Ramirocuei
problem to get system identity
Mon Mar 13, 2023 3:23 pm
I cant seem to find out why I'm not getting the value of system identity when I execute this command, in turn I get a blank response:
/system identity get name
[EMPTY]
if I use system identity print, I get:
ROS version: 6.49.7
I just want to get the identity of the router on a variable to add it to a mail subject but it's not working...
:set mikrotikName [/system identity get name]
Thank you in advance!
Regards
Ramiro
karlisi
Re: problem to get system identity
Mon Mar 13, 2023 3:58 pm
rextended
Mon Mar 13, 2023 6:07 pm
What you give with this command on terminal?
/system identity export
You have ALREADY defined the mikrotikName valiable with ":global mikrotikName" or ":local mikrotikName" ???
Show all the script, probably the error is on another place.
Users browsing this forum: No registered users and 27 guests
