aseques
Mysterious reset on a CSR112
Wed Mar 22, 2023 7:18 pm
We have a lot of CSR112 deployed on field, only authorized technicians have access to the routers. Still one of those routers yesterday cease to work and after checking it's back to de default configuration (no pasword)
On the logs there's only a message saying "Starting_defconf_script_" so it seems that the config was reseted. So two questions come to my mind:
  • Apart from the reset button are there any other ways to phisically reset the router? I haven't found any on the forums.
  • Is there any evidence left after the reset that might throw some light into what happened, I haven't yet reseted the router just in case
NOTE: I'm aware of the protect boot functionality but so far we haven't considered it necessary.
Kanta
Re: Mysterious reset on a CSR112
Wed Mar 22, 2023 11:21 pm
CRS112-8P-4S-IN ?
Mine have a weird issue where they stop switching randomly, if I disable HW switching it starts working over the CPU. If I enable HW switching on bride port back it stops. Only a reboot helps. But none of them reset themselves.
rextended
Thu Mar 23, 2023 12:02 am
When the device start to do that, often has flash broken...
aseques
Thu Mar 23, 2023 10:58 am
Ok, that might be an explanation, so maybe I should open an RMA if the device it's in warranty, Is there any way to check the flash health so I can provide some evidence on the ticket? I searched but only found about checking the disks attached.
Regards
andkar
Thu Mar 23, 2023 12:19 pm
system resource/print
Look for "bad-blocks" value.
AidanAus
Mon Apr 03, 2023 8:33 am
To continue with this line of thought, can you please try netinstalling the device as well?
https://help.mikrotik.com/docs/display/ROS/Netinstall
Users browsing this forum: torogicorp and 43 guests
