Overhead8101
No access to internal network from OpenVPN clients
Fri Mar 17, 2023 7:05 pm
Hello, my OpenVPN server is at 192.168.0.161. The OpenVPN clients cannot seem to reach any addresses on my LAN. Any advice is greatly appreciated.
Here is my config:
# mar/17/2023 12:47:13 by RouterOS 6.49.6
# software id = W0T5-PBGI
# model = RouterBOARD 750 r2
# serial number = 67D306B9A00A
add admin-mac=6C:3B:6B:C6:43:18 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.10-192.168.3.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=192.168.0.1/22 comment=defconf interface=bridge network=\
    192.168.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.0.0/22 comment=defconf dns-server=192.168.0.5,192.168.0.3 \
    gateway=192.168.0.1 netmask=22
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
/ip firewall address-list
add action=drop chain=input comment="Block IP cameras from WAN access" \
    src-address=192.168.1.121
    established,related,untracked
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    in-interface-list=!LAN
    invalid
    connection-state=invalid
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=\
    192.168.0.0/22 out-interface=bridge src-address=192.168.0.0/22
add action=dst-nat chain=dstnat comment="openvpn port forward" \
    dst-address-list=WAN-IP dst-port=19847 protocol=udp to-addresses=\
    192.168.0.161 to-ports=19847
add disabled=yes distance=1 gateway=192.168.10.1
add check-gateway=ping distance=1 dst-address=192.168.229.0/24 gateway=\
    192.168.0.161 pref-src=192.168.0.161
/system clock
set time-zone-name=America/Toronto
/tool mac-server
/tool mac-server mac-winbox
anav
Re: No access to internal network from OpenVPN clients
Fri Mar 17, 2023 11:11 pm
Yeah, use wireguard, faster, easier better supported by RoS.
Overhead8101
Sat Mar 18, 2023 12:31 am
Thanks for your reply. Surely there must be a way to make it work. But I am a novice at RouterOS. I have never had issues with OpenWRT and EdgeOS allowing OpenVPN clients to access the internal network.
bpwl
Sat Mar 18, 2023 1:52 am
OpenVPN has modes TUN (routed tunnel or L3) and TAP (bridged or L2).
In Mikrotik these are called "ip mode" and "ethernet mode"
Seen here: http://ict.smkn1bawang.sch.id/2021/08/3 ... l-eng-sub/
Overhead8101
Sat Mar 18, 2023 9:14 am
Apologies all, I should mention that OpenVPN is on a virtual server (192.168.0.161) inside an ESXI host. I am quite sure the OpenVPN server is setup correctly because it was working fine before moving from EdgeRouter to Mikrotik Hex Lite.
Thanks for all the help from you experienced ninjas!
anav
Sat Mar 18, 2023 3:18 pm
Hahaha, like I said, wireguard is included on RoS, no need for any additional complexity............ can lead a horse to water........
Users browsing this forum: Bing [Bot], jamesperks and 122 guests
