rikpal
Mikrotik Router configuration - Blocking Inter-VLAN
Thu Mar 23, 2023 7:13 pm
Good morning,
I'm configuring a new mikrotik router (CCR2216) to replace my current one from Draytek (Vigor3910).
I have some doubts about firewall configuration. I've read carefully several times forum discussions and this guide: viewtopic.php?t=180838
my need is to keep completely isolated 4 VLANs I've (i searched a lot about the subject 'block inter-vlan routing in the forum).
I struggled to do it, but at the and I was able to make it working, also if I still have some doubts. In practice I was able to separate the vlans only if I use the IP filter chain=input, despite in several discussions I've clearly seen examples using chain=forward to block the inter-vlan routing end keep them completely isolated.
here my config. Is there something wrong I've done?
thank in advance you for your help and suggestions.
add action=accept chain=input comment="accept established,related,untracked" \
add action=drop chain=input comment="drop invalid" connection-state=invalid
"allow VLAN 50 only (inter-vlan is blocked)" dst-address=10.10.50.0/24 \
src-address=10.10.50.0/24
"allow VLAN 100 only (inter-vlan is blocked)" dst-address=10.10.100.0/24 \
src-address=10.10.100.0/24
"allow MANAGEMENT VLAN only (inter-vlan is blocked)" dst-address=\
10.10.99.0/24 src-address=10.10.99.0/24
"allow GUEST VLAN only (inter-vlan is blocked)" dst-address=\
192.168.0.0/24 src-address=192.168.0.0/24
add action=drop chain=input comment="block everything else"
add action=fasttrack-connection chain=forward comment=\
"fast-track for established,related" connection-state=established,related \
hw-offload=yes
add action=accept chain=forward comment="accept established,related" \
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="allow internet traffic (all vlans)" \
in-interface=all-vlan out-interface-list=WAN
add action=drop chain=forward comment="drop access to clients behind NAT from \
WAN - drops all new connection attempts from the WAN port to our LAN netwo\
rk (unless DstNat is used). Without this rule, if an attacker knows or gue\
sses your local subnet, he/she can establish connections directly to local\
\_hosts and cause a security threat." connection-nat-state=!dstnat \
connection-state=new in-interface-list=WAN log=yes log-prefix=\
"*** INVALID ACCESS TO CLIENTS BEHIND NAT FROM WAN ***"
add action=drop chain=forward comment="block everything else"
Users browsing this forum: Bing [Bot], maldridge, raiser and 120 guests
