I am not very familiar with MikroTik, so I don't know if the information here is enough for debugging. If not, I will be happy to provide the necessary information.
I have a CCR2004-1G-12S+2XS which I want to put WAN-side direct to the Internet. For this I have another router, on which a static IPv4 network is configured.
If I connect the WAN interface (sfp28-1) directly to the other router using DAC cable, the connection works.
If I use the same cable and connect the MikroTik router via a switch, it does not receive a link.
The ports on the switch are all in the same VLAN. Other firewalls are connected to the switch, which works without any problems.
Here is also my config file:
Code: Select all
# mar/19/2023 13:21:47 by RouterOS 7.8
# software id = 88LN-20R4
# model = CCR2004-1G-12S+2XS
# serial number = XXX
set [ find default-name=ether1 ] name="ether1[MGMT]"
set [ find default-name=sfp28-1 ] name="sfp28-1[WAN]"
set [ find default-name=sfp28-2 ] name="sfp28-2[LAN]"
/port
set 0 name=serial0
set 1 name=serial1
/ipv6 settings
set disable-ipv6=yes
add address=10.21.31.1/24 comment=defconf interface="ether1[MGMT]" network=\
10.21.31.0
add address=XXX.XXX.226.115/29 interface="sfp28-1[WAN]" network=XXX.XXX.226.112
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set rtsp disabled=no
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=10.21.31.0/24,10.10.10.0/24
set api-ssl disabled=yes
/system identity
set name=ROU-01
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.ch.pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Am I missing something?
Thank you and best regards
