ENC
12:26:28 ipsec,debug => (first 0x100 of 0x120)
12:26:28 ipsec,debug 30000120 576c913c abc2fef6 4e7ffa1d 6a88b47e fca8ff64 128f3c1e 9d932b68
12:26:28 ipsec,debug 48882477 54c26088 4d8ebd5c 3fefd6ce c189884e 5552ba2c e4da0f5f 92af9850
12:26:28 ipsec,debug 2db7f194 3cdbd0e4 b09f521b 835d0eda 93a334bc 1757224e 9bd0f8a9 006c122a
12:26:28 ipsec,debug 128c4faa a9f01fb9 e7caf0d0 19ffcd71 a59bfbb0 d83d3cd0 f83afe7d 83bda85f
12:26:28 ipsec,debug 4d39e01b a9e596c0 fdefade6 f686b9cf 53d51c11 ccac9794 e6f4e144 7ca9910e
12:26:28 ipsec,debug ccb421f2 b040b993 0a92f0cf 5b84dd9c 4181a9fc 4205eff7 94c3f33b 1b52811f
12:26:28 ipsec,debug 2bfe5155 427435b5 05f7b447 2797ea23 dfdb3e89 cae3796e 3bb8d719 9c06019e
12:26:28 ipsec,debug f4626eba c1304f66 81c0df5a 4acc561c 3141414e 7a38bdae c8943b30 ce189041
12:26:28 ipsec,debug ===== sending 316 bytes from 192.168.50.154[4500] to 138.199.29.195[4500]
12:26:28 ipsec,debug 1 times of 320 bytes message will be sent to 138.199.29.195[4500]
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202308 00000005 0000013c 30000120
12:26:28 ipsec,debug,packet 576c913c abc2fef6 4e7ffa1d 6a88b47e fca8ff64 128f3c1e 9d932b68 48882477
12:26:28 ipsec,debug,packet 54c26088 4d8ebd5c 3fefd6ce c189884e 5552ba2c e4da0f5f 92af9850 2db7f194
12:26:28 ipsec,debug,packet 3cdbd0e4 b09f521b 835d0eda 93a334bc 1757224e 9bd0f8a9 006c122a 128c4faa
12:26:28 ipsec,debug,packet a9f01fb9 e7caf0d0 19ffcd71 a59bfbb0 d83d3cd0 f83afe7d 83bda85f 4d39e01b
12:26:28 ipsec,debug,packet a9e596c0 fdefade6 f686b9cf 53d51c11 ccac9794 e6f4e144 7ca9910e ccb421f2
12:26:28 ipsec,debug,packet b040b993 0a92f0cf 5b84dd9c 4181a9fc 4205eff7 94c3f33b 1b52811f 2bfe5155
12:26:28 ipsec,debug,packet 427435b5 05f7b447 2797ea23 dfdb3e89 cae3796e 3bb8d719 9c06019e f4626eba
12:26:28 ipsec,debug,packet c1304f66 81c0df5a 4acc561c 3141414e 7a38bdae c8943b30 ce189041 786aa290
12:26:28 ipsec,debug,packet dca80a85 bed8d03f 2ff19127 17bb36f5 006b7e4e 2ea18ba6 4a41b819
12:26:28 ipsec,debug ===== received 76 bytes from 138.199.29.195[4500] to 192.168.50.154[4500]
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202320 00000005 0000004c 30000030
12:26:28 ipsec,debug,packet aa0a6117 d1069fc5 6d890c24 2e55d2f5 4c6e27dc e00800c9 2cfda12e 533a6c37
12:26:28 ipsec,debug,packet a605f8ad 24a551ad 4d7c859b
12:26:28 ipsec -> ike2 reply, exchange: AUTH:5 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:28 ipsec payload seen: ENC (48 bytes)
12:26:28 ipsec,debug aa0a6117 d1069fc5 6d890c24 2e55d2f5
12:26:28 ipsec,debug,packet => decrypted packet (size 0x24)
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 30202320 00000005 00000024 00000008
12:26:28 ipsec,debug,packet 03030004
12:26:28 ipsec payload seen: EAP (8 bytes)
12:26:28 ipsec EAP success
12:26:28 ipsec,debug => EAP MSK (size 0x40)
12:26:28 ipsec,debug cb157867 562e533f 984ecb9c b52d7d41 bbd9142c dd801afd 70150140 bfb28fba
12:26:28 ipsec,debug 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
12:26:28 ipsec ID_I (DER DN): C=VG, O=Surfshark, CN=Surfshark Root CA
12:26:28 ipsec,debug => auth nonce (size 0x20)
12:26:28 ipsec,debug e8d3b231 f5b85580 4ce48340 21dc198a 2316f2e2 7a2d6ab6 67a77c24 7d14f3f2
12:26:28 ipsec,debug => SK_p (size 0x14)
12:26:28 ipsec,debug 473cd74b d47b3979 957d9c60 7ef83107 cf119078
12:26:28 ipsec,debug => idhash (size 0x14)
12:26:28 ipsec,debug 86db9fab 3d92bbaf bd10fe8a 7b21c4b8 932c6340
12:26:28 ipsec,debug => my auth (size 0x14)
12:26:28 ipsec,debug 2dcec0ec fdba0ddb 4eeb8581 21d74727 e2beb70d
12:26:28 ipsec adding payload: AUTH
12:26:28 ipsec,debug => (size 0x1c)
12:26:28 ipsec,debug 0000001c 02000000 2dcec0ec fdba0ddb 4eeb8581 21d74727 e2beb70d
12:26:28 ipsec <- ike2 request, exchange: AUTH:6 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:28 ipsec,debug,packet => outgoing plain packet (size 0x38)
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 27202308 00000006 00000038 0000001c
12:26:28 ipsec,debug,packet 02000000 2dcec0ec fdba0ddb 4eeb8581 21d74727 e2beb70d
12:26:28 ipsec,debug => (first 0x100 of 0x130)
12:26:28 ipsec,debug 27000130 2e533a6c 37a605f8 ad24a551 ad4d7c85 431e2450 493a5b03 801942c2
12:26:28 ipsec,debug 1602deec 3f03cf70 847b2e80 1117c85e f40b6d9d 5e1fdd91 294af9e5 f765bbd1
12:26:28 ipsec,debug 037f19f6 d26e4543 b08c4d90 fc3cbb6b c8a6f734 6975064f 54ea5d98 712eea88
12:26:28 ipsec,debug 44dabeac a8d1625e 588653c9 f5efa94a e147e391 6284242d 7a75309e df6bdd95
12:26:28 ipsec,debug 0773e1c9 95f5b179 ca303f70 54aaaa05 6d297728 a263a012 63f23b9c 9841cb68
12:26:28 ipsec,debug 73b2a548 7e29c7b4 66816d7a 6512f1ad f5eab452 79944157 e52715d8 ce1987c6
12:26:28 ipsec,debug e83d51e5 064a5ae6 e2735ba0 78399c48 7818586b 5039d3c9 112d06e8 8ff12f51
12:26:28 ipsec,debug eafff165 b3e8d889 f6489ea1 ff0a197c 8aefc97d e8158e90 35a56fb0 23d00176
12:26:28 ipsec,debug ===== sending 332 bytes from 192.168.50.154[4500] to 138.199.29.195[4500]
12:26:28 ipsec,debug 1 times of 336 bytes message will be sent to 138.199.29.195[4500]
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202308 00000006 0000014c 27000130
12:26:28 ipsec,debug,packet 2e533a6c 37a605f8 ad24a551 ad4d7c85 431e2450 493a5b03 801942c2 1602deec
12:26:28 ipsec,debug,packet 3f03cf70 847b2e80 1117c85e f40b6d9d 5e1fdd91 294af9e5 f765bbd1 037f19f6
12:26:28 ipsec,debug,packet d26e4543 b08c4d90 fc3cbb6b c8a6f734 6975064f 54ea5d98 712eea88 44dabeac
12:26:28 ipsec,debug,packet a8d1625e 588653c9 f5efa94a e147e391 6284242d 7a75309e df6bdd95 0773e1c9
12:26:28 ipsec,debug,packet 95f5b179 ca303f70 54aaaa05 6d297728 a263a012 63f23b9c 9841cb68 73b2a548
12:26:28 ipsec,debug,packet 7e29c7b4 66816d7a 6512f1ad f5eab452 79944157 e52715d8 ce1987c6 e83d51e5
12:26:28 ipsec,debug,packet 064a5ae6 e2735ba0 78399c48 7818586b 5039d3c9 112d06e8 8ff12f51 eafff165
12:26:28 ipsec,debug,packet b3e8d889 f6489ea1 ff0a197c 8aefc97d e8158e90 35a56fb0 23d00176 17f609a2
12:26:28 ipsec,debug,packet 2f03850a 638602ab ff748f34 b13276b1 23a244f9 626226ef f6b766ee 703806ae
12:26:28 ipsec,debug,packet 41de58a8 ea971cfc 5585dc97
12:26:28 ipsec,debug ===== received 236 bytes from 138.199.29.195[4500] to 192.168.50.154[4500]
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202320 00000006 000000ec 270000d0
12:26:28 ipsec,debug,packet a9629060 76537810 d396e1ec b04a8b65 7cc6b775 0f1e00ae f46ca7f3 03101d4e
12:26:28 ipsec,debug,packet 36d90478 2d0a9876 a31fc63e 37033411 22554d29 ff98e7f6 ef37123b 9a2c13d0
12:26:28 ipsec,debug,packet e4723a01 f700364c 9936b1e9 f0a3f63e 4c5ea9cc 8aacced7 c964acb8 ead6dc80
12:26:28 ipsec,debug,packet 182e89e9 a2291c67 ef3e2b2e 0cbcb4ce 4113056f 119eadcf 50dcd2e6 8f750f5a
12:26:28 ipsec,debug,packet ea43e8fc b0169d75 5cc8003b f0cd9c61 6e61e391 623629f3 80c40df6 1b885a57
12:26:28 ipsec,debug,packet c4d0e1bc 89a3e2eb 8f14f431 2e27ef1f bc0a314a 1d91d410 c5a5585c 155d592d
12:26:28 ipsec,debug,packet aaad77cd 1ef0e602 1d355eeb
12:26:28 ipsec -> ike2 reply, exchange: AUTH:6 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:28 ipsec payload seen: ENC (208 bytes)
12:26:28 ipsec,debug a9629060 76537810 d396e1ec b04a8b65
12:26:28 ipsec,debug,packet => decrypted packet (size 0xbc)
12:26:28 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 27202320 00000006 000000bc 2f00001c
12:26:28 ipsec,debug,packet 02000000 4d1e4b38 b3866bd0 bbc89692 4863a943 f5933663 21000028 02000000
12:26:28 ipsec,debug,packet 00010004 0a060306 00030004 a2fcac39 00030004 959a9f5c 00020004 ffffffff
12:26:28 ipsec,debug,packet 2c00002c 00000028 01030403 cccd3a05 0300000c 0100000c 800e0100 03000008
12:26:28 ipsec,debug,packet 03000002 00000008 05000000 2d000018 01000000 07000010 0000ffff 0a060306
12:26:28 ipsec,debug,packet 0a060306 00000018 01000000 07000010 0000ffff 00000000 ffffffff
12:26:28 ipsec payload seen: AUTH (28 bytes)
12:26:28 ipsec payload seen: CONFIG (40 bytes)
12:26:28 ipsec payload seen: SA (44 bytes)
12:26:28 ipsec payload seen: TS_I (24 bytes)
12:26:28 ipsec payload seen: TS_R (24 bytes)
12:26:28 ipsec processing payload: AUTH
12:26:28 ipsec requested auth method: SKEY
12:26:28 ipsec,debug => peer's auth (size 0x14)
12:26:28 ipsec,debug 4d1e4b38 b3866bd0 bbc89692 4863a943 f5933663
12:26:28 ipsec,debug => auth nonce (size 0x18)
12:26:28 ipsec,debug faf4eb16 d8756c01 2f10a512 845b487a 57141751 8ca7be8d
12:26:28 ipsec,debug 56720ae1 02c1f888 95681ac7 ed3928ef 80217ef7
12:26:28 ipsec,debug 42743997 d2b33928 3fd0c2e4 4f998f2c 390c1f94
12:26:28 ipsec,debug => calculated peer's AUTH (size 0x14)
12:26:28 ipsec,info,account EAP authorized: FRBD 192.168.50.154[4500]-138.199.29.195[4500] spi:cb3a007dccb83593:8673ef9df1c95f53
12:26:28 ipsec peer selected tunnel mode
12:26:28 ipsec processing payload: SA
12:26:28 ipsec IKE Protocol: ESP
12:26:28 ipsec proposal #1
12:26:28 ipsec enc: aes256-cbc
12:26:28 ipsec auth: sha1
12:26:28 ipsec matched proposal:
12:26:28 ipsec processing payload: TS_I
12:26:28 ipsec 10.6.3.6
12:26:28 ipsec processing payload: TS_R
12:26:28 ipsec 0.0.0.0/0
12:26:28 ipsec updating my selectors
12:26:28 ipsec using selectors: 10.6.3.6 <=> 0.0.0.0/0
12:26:28 ipsec searching for policy for selector: 10.6.3.6 <=> 0.0.0.0/0
12:26:28 ipsec generating policy
12:26:28 ipsec,debug => child keymat (size 0x78)
12:26:28 ipsec,debug d890b78f e47fc568 e08383e8 fcd42d88 09cbeaa3 eb9723c5 df590885 9e72cbee
12:26:28 ipsec,debug 5857090c 580d6067 c75414ed 0747b5a1 b6f6117e 868c83ef 4767d5ac fc5931f0
12:26:28 ipsec,debug b65a923e 9775107c 248fc46e 8ce8ea11 b579e853 e6d03b36 bb07d0e4 72bd9ab1
12:26:28 ipsec,debug 4bf9d712 83144fbe 3ff67ba9 99412192 89545e09 1fb3e70e
12:26:28 ipsec IPsec-SA established: 138.199.29.195[4500]->192.168.50.154[4500] spi=0x3da150c
12:26:28 ipsec IPsec-SA established: 192.168.50.154[4500]->138.199.29.195[4500] spi=0xcccd3a05
12:26:28 ipsec processing payload: CONFIG
12:26:28 ipsec attribute: internal IPv4 address size: 4
12:26:28 ipsec attribute: internal IPv4 DNS size: 4
12:26:28 ipsec attribute: internal IPv4 netmask size: 4
12:26:28 ipsec got address 10.6.3.6
12:26:28 ipsec got netmask 255.255.255.255
12:26:28 ipsec exclusive dns 162.252.172.57
12:26:28 ipsec exclusive dns 149.154.159.92
12:26:36 ipsec DNS address changed for FRBD to 217.146.83.103
12:26:36 ipsec,info killing ike2 SA: FRBD 192.168.50.154[4500]-138.199.29.195[4500] spi:cb3a007dccb83593:8673ef9df1c95f53
12:26:36 ipsec IPsec-SA killing: 138.199.29.195[4500]->192.168.50.154[4500] spi=0x3da150c
12:26:36 ipsec IPsec-SA killing: 192.168.50.154[4500]->138.199.29.195[4500] spi=0xcccd3a05
12:26:36 ipsec removing generated policy
12:26:36 ipsec adding payload: DELETE
12:26:36 ipsec,debug => (size 0x8)
12:26:36 ipsec,debug 00000008 01000000
12:26:36 ipsec <- ike2 request, exchange: INFORMATIONAL:7 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:36 ipsec,debug,packet => outgoing plain packet (size 0x24)
12:26:36 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2a202508 00000007 00000024 00000008
12:26:36 ipsec,debug,packet 01000000
12:26:36 ipsec adding payload: ENC
12:26:36 ipsec,debug => (size 0xd0)
12:26:36 ipsec,debug 2a0000d0 5c155d59 2daaad77 cd1ef0e6 021d355e 34ff16c7 b30b3eea 2ffab4a2
12:26:36 ipsec,debug e41e517f 6f21a8bd 22a7932a a69bda34 05b84c5b af6064f6 0f2a998e 9a154fa4
12:26:36 ipsec,debug 7de68fc5 5bb370d1 6b2665c6 31a60b03 d492205a d3f2a8db e916cf7b a7adedf8
12:26:36 ipsec,debug c752ca16 69fd8f17 5306a285 4a3c20b3 4cd1beb7 d0ffae8a cd87f166 0097388b
12:26:36 ipsec,debug 001e2280 f984bcbd 85fd20d1 53063a56 6c7ae35f ce2a26e7 c7973504 a7fe1c84
12:26:36 ipsec,debug 6db62ade 45b1950f 43b7b8d9 b1ca3228 6bdd1ceb 457dc36a 832ac991 3d4e303a
12:26:36 ipsec,debug db100913 00000000 00000000 00000000
12:26:36 ipsec,debug ===== sending 236 bytes from 192.168.50.154[4500] to 138.199.29.195[4500]
12:26:36 ipsec,debug 1 times of 240 bytes message will be sent to 138.199.29.195[4500]
12:26:36 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202508 00000007 000000ec 2a0000d0
12:26:36 ipsec,debug,packet 5c155d59 2daaad77 cd1ef0e6 021d355e 34ff16c7 b30b3eea 2ffab4a2 e41e517f
12:26:36 ipsec,debug,packet 6f21a8bd 22a7932a a69bda34 05b84c5b af6064f6 0f2a998e 9a154fa4 7de68fc5
12:26:36 ipsec,debug,packet 5bb370d1 6b2665c6 31a60b03 d492205a d3f2a8db e916cf7b a7adedf8 c752ca16
12:26:36 ipsec,debug,packet 69fd8f17 5306a285 4a3c20b3 4cd1beb7 d0ffae8a cd87f166 0097388b 001e2280
12:26:36 ipsec,debug,packet f984bcbd 85fd20d1 53063a56 6c7ae35f ce2a26e7 c7973504 a7fe1c84 6db62ade
12:26:36 ipsec,debug,packet 45b1950f 43b7b8d9 b1ca3228 6bdd1ceb 457dc36a 832ac991 3d4e303a db100913
12:26:36 ipsec,debug,packet 11136fef 645fb526 9b04df4d
12:26:36 ipsec KA remove: 192.168.50.154[4500]->138.199.29.195[4500]
12:26:36 ipsec,debug KA tree dump: 192.168.50.154[4500]->138.199.29.195[4500] (in_use=1)
12:26:36 ipsec,debug KA removing this one...
12:26:36 ipsec,debug ===== received 76 bytes from 138.199.29.195[4500] to 192.168.50.154[4500]
12:26:36 ipsec,debug,packet cb3a007d ccb83593 8673ef9d f1c95f53 2e202520 00000007 0000004c 00000030
12:26:36 ipsec,debug,packet 6871f04c b955ef84 37c62b72 6a8f6d3b a8e5c4ac eee122cf a6926d3b bd4e258e
12:26:36 ipsec,debug,packet 4f32c669 73d7421b e15b5f39
12:26:36 ipsec -> ike2 reply, exchange: INFORMATIONAL:7 138.199.29.195[4500] cb3a007dccb83593:8673ef9df1c95f53
12:26:36 ipsec SPI cb3a007dccb83593 not registered for 138.199.29.195[4500]
12:26:36 system,info,account user admin logged in from 192.168.50.156 via local
https://support.surfshark.com/hc/en-us/ ... with-IKEv2
Code: Select all
[admin@MikroTik] > export
# mar/10/2023 12:44:20 by RouterOS 7.8
# software id =
set [ find default-name=ether1 ] disable-running-check=no
/ip ipsec mode-config
add name=FRBD responder=no
/ip ipsec policy group
add name=FRBD
/ip ipsec profile
add name=FRBD
/ip ipsec peer
add address=uk-lon.prod.surfshark.com exchange-mode=ike2 name=FRBD profile=FRBD
/ip ipsec proposal
add name=FRBD pfs-group=none
/port
set 0 name=serial0
set 1 name=serial1
/ip dhcp-client
add interface=ether1
/ip ipsec identity
add auth-method=eap certificate=Surfshark_IKEv2 eap-methods=eap-mschapv2 \
generate-policy=port-strict mode-config=FRBD peer=FRBD \
policy-template-group=FRBD username=username
/ip ipsec policy
add dst-address=0.0.0.0/0 group=FRBD proposal=FRBD src-address=0.0.0.0/0 \
template=yes
/system logging
add topics=ipsec
