Johannes33
suggestion of AP
Wed Mar 22, 2023 12:14 pm
My home wifi ap just broke down.
It was a unifi ap ac lite.
I was not totally happy with the ap, it was a little weak and did not cover good in my house.
I live in a stand alone wooden house with a concrete blocked basement and has little wifi interference from houses around.
The house is 8x12 meter (26x39 feet) big and the wifi needs to mainly penetrate wood walls and a wooden floor down to the basement.
We are 5 in the house so 5 wifi devices might be used at the same time.
I have a 100/100Mbit fiber connection and I'm using an mikrotik 3011 router with gigabit connections.
Rox169
Re: suggestion of AP
Wed Mar 22, 2023 12:28 pm
buy hAP AX2 or hAP AX3 if you need USB.
Johannes33
Wed Mar 22, 2023 9:26 pm
I have seen a lot of complaints about the speed and range of mikrotik wifi equiptments.
Is it not better to use tp-link or asus?
What about the coverage in a house with walls, how many meters/feet is it's range for decent wifi for streaming netflix and playing low graphics games (roblox)?
I will probably buy the mikrotik hAP ax2 since I really like mirkotik anyway :). is there a good setup guide? I have never set up a mikrotik wifi gear.
