pandreozzi
Hardware Offload or Not Hardware Offload
Mon Mar 20, 2023 6:41 pm
I am working with a CRS 326 version 6.48.6 long term.
On this device I have some critical traffic (EF and AF) that needs to be prioritized on the egress ports.
Hardware offload is turned on for all the ports.
Should I disable hardware offload and use the QOS via connection mark/packet mark and Q-Tree.
I am not looking for line speed I am looking to prioritize DSCP 46,30 and 26 which I have a script for and have added to the routers.
My only concern is that this is a single CPU appliance and sending everything to the CPU may effect performance.
Thanks for your input.
Paul
rextended
Re: Hardware Offload or Not Hardware Offload
Mon Mar 20, 2023 7:22 pm
If you use the device for mark the connections, you drop the total bandwidth because is a switch, not a router,
all traffic pass inside CPU instead pass only to switch chip...
Only 1.3Gbps max
Users browsing this forum: gindich, m3das, nescafe2002, Semrush [Bot], Strange0ne and 124 guests
