Vasko
ROS 7.x - Surfshark ikev2 DNS resolve issue?
Wed Mar 15, 2023 4:55 pm
Yesterday i upgraded my router from ac3 to ax3 and from ROS 6.49 to 7.8.
After i finished setting up everything i brought up the ikev2 for the Surfshark which i am using home. I noticed that the IPSEC was getting terminated after 7-10s after being established.
I ran a debug and i found out that the DNS resolving address is constantly changing. Tested it on old router as well and there it works fine with the older ROS.
I configured the IP address which is written below surfshark server instead of DNS on peer settings and then started working normally.
Do you know if this is a bug of new ROS versions? Or if there is a workaround?
You can find the debug attached.
Thank you.
Users browsing this forum: adrianh, Google [Bot], Semrush [Bot] and 132 guests
