nike78
Capsman Problems
Fri Mar 17, 2023 6:18 pm
Hallo,
I have a mikrotik capsman with two cap that works perfect.
Today I added 3 more Cap and I have a problem...in 2G network (for the 3 new cap) Nothing is working, I do not recive IP, internet is not working.
Please hellp.
See attatch.
Thanks.
nike78
Re: Capsman Problems
Fri Mar 17, 2023 6:22 pm
My Capsman is:
And the remote CAps are ( the 2 cap that are working are in red circle)
whatever
Re: Capsman Problems  [SOLVED]
Fri Mar 17, 2023 8:40 pm
Check all mac addresses of your bridges and wifi interfaces. They must be unique, you probably have duplicates.
Ca6ko
Long time Member
Long time Member
Fri Mar 17, 2023 9:36 pm
nike78
Fri Mar 17, 2023 11:44 pm
That was the problem...but this kind of problems should never exist.
Thanks for your help.
erlinden
Sat Mar 18, 2023 10:39 am
Any professional networking device will give you the possibility to change MAC addresses. It's up to the user to have it changed...or not.
gotsprings
Sat Mar 18, 2023 12:13 pm
I did a couple hundred caps... I never had duplicate MACs detail me.
Ca6ko
Long time Member
Long time Member
Sun Mar 19, 2023 5:34 pm
You have never restored a backup to another device, as the author did.
bpwl
Sun Mar 19, 2023 6:50 pm
Backup is known to copy MAC addresses form the backup device to the restored device ... but I see them also in export (.rsc) files with bridges.
gotsprings
Sun Mar 19, 2023 7:35 pm
You are pretty close to right.
After the few times I have restored a config like that... I went back in and defaulted the MAC addresses.
Users browsing this forum: No registered users and 60 guests
