honzam
CubeSA 60Pro ac - kernel failure
Tue Mar 14, 2023 11:05 pm
CubeSA 60Pro ac with ROS 7.8 (and olders) still kernel failure. Reported many times to support.
It is not a piece defect, the problem occurs in several places....
Do you have the same problem?
Dish
Re: CubeSA 60Pro ac - kernel failure
Fri Mar 17, 2023 12:30 pm
i have the same problem..............
ROS: 7.7 / 7.8
Steve
Dish
Mon Mar 20, 2023 1:13 pm
the problem always occurs in heavy rain when the 60 GHZ link fails because the RX level is too low ( ca. -70 dbm ).
When the weather is nice (good RX level), the link is stable........
Steve
Dish
Thu Apr 13, 2023 8:55 am
any info from mikrotik support about the problem................??
In heavy rain, the problem of reboots occurs regularly.
Steve
normis
Thu Apr 13, 2023 9:08 am
There is a similar issue fixed in v7.10, so try the beta once it comes out.
Dish
Wed Aug 30, 2023 8:13 pm
the same problem with ROS v7.11.............
in heavy rain with bad RX level kernel error with reboot. the 5 GHZ backup doesn't help either :?
DenisPDA
Thu Aug 31, 2023 11:04 am
Why so many problems with the new Cube series ????
1 CubeSA 60Pro ac - kernel failure
2 CubeSA 60Pro WATER DANGER viewtopic.php?t=189614
3 CubeSA 60Pro ac: 60Ghz clients flapping viewtopic.php?t=188600
Dish
Sat Sep 09, 2023 8:33 am
any comment from Mikrotik about the kernel error ?
honzam
Sat Sep 09, 2023 9:41 am
Since version 7.10 I have not observed any kernel failure.
If this happens to you, you need to generate supout.rif after kernel failure and send it to support@mikrotik.com
rplant
Sat Sep 09, 2023 1:32 pm
This might be part of it.
carl0s
Wed Sep 13, 2023 12:20 am
I have a pair of these that I am intending to put up. I have two buildings just about 10 meters apart - opposites sides of the road, yet they are linked through leased-lines and VPN through the internet :shock:
Anyway, I did do my usual Mikrotik research (search forums..) and I think the Clients Flapping problem sounds like it is only with PtMP. So for PtP (1 device to 1 device) that should be OK.
For the water ingress problems, well, I have seen those pictures, so I will open mine up and use some gasket maker or similar on them.
Users browsing this forum: No registered users and 75 guests
