porch
Plugging laptop into VLAN port, blocks bridge interface of other router.
Tue Mar 21, 2023 4:06 am
I have a strange one. This is with two 2011UiAS-2HnD.
LivingRoom 192.168.1.24 (spf1) -> (spf1) BatteryRoom 192.168.1.25
The BatteryRoom router is doing most of the work. Duel WAN, VLANS, VPNs, etc. The LivingRoom router is working as a WIFI access point, and some of the ports are assigned VLANs, but that is it.
When I plug a laptop into port 5 of LivingRoom, it is on VLAN3, gets a DHCP address from the VLAN3 (192.168.3.0/24) pool (on BatteryRoom router), and everything just works fine.
When I plug the same laptop into port 2 of LivingRoom, it is on VLAN4, gets a DHCP address from the VLAN4 (192.168.4.0/24) pool (on BatteryRoom router), and it can access the internet, but within seconds, nothing else can ping BatteryRoom at 192.168.1.25. Everything else goes down. I can ping things in the 192.168.1.0/24 subnet, even stuff connected to the BatteryRoom router, but I can't ping the router itself. BatteryRoom router itself at 192.168.1.24 can't ping BatteryRoom at 192.168.1.25.
Unplugging the laptop from port 2, and after 3 minutes or so, I can ping 192.168.1.25 again and everything returns to normal.
I don't see a difference between VLAN3 and 4. It's like an MAC address collision, but I checked the ARP table and the MAC address on the laptop, and it is not the same as anything on the 2 routers.
Anyone see something like this before?
Sanitized configs attached.
anav
Re: Plugging laptop into VLAN port, blocks bridge interface of other router.
Tue Mar 21, 2023 2:03 pm
When you decide to have one bridge, and all subnets on vlans, I can help.
porch
Wed Mar 22, 2023 2:06 am
That is the end goal.
At the moment, I need to replace a switch with a managed one for the 192.168.2.0/24 subnet and make that subnet a real VLAN, and also workout how I can assign a wifi interface to that VLAN2. But first, I am trying to make VLANs work as expected.
Little steps.
tdw
Wed Mar 22, 2023 3:04 am
Have you at some point imported a .backup from one of the Mikrotiks to the other? The mac-address=E4:8D:8C:7D:AF:xx settings under /interface ethernet suggest this, in which case you may have duplicate MACs which confuse the bridge/switch forwarding tables.
There are also potential issues on devices using ports on multiple switch chips which are members of the same bridge, see https://help.mikrotik.com/docs/display/ ... witchchips
porch
Wed Mar 22, 2023 3:43 am
I don't ever recall importing a backup from one to the other. But at some point,I did notice the the bridges had the same mac address and I had to change one.
At the moment, I am keeping the VLANS on switch 1, but I will look into that when I expand.
tdw
Wed Mar 22, 2023 4:21 am
The addresses would initially be different so they must have been transferred across at some point. Use /interface ethernet [find] reset-mac-address to restore the inbuilt MAC addresses on the ethernet interfaces, other references (bridge admin, secondary wifi, L2 tunnel interfaces) have to be adjusted manually.
porch
Wed Mar 22, 2023 11:11 pm
Thank you. I reset all the Ethernet macs, removed the bridge admin mac, and gave the secondary wifi a different mac, and my problem went away.
That was a strange one I didn't think about.
Thanks for the help.
Users browsing this forum: nescafe2002 and 88 guests
