Kingberns
Priority LAN to WAN connection
Sun Mar 12, 2023 5:05 pm
Tried to search through internet but it doesn't get any solution or guide.
Is this possible in Mikrotik? want to set.up src address to priority WAN per LAN.
LAN1 Priority route ISP1
Backup route ISP2
LAN2 Priority route ISP2
Backup route ISP1
Thank you in advance
anav
Re: Priority LAN to WAN connection
Mon Mar 13, 2023 1:03 pm
EASY WAY TO DO THIS - avoids mangling
Step1 - create routes
distance=5 dst-address=0.0.0.0/0 gwy=ISP1-gatewayIP table=main check-gateway=ping
distance=10 dst-address=0.0.0.0/0 gwy=ISP2-gatewayIP table=main
From this alone, you have ALL USERS going to ISP1 and if that is not available the router will send them to ISP2.
We took advantage of distance different in routes to do this.
Step2 - Force LAN2 users out ISP2 ( add table, route and routing rule)
/routing table
add fib name=useWAN2
add distance=5 dst-address=0.0.0.0/0 gwy=ISP1-gatewayIP table=main check-gateway=ping
add distance=10 dst-address=0.0.0.0/0 gwy=ISP2-gatewayIP table=main
add dst-address=0.0.0.0/0 gwy=ISP2-gatewayIP table=useWAN2[/i]
/routing rule
add action=lookup src-address=LAN2-subnet table=useWAN2
The result is that ALL lan2 traffic will now be forced out WAN2. If WAN2 is not available the router will go to the main table for a working route and will find WAN1.
This is function of using action=lookup, if you had used action=lookup-only-in-table, there would be no option for the router to look for an alternate route.
Step3 - Consider LAn to LAn traffic.
Think about it, we are routing anything leaving LAN2 to WAN2, and that is all traffic, even that lets say heading to LAN1.
The way to ensure LAN2 to LAN2 traffic can work we need a second routing rule. Order is critical here.......
/routing rule
add action=lookup-only-in-table dst-address=LAN1-subnet table=main[/b]
Kingberns
Mon Mar 13, 2023 5:00 pm
Thank you Anav. I will try this one and revert back for the update.
broderick
Tue Mar 14, 2023 2:09 pm
@anav
I tested your setup in a virtual environment and it seems to be working as expected. Very good!
one question:
this rule needs no distance setup? Just the default 1?
anav
Tue Mar 14, 2023 5:40 pm
Correct, distance has no bearing on that non main table entry.
broderick
Wed Mar 15, 2023 9:32 am
oh, interesting. I didn't know that distance doesn't affect a non-main table entry.
Thank you
Users browsing this forum: STMT and 116 guests
