stricky
CCR1009 with 3 cAP ac
Sat Mar 11, 2023 12:20 pm
i have a problem with capsman. i've got a CCR1009 with capsman running.
i want to use 3 SSID's. Two SSID's are running. 1 Master / 1 Slave ( virtual ). When i add the second Slave, all connections where killed and then the cap will not work
RouterOS 7.8 on all Devices
Any Ideas ?
Christian
anav
Re: CCR1009 with 3 cAP ac
Sat Mar 11, 2023 2:06 pm
Simplify your setup and remove capsman.
Once you config one capac, the other two are usually almost identical. Easy Peasy and it works.
erlinden
Sat Mar 11, 2023 2:39 pm
Defnitely a misconfig, would be usefull to have an export (if you want to continu the CAPsMAN route):
/caps-man export file=anynameyoulike
From an admin perspective I would use CAPsMAN, especially on being able to monitor all wirelles devices in one place. But there are enough reasons to stick to stand alone configs.
Users browsing this forum: No registered users and 87 guests
