oguruma
WiFI VlAN Tag with upstream switch
Sun Mar 19, 2023 11:02 pm
I have a few Mikrotik cAP/wAPs connected to a Cisco Catalyst managed switch, which is connected to a PfSense router.
What I want to do is create a VLAN for my IOT devices, which will be blocked from going out the WAN on the router (I don't trust cheap Chinese electronics).
I've found enough write-ups to figure out the Mikrotik WiFi configuration part, and I've created a IOT-no-internet interface on the router, but what do I need to do configure the Cisco switch in the middle?
I have 192.168.0.1/16 as the LAN, 10.1.1.1/24 as a DMZ, and 10.4.1.1/24 as the IOT-no-internet.
The switch, as it is now, just has all of the interfaces bridged in the single "default" VLAN.
anav
Re: WiFI VlAN Tag with upstream switch
Mon Mar 20, 2023 1:43 am
You need to do this on the pfsense router and cisco switch so wrong forum.
mkx
Mon Mar 20, 2023 10:48 am
@anav, I thought you'd come up with correct answer on this one ... which is: replace Cisco with a CRS3xx switch :wink:
anav
Mon Mar 20, 2023 12:46 pm
I'm not paid enough for such novel thinking, however if MT added a zerotrust cloudflare options package for all MT devices, I would probably be inspired to recommend MT switches. ;-)
Users browsing this forum: Bing [Bot], DanMos79, grusu, Philippe57, rb9999, svh79 and 111 guests
