Floiran
Several Moving Bridges in one network on big area
Sun Mar 12, 2023 3:33 pm
Hello Guys,
I'm new to this forum and until now it helped me a lot.
I tried severel things but I can not create a stable network. It is more or less unstable.
Hardware:
  • Metal 52 ac on a antenna pole in the middle of the farm
  • Groove 52 on a driving machine
  • Groove 52 on a PickUp for having WiFi for mobile devices
  • Groove 52 on a Buggy for having WiFi for mobile access and a wired connection for a box pc
Picture of the area:
The Metal 52 ac is connected to a router (with DHCP server) and has access to the internet.
What is working until now:
  • Internet access from mobile devices all over the farm ( if they are within range to a Groove antenna)
  • internet access for devices connected by ethernet to the Groove 52 ac
What is not working stable:
  • Connection from a box-pc at the buggy to a device on the drving machine
  • sometimes it is working but slow and instable
Configuration:
  • Metal 52 ac:
    • Bridge Eth1 to Wlan1
    • WLan1 AP mode
    • fixed IP 192.168.2.2
  • /interface bridge
    add name=bridge1
    set [ find default-name=ether1 ] mac-address=DC:2C:6E:5E:DF:9E
    add name=WAN
    add name=LAN
    add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=------ \
        supplicant-identity="" wpa-pre-shared-key=------- \
        wpa2-pre-shared-key=--------
    /interface wireless
    set [ find default-name=wlan1 ] band=2ghz-b/g/n basic-rates-a/g=\
        6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=\
        5.5Mbps,11Mbps country=no_country_set disabled=no frequency=2412 \
        frequency-mode=superchannel installation=outdoor mode=ap-bridge \
        preamble-mode=long rate-set=configured security-profile=------- ssid=\
        ------- supported-rates-b=2Mbps,5.5Mbps,11Mbps wps-mode=disabled
    /ip hotspot profile
    add bridge=bridge1 interface=all
    add interface=bridge1 list=WAN
    add address=192.168.2.2/24 interface=ether1 network=192.168.2.0
    /ip dhcp-client
    add interface=ether1
    add address=192.168.2.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.2.2
    set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
    add distance=1 gateway=192.168.2.1
    /system clock
    set time-zone-name=America/Sao_Paulo
    /system identity
    set name="-------"
  • All Groove 52 ac
    • Bridge Eth1 to WLan1 to WLan2 (virtual)
    • WLan 1 station bridge
    • WLan 2 AP mode
    • DHCP client
    • /interface bridge
      add name=bridge1
      /interface lte apn
      /interface wireless
      set [ find default-name=wlan1 ] band=2ghz-b/g/n country=no_country_set \
          disabled=no frequency=2412 frequency-mode=superchannel mode=\
          station-bridge security-profile=------ ssid=------
      add disabled=no keepalive-frames=disabled mac-address=02:00:00:AA:00:00 \
          master-interface=wlan1 multicast-buffering=disabled name=wlan2 \
          security-profile=------ ssid=------ wds-cost-range=0 wds-default-cost=0 \
          wps-mode=disabled
      add bridge=bridge1 ingress-filtering=no interface=wlan1
      add bridge=bridge1 ingress-filtering=no interface=ether1
      add bridge=bridge1 ingress-filtering=no interface=all
      /ip settings
      set max-neighbor-entries=8192
      /ipv6 settings
      /interface ovpn-server server
      set auth=sha1,md5
      /ip dhcp-client
      /system clock
      /system identity
      set name=HBR02Polaris
I tried two different scenarios:
  1. Same SSID for the ap at the Metal 52 ac and the virtual APs
  2. SSID A at the Metal 52 ac AP and connectet all other Groove antennas by station bridge to this SSID. The virtual APs are all configured to SSID B
Option B seems to be a bit more stable. The Wife to the Metal 52 ac on the antenna pole works great. The issue I con not solve is the connection between a device at the buggy and a device at the machine. This connection is slow and connections between this devices are lost sometimes every 5 minutes and somtimes after hours. While testing these two vehicles are standing still in a distance of about 20 to 50 meters.
All antennas except the Metal on the antenna pole are moving around all the time.
Hope you can help me with this setup. I tried to search for something like this in this forum. If I have not found a relating post, but there is still one please excuse.
Thank you in advance
Florian
Edit 13.03.2023:
  • Added anonymous configuration of the antennas. Sensitive data replaced by '------'
  • Added picture
Users browsing this forum: olivier2831, Rox169 and 38 guests
