andzinslv
Device cannot connect specifically to Mikrotik APs
Sat Mar 11, 2023 2:20 pm
ordered Up2stream Mini V3 device and cannot connect to Mikrotik AP.
Interestingly I can connect to any other vendor APs, but tried 2 different places and setups using Mikrotik and it did not work.
This guy seems to have the same issue, but no one solved it: https://forum.arylic.com/t/unable-to-co ... ini/2752/9
Could it be caused by the device's MAC address?
What test could I run to narrow down the issue?
Thanks!
mfrommel
Re: Device cannot connect specifically to Mikrotik APs
Sun Mar 12, 2023 11:46 am
Please read this!
viewtopic.php?p=908118
You may start with "Step2"
andzinslv
Mon Mar 13, 2023 9:38 pm
Thanks for point to right direction!
Here is some additional information.
I want to connect device - up2stream mini V3 - to my home network.
Tried to do the initial setup of the device, but cannot connect to the network sometimes getting network timeout and sometimes DHCP error message.
I have tried to connect this exact device to three different networks.
It did connect successfully to one of them that was not based on Mirkotik devices.
But in both cases (my home network and lab network where Mikrotiks are used with different config) it did not connect, failing with the same massages.
My network consists of 2 Mikrotik devices.
Configurations are listed below.
HexPoe:
# mar/13/2023 21:21:23 by RouterOS 6.43.12
# software id = A1EQ-AR83
# model = 960PGS
# serial number = xxxxxx
add admin-mac=B8:69:F4:B3:A7:33 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
add disabled=no interface=ether1
add bridge=bridge comment=defconf interface=sfp1
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
/ip dhcp-server lease
add address=192.168.88.2 client-id=1:6c:3b:6b:87:82:d6 mac-address=\
    6C:3B:6B:87:82:D6 server=defconf use-src-mac=yes
add address=192.168.88.15 client-id=1:b8:27:eb:42:dc:19 mac-address=\
    B8:27:EB:42:DC:19 server=defconf use-src-mac=yes
add address=192.168.88.0/24 comment=defconf dns-server=8.8.8.8 gateway=\
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=accept chain=srcnat ipsec-policy=out,none out-interface=ether1
/system clock
set time-zone-name=Europe/Riga
/system identity
set name=MikroTik-HexPoE
/tool mac-server
/tool mac-server mac-winbox
wAP:
# mar/13/2023 21:27:08 by RouterOS 6.49.7
# software id = YKCP-2YN2
# model = RouterBOARD wAP G-5HacT2HnD
add name=bridge1
add authentication-types=wpa2-psk mode=dynamic-keys name=JenoteniSecured \
    supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country=latvia disabled=no \
    frequency=2437 mode=ap-bridge name=wlan-2G security-profile=\
    JenoteniSecured ssid=Jenoteni-2G
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=\
    20/40/80mhz-Ceee country=latvia disabled=no frequency=5260 mode=ap-bridge \
    name=wlan-5G security-profile=JenoteniSecured ssid=xxxxx
add bridge=bridge1 interface=wlan-2G
add bridge=bridge1 interface=wlan-5G
add bridge=bridge1 disabled=yes interface=all
/ip dhcp-client
add disabled=no interface=bridge1
/system clock
/system leds
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
chechito
Mon Mar 13, 2023 11:08 pm
i think will be useful to enable more extensive logging on wireless topic
/system logging
add topics=wireless
in that way you can collect info at the moment your client device try to associate with the AP and the possible reason of failing to do so
R1CH
Tue Mar 14, 2023 3:14 am
Try setting more compatible protocols instead of only n / ac. Cheap IOT chipsets sometimes don't even support 802.11n.
Ca6ko
Long time Member
Long time Member
Re: Device cannot connect specifically to Mikrotik APs  [SOLVED]
Tue Mar 14, 2023 8:31 am
Configure the wifi mode on Mikrotik as your device supports, the specification says b/g/n, so set it to 2 GHz - B/G/N
Users browsing this forum: No registered users and 58 guests
