I have an RB750GL configured in a very simple setup using a Bridge. I was wandering if there would be a noticeable performance increase by switching it to /switch configuration, I haven't played with /switch before and if I have to go down that route I would like some advise on what to do.
Here is the configuration. Basically it serves out vlan50 and another router (RB4011) connects to it as a dhcp client with no default route.
Cheers
Code: Select all
add ingress-filtering=no name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan50 vlan-id=50
add name=vlan50pool ranges=192.168.50.2-192.168.50.254
add address-pool=vlan50pool interface=vlan50 name=server1
add bridge=bridge1 interface=ether2 pvid=50
add bridge=bridge1 interface=ether3 pvid=50
add bridge=bridge1 interface=ether4 pvid=50
add bridge=bridge1 interface=ether5 pvid=50
add bridge=bridge1 interface=vlan50 pvid=50
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether1 untagged=ether2,ether3,ether4,ether5 \
vlan-ids=50
add address=192.168.50.1/24 interface=vlan50 network=192.168.50.0
/ip dhcp-client
# DHCP client can not run on slave or passthrough interface!
add interface=ether1
add address=192.168.50.0/24 gateway=192.168.50.1
add action=fasttrack-connection chain=input hw-offload=yes
/system clock
set time-zone-name=Australia/Sydney
