I was expecting that the certificate generated by the command below would be renewed automatically, but that hasn't happened. Mine has just expired and I do not see any signs of incoming connections to port 80. The www and www-ssl IP services are running and port 80 is open for Let's Encrypt hosts:
Code: Select all
/certificate enable-ssl-certificate dns-name=my.domain.com
In the terminal I see that the certificate has expired (E flag). WinBox displayed it as valid until I restarted the application .
Code: Select all
> /certificate/print
Flags: K - PRIVATE-KEY; E - EXPIRED; T - TRUSTED
Columns: NAME, COMMON-NAME, SUBJECT-ALT-NAME
# NAME COMMON-NAME SUBJECT-ALT-NAME
0 T dns-nextdns-io.pem_0 USERTrust ECC Certification Authority
1 KET letsencrypt-autogen_2022-12-11T14:48:10Z <removed>.ddns.net DNS:<removed>.ddns.net
Shall I run the /certificate/enable-ssl-certificate again to remove the expired certificate and generate a new one?
