s4nguine
Unable to ping VLAN default gateway after changing PVID
Tue Mar 14, 2023 9:53 pm
Hello everyone,
First of all I'm kind of new to networking stuff and this is my first Mikrotik device so forgive me stupid questions.
I have CRS326 switch which is connected to OpenWRT router.
Currently I created lab environment in GNS3 which pretty much reflects what I have in home:
OpenWRT VLANs with DHCP servers are created, for testing VLAN110 with address 192.168.10.1/24
Trunk port would be 'e0' so I assigned it as tagged port.
Mikrotik is connected to router on ether2 port, configuration looks like this:
add ingress-filtering=no name=bridge1 vlan-filtering=yes
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] disable-running-check=no
set [ find default-name=ether3 ] disable-running-check=no
set [ find default-name=ether4 ] disable-running-check=no
set [ find default-name=ether5 ] disable-running-check=no
set [ find default-name=ether6 ] disable-running-check=no
set [ find default-name=ether7 ] disable-running-check=no
set [ find default-name=ether8 ] disable-running-check=no
/port
set 0 name=serial0
add bridge=bridge1 interface=ether8 pvid=110
/interface bridge vlan
add bridge=bridge1 tagged=ether2 untagged=ether8 vlan-ids=110
/ip dhcp-client
add interface=bridge1
I want PC1 which is connected to switch on ether8 port to get address from VLAN 110, but as soon as I change port ether8 VLAN to 110 I'm unable to ping default gateway address of VLAN which is 192.168.10.1 (I can ping it from Mikrotik console so it should be accessible).
I really hope you can help me figure this out.
Users browsing this forum: adimihaix, Bing [Bot], GoogleOther [Bot], sebi099 and 164 guests
