eldite
CRS309-1G-8S
Sat Mar 18, 2023 12:40 am
I've got a CRS309-1G-8S and it works nicely. I am using it to route, and the connection is PPPoE. It uses about 75-80% CPU at 1Gbps. So I don't think it will do much better. It has twice the resources of the CRS125, and the performance is only marginally better. I also can't overclock it, which can be done with the CRS125.
The setup is as simple as it gets. All ports bridged, PPPoE client connected to the bridge. The routes for the PPPoE connection don't show as HW Offloaded. This page doesn't clearly state no HW Offloading for PPPoE, but that seems to be the case: https://help.mikrotik.com/docs/display/ ... Offloading
I'm happy with it, but are there any secret enhancements that can be done to squeeze a bit more out of it?
Cheers
sirbryan
Re: CRS309-1G-8S
Sat Mar 18, 2023 5:58 am
No, you're essentially hitting the maximums of that CPU, since PPPoE is CPU-bound.
Depending on what your Internet connection is, you could front it with something like an RB5009.
netflow
Re: CRS309-1G-8S
Wed Mar 29, 2023 9:54 pm
Well it is meant to be primarily a switch. Still it has no problem to do NAT at 1gbps with CPU at around 1%, so it might work for you to try this suggestion made by ChatGPT, let me know if works and I will reward ChatGPT for finding out ;-)
/interface ethernet switch settings
set switch-all-packets=
forward-encrypted,forward-decrypted,forward-pppoe-chap,forward-pppoe-pap
mbovenka
Re: CRS309-1G-8S
Thu Mar 30, 2023 8:05 am
That's because NAT can be HW offloaded. PPPoE can't.
Users browsing this forum: Bing [Bot], ShindigNZ and 93 guests
