ioannistsi
Connect Router's Through 3rd VPN
Thu Mar 16, 2023 1:38 pm
Hello, i have 2 routers that connect to each other succesfully to o Master Router with VPN
Slave Router 1 (172.16.20.0/24) --> Master Router (172.16.88.0/24)
Slave Router 2 (172.16.30.0/24) --> Master Router (172.16.88.0/24)
What is the routing config at the table to connect Slave Router 1 & 2 through Master Router?
k6ccc
Re: Connect Router's Through 3rd VPN
Thu Mar 16, 2023 4:20 pm
Far more information needed. What routers and what software versions? Please post the configurations of all three. To export and paste your configuration (and I'm assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) "/export hide-sensitive file=any-filename-you-wish". Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Suggest you then open the .rsc file in your favorite text editor and redact any sensitive information. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
ioannistsi
Thu Mar 16, 2023 7:47 pm
For an unknown reason i can not post all 3 codes in one post so...
Main Router's:
# mar/16/2023 19:21:21 by RouterOS 6.49.7
# software id = C3FF-C97T
# model = RB952Ui-5ac2nD
# serial number = 9E940A5314CE
add admin-mac=74:4D:28:4E:B3:FB auto-mac=no comment=defconf mtu=1480 name=\
    bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=2641022808 user=\
    oaktpl@otenet.gr
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed mode=dynamic-keys name=COSMOTE-103006 \
    supplicant-identity=""
    management-protection=allowed mode=dynamic-keys name="JohnTsi's" \
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
    20/40mhz-XX country=no_country_set disabled=no distance=indoors \
    frequency=auto frequency-mode=manual-txpower installation=indoor mode=\
    ap-bridge name="2.4 GHz" security-profile=COSMOTE-103006 ssid=\
    COSMOTE-103006 station-roaming=enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac \
    channel-width=20/40/80mhz-XXXX country=no_country_set disabled=no \
    distance=indoors frequency=5240 frequency-mode=manual-txpower \
    installation=indoor mode=ap-bridge name=5GHz security-profile="JohnTsi's" \
    ssid="John Tsi's" station-roaming=enabled wireless-protocol=802.11
add name=dhcp_pool5 ranges=192.168.77.1-192.168.77.253
add name=dhcp_pool6 ranges=192.168.99.1-192.168.99.253
add address-pool=default-dhcp disabled=no interface=bridge lease-time=1h1m \
    name=defconf
add address-pool=dhcp_pool6 interface="2.4 GHz" name=dhcp1
/interface sstp-client
add connect-to=a36a0a242d38.sn.mynetname.net:543 disabled=no name=Kastraki \
    profile=default-encryption user="G Parodos"
add connect-to=e7e60fe06290.sn.mynetname.net:343 disabled=no name=Kremasta \
/queue simple
add burst-limit=0/80M burst-threshold=0/75M burst-time=0s/1m disabled=yes \
    max-limit=0/75M name="Cosmote Tv Priority" queue=default/default target=\
    bridge
/system logging action
add email-to=-@gmail.com name=email target=email
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=5GHz
add bridge=bridge interface=ether2
add bridge=bridge interface="2.4 GHz"
/interface l2tp-server server
set default-profile=default keepalive-timeout=60
add disabled=yes interface="2.4 GHz" list=LAN
/interface sstp-server server
set enabled=yes
add address=192.168.88.254/24 comment=defconf interface=bridge network=\
    192.168.88.0
add address=192.168.1.2/24 comment="Cosmote 2641022808 Router" interface=\
    ether1 network=192.168.1.0
add address=192.168.99.254/24 disabled=yes interface="2.4 GHz" network=\
    192.168.99.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=ether2
add address=192.168.77.0/24 dns-server=192.168.77.254 gateway=192.168.77.254
add address=192.168.88.0/24 comment=defconf dns-server=\
    192.168.88.254,1.0.0.1,1.1.1.1 domain="John Tsi Network" gateway=\
    192.168.88.254
add address=192.168.99.0/24 dns-server=192.168.99.254,1.0.0.1,1.1.1.1 domain=\
    "Cosmote TV Network" gateway=192.168.99.254
set servers=192.168.88.254,1.1.1.1,1.0.0.1,192.168.99.254
/ip dns static
add address=104.16.248.249 disabled=yes name=cloudflare-dns.com
add address=104.16.249.249 disabled=yes name=cloudflare-dns.com
add address=172.16.20.90 name=kastraki.nvr
add address=172.16.10.90 name=kremasta.nvr
    established,related,untracked
    invalid
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes
    connection-state=invalid
add action=drop chain=input comment="Secure TCP DNS" dst-port=53 \
    in-interface=ether1 protocol=tcp
add action=fasttrack-connection chain=forward comment="Fasttarck DNS" \
    disabled=yes dst-port=53 protocol=tcp
add action=fasttrack-connection chain=forward comment="Fasttarck DNS UDP" \
    disabled=yes dst-port=53 protocol=udp
add action=drop chain=input comment="Secure UDP DNS" dst-port=53 \
    in-interface=ether1 protocol=udp
    ipsec-policy=out,none out-interface=2641022808
add comment="Kremasta CCTV" distance=1 dst-address=172.16.10.0/24 gateway=\
    10.10.88.100,10.10.88.10
add comment="Kastraki CCTV" distance=1 dst-address=172.16.20.0/24 gateway=\
    10.10.88.2,10.10.88.12
add comment="Stratos CCTV" distance=1 dst-address=172.16.30.0/24 gateway=\
    10.10.88.30
add comment="Kastraki 4G Router" distance=1 dst-address=192.168.2.1/32 \
    gateway=10.10.88.2
add comment="Kremasta LAN" distance=1 dst-address=192.168.6.0/24 gateway=\
    10.10.88.10,10.10.88.1 scope=10
add comment="Kremasta 4G Router" distance=1 dst-address=192.168.15.1/32 \
    gateway=10.10.88.100,10.10.88.10
add comment="Kremasta LAN" disabled=yes distance=1 dst-address=\
    192.168.80.0/24 gateway=10.10.90.10 scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip traffic-flow
set cache-entries=128k interfaces=bridge
/ppp secret
add local-address=10.10.88.3 name=Stratos profile=default-encryption \
    remote-address=10.10.88.30 service=sstp
add local-address=10.10.88.1 name=Kremasta profile=default-encryption \
    remote-address=10.10.88.10 service=sstp
add local-address=10.10.88.120 name=Kastraki profile=default-encryption \
    remote-address=10.10.88.12 service=sstp
/system clock
set time-zone-name=Europe/Athens
/system identity
set name="Davaki 12"
/system logging
set 0 topics=info,!ppp
add action=email topics=critical
add action=disk topics=info,!ppp,!wireless,!dhcp
add action=disk topics=warning
add action=disk topics=critical
add action=disk topics=error
add action=email disabled=yes topics=sstp,ppp,info,account
/system ntp client
set enabled=yes primary-ntp=91.217.155.60 secondary-ntp=162.159.200.1
/system ntp server
set broadcast=yes broadcast-addresses=192.168.88.254 enabled=yes
/system routerboard settings
set auto-upgrade=yes
/system scheduler
add disabled=yes interval=1d name="Email Logs" on-event="/log print file=logs\
    \r\
    \ndelay 10\r\
    \n/tool e-mail send to=\"ioannistsi@gmail.com\" subject=\"\$[/system ident\
    ity get name]  logs\" \\\r\
    \nbody=\"\$[/system clock get date] log file\" file=logs.txt" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=apr/03/2020 start-time=23:59:00
/tool e-mail
set address=smtp.gmail.com from="G Parodos Mikrotik" port=587 start-tls=yes \
    user=g.parodos.router@gmail.com
/tool mac-server
/tool mac-server mac-winbox
ioannistsi
Slave Router 1
# mar/16/2023 19:21:29 by RouterOS 6.49.7
# software id = SXY6-NFUI
# model = RB760iGS
# serial number = A36A0A242D38
add name=CCTV
add interface=ether1 name=2641098287 use-peer-dns=yes user=\
    kastrakihps@tellas.gr
add name=MGM
/interface lte apn
set [ find default=yes ] apn=vpn-internet name="Cosmote Wireless Internet"
add disabled=no interface=CCTV name="CCTV "
add name="CCTV Pool" ranges=172.16.20.1-172.16.20.253
/port
set 0 name=serial0
add connect-to=9e940a5314ce.sn.mynetname.net disabled=no name=Davaki profile=\
    default-encryption user=Kastraki
    profile=default-encryption user=Kastraki
set 1 disk-lines-per-file=4000
add email-start-tls=yes email-to=-@dei.com.gr name=email target=\
    email
/user group
set write policy="local,telnet,ssh,reboot,read,write,test,winbox,password,web,\
    sniff,sensitive,api,romon,dude,tikapp,!ftp,!policy"
/dude
set enabled=yes
add bridge=CCTV interface=ether2
add bridge=CCTV interface=ether5
set discover-interface-list=MGM
set enabled=yes use-ipsec=required
add interface=ether5 list=MGM
set default-profile=default-encryption enabled=yes port=543
add address=172.16.20.254/24 interface=CCTV network=172.16.20.0
/ip cloud
/ip dhcp-client
add default-route-distance=2 disabled=no interface=ether4 use-peer-ntp=no
/ip dhcp-server lease
add address=172.16.20.253 client-id=1:98:da:c4:18:a7:a9 comment=\
    "TP-LINK PoE Switch" mac-address=98:DA:C4:18:A7:A9 server="CCTV "
add address=172.16.20.180 client-id=1:14:d6:4d:9:25:34 comment=\
    "WS-KAS19 100Mbps" disabled=yes mac-address=00:11:6B:F0:0E:B9 server=\
    "CCTV "
add address=172.16.20.90 client-id=1:68:6d:bc:da:a1:b7 comment=NVR \
    mac-address=68:6D:BC:DA:A1:B7 server="CCTV "
add address=172.16.20.1 client-id=1:84:9a:40:c2:50:75 comment="PULH Car" \
    mac-address=84:9A:40:C2:50:75 server="CCTV "
add address=172.16.20.3 client-id=1:98:df:82:5f:3c:14 comment=PLATEIA \
    mac-address=98:DF:82:5F:3C:14 server="CCTV "
add address=172.16.20.4 client-id=1:98:df:82:5f:3c:10 comment=\
    "EISODOS KTIRIOU" mac-address=98:DF:82:5F:3C:10 server="CCTV "
add address=172.16.20.7 client-id=1:98:df:82:5f:3c:8 comment=YDROLHPSIA \
    mac-address=98:DF:82:5F:3C:08 server="CCTV "
add address=172.16.20.5 client-id=1:98:df:82:51:a2:c2 comment=\
    "Y/S PROS ZERVA" mac-address=98:DF:82:51:A2:C2 server="CCTV "
add address=172.16.20.6 client-id=1:98:df:82:5f:3c:a comment=\
    "Y/S PROS AGOGOUS" mac-address=98:DF:82:5F:3C:0A server="CCTV "
add address=172.16.20.8 client-id=1:98:df:82:51:a2:c1 comment=YPERXEILISTHS \
    mac-address=98:DF:82:51:A2:C1 server="CCTV "
add address=172.16.20.100 client-id=1:b4:a3:82:ed:85:c9 comment=Joystick \
    mac-address=B4:A3:82:ED:85:C9 server="CCTV "
add address=172.16.20.170 client-id=1:c4:ad:34:28:e1:32 comment=\
    "mAP Lite Wireless" mac-address=C4:AD:34:28:E1:32 server="CCTV "
add address=172.16.20.190 client-id=1:24:77:3:ed:93:a8 comment=\
    "Dell-Laptop Wireless" mac-address=24:77:03:ED:93:A8 server="CCTV "
add address=172.16.20.140 client-id=1:0:23:24:44:4e:7e comment=\
    "PC Fulakiou Pulhs" mac-address=00:23:24:44:4E:7E server="CCTV "
add address=172.16.20.200 client-id=1:e0:db:55:e0:49:78 comment=\
    "Dell-Laptop Ethernet" mac-address=E0:DB:55:E0:49:78 server="CCTV "
add address=172.16.20.9 client-id=1:98:df:82:3e:fa:f8 comment="KTIRIO PISO" \
    mac-address=98:DF:82:3E:FA:F8 server="CCTV "
add address=172.16.20.175 client-id=1:c4:ad:34:28:e1:30 comment=\
    "mAP Lite Ethernet" mac-address=C4:AD:34:28:E1:30 server="CCTV "
add address=172.16.20.185 client-id=1:ac:5f:3e:69:f0:7f comment=\
    Samsung-Galaxy-S7 mac-address=AC:5F:3E:69:F0:7F server="CCTV "
add address=172.16.20.160 client-id=1:50:3e:aa:1f:f5:18 comment=\
    "WS-KAS19 1Gbps" disabled=yes mac-address=50:3E:AA:1F:F5:18 server=\
    "CCTV "
add address=172.16.20.11 client-id=1:98:df:82:3e:fc:fa comment="APOTHIKI B'" \
    mac-address=98:DF:82:3E:FC:FA server="CCTV "
add address=172.16.20.10 client-id=1:84:9a:40:b4:49:fe comment="APOTHIKI A'" \
    mac-address=84:9A:40:B4:49:FE server="CCTV "
add address=172.16.20.12 client-id=1:98:df:82:5f:3c:b comment=BIOLOGIKOS \
    mac-address=98:DF:82:5F:3C:0B server="CCTV "
add address=172.16.20.13 client-id=1:98:df:82:3e:fb:77 comment="GEFYRA ZERVA" \
    mac-address=98:DF:82:3E:FB:77 server="CCTV "
add address=172.16.20.110 client-id=1:0:80:a3:b5:d7:d0 comment=\
    "Temperature Monitor" mac-address=00:80:A3:B5:D7:D0 server="CCTV "
add address=172.16.20.195 client-id=1:8:0:27:09:21:D8 comment="CCTV VM" \
    mac-address=08:00:27:45:63:56 server="CCTV "
add address=172.16.20.120 client-id=1:0:20:85:de:fe:ef comment=\
    "UPS Server Room" mac-address=00:20:85:DE:FE:EF server="CCTV "
add address=172.16.20.122 client-id=1:0:20:85:de:fe:f6 comment=\
    "UPS Kastraki Control" mac-address=00:20:85:DE:FE:F6 server="CCTV "
add address=172.16.20.150 client-id=1:0:e0:4c:0:f4:bb comment=KASTRAKI_AMD \
    mac-address=00:E0:4C:00:F4:BB server="CCTV "
add address=172.16.20.2 client-id=1:80:7c:62:ff:b1:dc comment=STADIA \
    mac-address=80:7C:62:FF:B1:DC server="CCTV "
add address=172.16.20.0/24 dns-server=172.16.20.254,1.1.1.3,1.0.0.3 domain=\
    "Kastraki CCTV" gateway=172.16.20.254
set allow-remote-requests=yes servers=172.16.20.254,1.0.0.3,1.1.1.3
/ip dns static
add address=172.16.30.90 name=stratos.nvr
/ip firewall address-list
add address=172.16.20.1-172.168.20.140 disabled=yes list="Safire Equipment"
add address=192.168.88.0/24 list="Familiar Subnet's"
add address=172.16.20.150-172.16.20.200 list="Permissive IP's"
add action=accept chain=forward dst-address=192.168.88.0/24 src-address=\
    172.16.20.0/24
add action=accept chain=forward dst-address=172.16.10.0/24 src-address=\
    172.16.20.0/24
add action=fasttrack-connection chain=forward dst-port=53 protocol=tcp
add action=fasttrack-connection chain=forward dst-port=53 protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp
add action=accept chain=input comment="Access from G Parodos" dst-port=8291 \
    protocol=tcp src-address=192.168.88.0/24
    protocol=tcp src-address=172.16.10.93
add action=accept chain=forward comment="Access Cam from G Parodos" \
    dst-address=192.168.88.0/24 src-address=172.16.20.1-172.16.20.89
add action=drop chain=forward comment="Safire Equipment except NVR" \
    dst-address=0.0.0.0/0 src-address=172.16.20.1-172.16.20.89
add action=drop chain=forward comment="Filakio Client PC" dst-address=\
    0.0.0.0/0 src-address=172.16.20.140
add action=accept chain=forward comment="Safire Equipment except NVR" \
    dst-address=0.0.0.0/0 src-address-list="Permissive IP's"
    dst-address=0.0.0.0/0 src-address=172.16.20.90-172.16.20.139 \
add action=accept chain=input dst-port=8291 protocol=tcp src-address-list=\
    "Permissive IP's"
add action=drop chain=input dst-port=8291 protocol=tcp src-address-list=\
    !knock-final
add action=add-src-to-address-list address-list=knock1 address-list-timeout=\
    10s chain=input dst-port=@@@@ protocol=tcp
add action=add-src-to-address-list address-list=knock2 address-list-timeout=\
    10s chain=input dst-port=@@@@ protocol=tcp src-address-list=knock1
add action=add-src-to-address-list address-list=knock-final \
    address-list-timeout=1d chain=input dst-port=@@@@ protocol=tcp \
    src-address-list=knock2
# 2641098287 not ready
add action=masquerade chain=srcnat out-interface=2641098287
add action=masquerade chain=srcnat out-interface=ether4
add check-gateway=ping comment=ADSL distance=3 gateway=2641098287
add check-gateway=ping comment=4G disabled=yes distance=1 gateway=ether4
add check-gateway=ping comment="Netwatch ADSL" disabled=yes distance=1 \
    dst-address=8.8.4.4/32 gateway=2641098287
add check-gateway=ping comment="Netwatch 4G" disabled=yes distance=1 \
    dst-address=8.8.8.8/32 gateway=ether4
add distance=1 dst-address=172.16.10.0/24 gateway=10.10.20.1
add distance=2 dst-address=172.16.10.0/24 gateway=10.10.10.10
add distance=1 dst-address=172.16.30.0/24 gateway=10.10.30.20
add distance=2 dst-address=172.16.30.0/24 gateway=10.10.20.1
add distance=1 dst-address=192.168.15.0/24 gateway=10.10.10.10,10.10.20.1
add distance=1 dst-address=192.168.88.0/24 gateway=10.10.88.20
add distance=2 dst-address=192.168.88.0/24 gateway=10.10.88.120
/ip service
/ppp secret
add local-address=10.10.88.2 name="G Parodos" profile=default-encryption \
    remote-address=10.10.88.20 service=sstp
add local-address=10.10.10.1 name=Kremasta profile=default-encryption \
    remote-address=10.10.10.10 service=sstp
add local-address=10.10.30.2 name=Stratos profile=default-encryption \
    remote-address=10.10.30.20 service=sstp
add disabled=yes local-address=10.10.15.2 name=Teltonika profile=\
    default-encryption remote-address=10.10.15.20 service=sstp
add disabled=yes local-address=10.10.150.1 name=Papakammenos profile=\
    default-encryption remote-address=10.10.150.10 service=l2tp
/system clock
/system identity
set name="Kastraki Router"
/system logging
add action=email disabled=yes topics=dhcp,info
add action=email disabled=yes topics=info,interface
add action=email disabled=yes topics=info,system
/system ntp client
set enabled=yes primary-ntp=194.177.210.54 secondary-ntp=176.119.210.243
/system ntp server
set broadcast=yes broadcast-addresses=172.16.20.254 enabled=yes
/tool e-mail
set address=smtp.mail.yahoo.com from=kastraki.router@yahoo.com port=465 \
    start-tls=tls-only user=-@yahoo.com
/tool netwatch
add disabled=yes down-script="/ip route disable [/ip route find comment=4G]" \
    host=8.8.8.8 interval=30s timeout=3s up-script=\
    "/ip route enable [/ip route find comment=4G]"
add disabled=yes down-script=\
    "/ip route disable [/ip route find comment=ADSL]" host=8.8.4.4 timeout=3s \
    up-script="/ip route enable [/ip route find comment=ADSL]"
ioannistsi
Thu Mar 16, 2023 7:48 pm
Slave router 2
# mar/16/2023 19:20:54 by RouterOS 6.49.7
# software id = 1K8F-T4GM
# model = RB760iGS
# serial number = A36A0A636D0E
add name=CCTV
add add-default-route=yes default-route-distance=3 disabled=no interface=\
    ether1 name=2641071181 use-peer-dns=yes user=ojh5ff@otenet.gr
add disabled=no interface=CCTV name="Stratos CCTV"
add name=CCTV ranges=172.16.30.1-172.16.30.253
/port
set 0 name=serial0
add connect-to=9e940a5314ce.sn.mynetname.net disabled=no name="G Parodos" \
    profile=default-encryption user=Stratos
add connect-to=a36a0a242d38.sn.mynetname.net:543 name=Kastraki profile=\
add email-to=-@dei.com.gr name=email target=email
/user group
set read policy="local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,s\
    ensitive,api,romon,dude,tikapp,!ftp,!write,!policy"
add address=172.16.30.254/24 interface=CCTV network=172.16.30.0
/ip cloud
/ip dhcp-client
add default-route-distance=2 disabled=no interface=ether3 use-peer-ntp=no
add address=172.16.30.5 client-id=1:98:df:82:5f:3c:e comment="STRATOS 2" \
    mac-address=98:DF:82:5F:3C:0E server="Stratos CCTV"
add address=172.16.30.2 client-id=1:84:9a:40:b4:49:70 comment=STADIA \
    mac-address=84:9A:40:B4:49:70 server="Stratos CCTV"
add address=172.16.30.1 client-id=1:98:df:82:5f:3c:9 comment=PULH \
    mac-address=98:DF:82:5F:3C:09 server="Stratos CCTV"
add address=172.16.30.90 client-id=1:90:2:a9:da:bc:79 comment="STRATOS NVR" \
    mac-address=90:02:A9:DA:BC:79 server="Stratos CCTV"
add address=172.16.30.100 client-id=1:b4:a3:82:ed:85:c7 comment=JOYSTICK \
    mac-address=B4:A3:82:ED:85:C7 server="Stratos CCTV"
add address=172.16.30.3 client-id=1:98:df:82:5f:3c:16 comment=YPOSTATHMOS \
    mac-address=98:DF:82:5F:3C:16 server="Stratos CCTV"
add address=172.16.30.28 client-id=1:0:23:24:43:b1:84 comment=\
    "CLIENT PC CONTROL" mac-address=00:23:24:43:B1:84 server="Stratos CCTV"
add address=172.16.30.6 client-id=1:98:df:82:5f:3c:4 comment=\
    "FRAGMA STRATOS 2" mac-address=98:DF:82:5F:3C:04 server="Stratos CCTV"
add address=172.16.30.4 client-id=1:98:df:82:5f:3c:c comment=YPERXEILISTIS \
    mac-address=98:DF:82:5F:3C:0C server="Stratos CCTV"
add address=172.16.30.40 client-id=1:c4:ad:34:28:e1:30 mac-address=\
    C4:AD:34:28:E1:30 server="Stratos CCTV"
add address=172.16.30.50 client-id=1:24:77:3:ed:93:a8 mac-address=\
    24:77:03:ED:93:A8 server="Stratos CCTV"
add address=172.16.30.70 client-id=1:c4:ad:34:28:e1:32 mac-address=\
    C4:AD:34:28:E1:32 server="Stratos CCTV"
add address=172.16.30.60 client-id=1:e0:db:55:e0:49:78 mac-address=\
    E0:DB:55:E0:49:78 server="Stratos CCTV"
add address=172.16.30.20 client-id=1:0:23:24:43:b2:7c comment=\
    "CLIENT PC FYLAKIO" mac-address=00:23:24:43:B2:7C server="Stratos CCTV"
add address=172.16.30.30 client-id=1:0:20:85:de:fe:f6 comment=\
    "Stratos CCTV UPS" disabled=yes mac-address=00:20:85:DE:FE:F6 server=\
    "Stratos CCTV"
add address=172.16.30.80 client-id=1:7e:e4:a3:59:57:83 mac-address=\
    7E:E4:A3:59:57:83 server="Stratos CCTV"
add address=172.16.30.0/24 dns-server=1.1.1.3,1.0.0.3 domain="Stratos CCTV" \
    gateway=172.16.30.254
set servers=172.16.30.254,1.0.0.3,1.1.1.3
add address=172.16.30.7-172.16.30.29 list="Rest Network Equipment"
add address=172.16.30.1-172.16.30.6 list="Safire IP Cameras"
add address=192.168.88.0/24 list="Familar Subnet's"
add address=172.16.20.0/24 list="Familar Subnet's"
add action=accept chain=forward dst-address-list="Familar Subnet's" \
    src-address-list="Safire IP Cameras"
    src-address-list="Rest Network Equipment"
add action=drop chain=forward dst-address=0.0.0.0/0 src-address-list=\
    "Safire IP Cameras"
add action=drop chain=input dst-port=53 protocol=tcp
add action=drop chain=input dst-port=53 protocol=udp
add action=masquerade chain=srcnat out-interface=2641071181
add action=masquerade chain=srcnat out-interface=ether3
add distance=1 dst-address=10.10.150.10/32 gateway=Kastraki
add distance=1 dst-address=10.10.200.10/32 gateway=Kremasta
add distance=1 dst-address=172.16.10.0/24 gateway=10.10.30.1
add distance=1 dst-address=172.16.20.0/24 gateway=10.10.30.2 scope=10
add distance=1 dst-address=192.168.3.1/32 gateway=2641071181
add distance=1 dst-address=192.168.88.0/24 gateway=10.10.88.3 pref-src=\
    0.0.0.0
/ip service
/system clock
/system identity
set name="Stratos Router"
/system logging
add action=email topics=interface
add action=email disabled=yes topics=system
/system ntp client
/system ntp server
set broadcast=yes broadcast-addresses=172.16.30.254 enabled=yes
/tool e-mail
set address=smtp.mail.yahoo.com from=stratos.nvr@yahoo.com port=465 \
Users browsing this forum: No registered users and 44 guests
