karaYusuf
Why can I not install rose-storage package
Wed Mar 22, 2023 6:14 pm
Hello Guys,
As I said in the title: I try to install the rose-storage package on my hapac2 with v7.8 but it just do not get installed.
At first I downloaded the extra packages with the right architecture and droped it after that in the files in winbox.
Then I just clicked on reboot. After the reboot there is no rose-storage in the package list.
I also have already container and zerotier installed on that router.
So does someone know why I can not install the rose-storage package?
I appreciate any help :)
holvoetn
Re: Why can I not install rose-storage package
Wed Mar 22, 2023 8:52 pm
Isn't there a command line step where you should press reset when activating ?
Or was that for container ? Not sure anymore...
massinia
Wed Mar 22, 2023 9:03 pm
Have you checked the available space in flash?
I have the same packages installed on a hap ac2 and there is no space to install ROSE.
Amm0
Wed Mar 22, 2023 9:07 pm
The logs will show stuff if it tried and failed, so if you see anything there, that might give you a clue on what's going on.
But I'd imagine you cannot have a lot of users files for sure. Whether even that leaves enough space, I dunno...
Amm0
Wed Mar 22, 2023 9:10 pm
It's container that need the /system/device-mode change with the hard/physical reboot (e.g. to confirm you're not remotely doing it). ROSE doesn't need that, or at least it didn't for me on other devices.
SuperMarioSF
Sun Apr 02, 2023 8:24 pm
I'm having exactly the problem as yours.
I have a CCR2004-1G-2XS-PCIe, which just upgraded to RouterOS 7.8-stable. I'm trying to install rose-storage and dude. I installed them as usual, and log says "installed", but actually there is no new packages installed at all, and Package section also confirmed that. I have installed ZeroTier package before the upgrade, it was 7.4rc2, and it was installed successfully.
I have tried upgraded RouterBOARD bootloader firmware to 7.8 as well but no luck there. I have tired install the package individually, but none of them installed successfully.
btw I have created support ticket in Mikrotik support with supout.rif attached, hopefully they can spot the problem.
Users browsing this forum: DNAT, maigonis, Renfrew and 109 guests
