blank85za
Constant disconnect routerboard wifi client
Thu Mar 23, 2023 3:27 pm
Hello everyone.
I have a Mikrotik used as a gateway for my fibre. In my room outside the house I have another Mikrotik which is a Wifi client of the Gateway.
I set it up like so:
viewtopic.php?t=171313
also tried this:
https://mikrotrik.com/how-to-setup-mikr ... ater-mode/
Same issue on both, I will lose connection every 30 seconds consistently.
Reply from 8.8.8.8: bytes=32 time=22ms TTL=52
Reply from 8.8.8.8: bytes=32 time=26ms TTL=52
Reply from 8.8.8.8: bytes=32 time=23ms TTL=52
Reply from 8.8.8.8: bytes=32 time=24ms TTL=52
Reply from 8.8.8.8: bytes=32 time=21ms TTL=52
Reply from 8.8.8.8: bytes=32 time=25ms TTL=52
Reply from 8.8.8.8: bytes=32 time=93ms TTL=52
Reply from 8.8.8.8: bytes=32 time=213ms TTL=52
Reply from 8.8.8.8: bytes=32 time=282ms TTL=52
Reply from 8.8.8.8: bytes=32 time=855ms TTL=52
Request timed out.
Reply from 8.8.8.8: bytes=32 time=33ms TTL=52
Reply from 8.8.8.8: bytes=32 time=32ms TTL=52
Reply from 8.8.8.8: bytes=32 time=29ms TTL=52
Reply from 8.8.8.8: bytes=32 time=125ms TTL=52
Reply from 8.8.8.8: bytes=32 time=47ms TTL=52
Reply from 8.8.8.8: bytes=32 time=155ms TTL=52
Reply from 8.8.8.8: bytes=32 time=905ms TTL=52
Reply from 8.8.8.8: bytes=32 time=454ms TTL=52
Reply from 8.8.8.8: bytes=32 time=1038ms TTL=52
Request timed out.
Reply from 8.8.8.8: bytes=32 time=28ms TTL=52
Reply from 8.8.8.8: bytes=32 time=136ms TTL=52
Reply from 8.8.8.8: bytes=32 time=193ms TTL=52
Reply from 8.8.8.8: bytes=32 time=269ms TTL=52
Reply from 8.8.8.8: bytes=32 time=340ms TTL=52
Reply from 8.8.8.8: bytes=32 time=408ms TTL=52
Reply from 8.8.8.8: bytes=32 time=479ms TTL=52
Reply from 8.8.8.8: bytes=32 time=40ms TTL=52
Request timed out.
Reply from 8.8.8.8: bytes=32 time=300ms TTL=52
Reply from 8.8.8.8: bytes=32 time=259ms TTL=52
Reply from 8.8.8.8: bytes=32 time=27ms TTL=52
Reply from 8.8.8.8: bytes=32 time=31ms TTL=52
Reply from 8.8.8.8: bytes=32 time=442ms TTL=52
Reply from 8.8.8.8: bytes=32 time=493ms TTL=52
Reply from 8.8.8.8: bytes=32 time=79ms TTL=52
Reply from 8.8.8.8: bytes=32 time=145ms TTL=52
Reply from 8.8.8.8: bytes=32 time=235ms TTL=52
Reply from 8.8.8.8: bytes=32 time=293ms TTL=52
Reply from 8.8.8.8: bytes=32 time=37ms TTL=52
Like clockwork every 30 or so seconds the ping shoots up and / or disconnects.
I have wlan1 on 20mhz / 2412.
I had this working perfectly with the mikrotik gateway and a Tp-Link flashed with OPENWRT. The TP-link died and I replaced it with a HAPac2 but this issue is killing me.
blank85za
Re: Constant disconnect routerboard wifi client
Fri Mar 24, 2023 12:05 am
I used this method:
(with Winbox starting from stock configuration):
1. Connect to a LAN port of the RB2011 with cable
2. Exclude the Wi-Fi interface from the bridge - Bridge -> Ports -> Delete the Wi-Fi interface
3. Include the Ether1 interface in the bridge - Bridge - Ports -> Open ether2 -> Copy -> Change the interface in the new dialog to ether 1 -> OK
4. Adjust which is the WAN port - Interfaces -> Interface list - WAN -> wlan1
5. Connect the Wi-Fi interface as a client to the Wi-Fi network of Home WiFi router - Wireless -> WiFi interfaces -> wlan1 -> Scan -> find the WiFi network and press Connect
6. Adjust the security settings of the WiFi client - Wireless -> Security Profiles -> default -> Mode: dynamic keys; Authentication Types WPA/WPA2 PSK (or other, depending on the security settings of the Home WiFi router)
If everything is OK with the security settings the RB2011 will connect to the home router
7. Enable the DHCP client of the RB2011 on the WiFi interface - IP -> DHCP client -> Change ether1 to wlan1
And now I still get the ping spikes but no timeouts.
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=22ms TTL=51
Reply from 8.8.8.8: bytes=32 time=23ms TTL=51
Reply from 8.8.8.8: bytes=32 time=24ms TTL=51
Reply from 8.8.8.8: bytes=32 time=21ms TTL=51
Reply from 8.8.8.8: bytes=32 time=30ms TTL=51
Reply from 8.8.8.8: bytes=32 time=26ms TTL=51
Reply from 8.8.8.8: bytes=32 time=427ms TTL=51
Reply from 8.8.8.8: bytes=32 time=491ms TTL=51
Reply from 8.8.8.8: bytes=32 time=25ms TTL=51
Reply from 8.8.8.8: bytes=32 time=89ms TTL=51
Reply from 8.8.8.8: bytes=32 time=154ms TTL=51
Reply from 8.8.8.8: bytes=32 time=221ms TTL=51
Reply from 8.8.8.8: bytes=32 time=287ms TTL=51
Reply from 8.8.8.8: bytes=32 time=34ms TTL=51
Reply from 8.8.8.8: bytes=32 time=42ms TTL=51
Reply from 8.8.8.8: bytes=32 time=195ms TTL=51
Reply from 8.8.8.8: bytes=32 time=262ms TTL=51
Reply from 8.8.8.8: bytes=32 time=326ms TTL=51
Reply from 8.8.8.8: bytes=32 time=393ms TTL=51
Reply from 8.8.8.8: bytes=32 time=460ms TTL=51
Reply from 8.8.8.8: bytes=32 time=514ms TTL=51
Reply from 8.8.8.8: bytes=32 time=1595ms TTL=51
Reply from 8.8.8.8: bytes=32 time=44ms TTL=51
Reply from 8.8.8.8: bytes=32 time=40ms TTL=51
Reply from 8.8.8.8: bytes=32 time=476ms TTL=51
Reply from 8.8.8.8: bytes=32 time=71ms TTL=51
Reply from 8.8.8.8: bytes=32 time=128ms TTL=51
Reply from 8.8.8.8: bytes=32 time=263ms TTL=51
Reply from 8.8.8.8: bytes=32 time=333ms TTL=51
Reply from 8.8.8.8: bytes=32 time=35ms TTL=51
Reply from 8.8.8.8: bytes=32 time=27ms TTL=51
Reply from 8.8.8.8: bytes=32 time=225ms TTL=51
Reply from 8.8.8.8: bytes=32 time=317ms TTL=51
Reply from 8.8.8.8: bytes=32 time=896ms TTL=51
Reply from 8.8.8.8: bytes=32 time=957ms TTL=51
Reply from 8.8.8.8: bytes=32 time=500ms TTL=51
Reply from 8.8.8.8: bytes=32 time=97ms TTL=51
blank85za
Fri Mar 24, 2023 3:21 pm
I just went ahead and had a cable installed from the house to the outside room.
pe1chl
Fri Mar 24, 2023 5:02 pm
That is always the best solution!
WiFi can work, but it often is erratic. Without knowing model numbers and configuration there is little that can be said about it.
dipomm
Sat Mar 25, 2023 7:00 am
Munchkin cats are short on legs and big on personality. Learn more about this incredibly cute one-of-a-kind cat breed. The munchkin cat has no problem getting around the same as its longer-limbed feline friends. https://catsbuz.com/munchkin-cat/
gotsprings
Sun Mar 26, 2023 12:05 am
Wireless wire Cube has been a solid bridge solution for me.
But when I go outside and back in... I prefer not using copper.
Users browsing this forum: No registered users and 38 guests
