Bernhard
SSH-Session to Cisco not possible (ROS v7.8) - no matching key algorithm
Mon Mar 13, 2023 12:46 pm
Dear Gurus,
i try to connect to a cisco Catalyst 9200 (Cisco IOS XE Software, Version 17.03.04b) via Tools -> Telenet -> SSH which leads to an immidiate disconnect.
I enabled the /ip/ssh strong-crypto to get over problems with MAC algorithmus. That is working now - they do hmac-sha2-256
But then I stumble across the kex algorithmus:
  • Mikrotik offers: curve25519-sha256,diffie-hellman-group-exchange-sha256,ext-info-c
  • Cisco offers: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group14-sha1
So we have no match.
Is there a possibility to get connected?
Thanks a lot,
Bernhard
mkx
Re: SSH-Session to Cisco not possible (ROS v7.8) - no matching key algorithm
Mon Mar 13, 2023 2:34 pm
Yes ... using a full-blown ssh client which in fact still implements outdated algorithms but doesn't have them enabled by default.
Bernhard
Tue Mar 14, 2023 4:48 pm
What I really wanted to know - is there a possibility to get connected to the cisco switch using a MikroTik router?
Is there a full-blown ssh client for MikroTik Routerboard?
mkx
Tue Mar 14, 2023 6:29 pm
It seems it's not possible using built-in ssh client at the moment.
Not really. Some Mikrotik routers, running v7 (e.g. 7.8) can run containers ... and you could include full-blown ssh client in a container. Not exactly light-weight solution ... if I would need connectivity and none of linux machines running all the time, I'd go with raspberry pi ...
Bernhard
Tue Mar 14, 2023 7:01 pm
OK - thanks. Doesn't make me happy.
eworm
Thu Mar 16, 2023 9:18 am
You want the network traffic to originate from the Mikrotik device (from Cisco device's point of view), but you do this from your workstation, no? You can use ssh jump host functionality for this. Search for these keywords for details.
The call would look something like this:
ssh -J admin@mikrotik -o enable-legacy-option -o enable-deprecated-option admin@cisco
Works well will Mikrotik device as jump host.
Users browsing this forum: mbovenka, rplant and 130 guests
