collateral
WAN/LAN traffic interaction on HAP AX^3 HW acceleration issue
Thu Mar 23, 2023 9:29 pm
I recently bought an HAP AX^3 for my personal use at home.
I am new to Mikrotik devices, but I am not new to networks and network switches.
Few day after the initial configuration I finally found some time to do some performance testing with my new equipment, and I noticed a weird behavior:
If I have a TCP stream running between two machines in my LAN (red arrow in my graph), my upload throughput towards the Internet (green arrow) is only 200 Mb/s instead of the normal 1 Gb/s, the download speed is unaffected.
If I just send from a computer in my LAN towards the Internet using TCP, with no other significant traffic on my LAN I can saturate my 1 Gb/s connection.
If I try to stress the switch with just local traffic it can bridge 2 full-duplex TCP streams without any issues.
The problem seems to happen only when I have both local and external traffic.
In order to exclude any possible misbehavior of the NAT, I tried to replicate the setup using another port and assigning it to a different subnet. The router shows the same behavior, as soon as there is bridged and routed traffic the upload of the routed stream (green arrow) is limited to 200 Mb/s.
If I disable the HW offloading of L2 traffic the problem goes away, so this seems to be related to the HW offloading in the switch ASIC.
This is the configuration I am currently running:
add admin-mac=48:A9:8A:0C:DF:02 auto-mac=no comment=defconf name=bridge protocol-mode=none
add name=guest_traffic
set [ find default-name=ether5 ] mac-address=00:1E:80:A8:91:90 name=eth_wan
set [ find default-name=ether1 ] poe-out=off
/interface wifiwave2
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz configuration.country=France .mode=ap .ssid=frafla_network disabled=no name=wifi \
    security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.country=France .mode=ap .ssid=frafla_network_5G disabled=no name=wifi_5g \
add channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz configuration.country=France .mode=ap .ssid=frafla_guest disabled=no mac-address=4A:A9:8A:0C:DF:07 master-interface=\
    wifi name=wifi_guest security.authentication-types=wpa2-psk,wpa3-psk
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="guest internet only traffic" name=GUEST
add name=default-dhcp ranges=192.168.0.2-192.168.0.254
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add address-pool=default-dhcp interface=bridge name=dhcp
add address-pool=dhcp_pool1 interface=guest_traffic name=guest_dhcp
add bridge=bridge comment=defconf interface=wifi_5g
add bridge=guest_traffic interface=wifi_guest
add bridge=bridge interface=ether1
/ipv6 settings
set max-neighbor-entries=15360
add interface=eth_wan list=WAN
add interface=guest_traffic list=GUEST
add address=192.168.0.1/24 comment=defconf interface=bridge network=192.168.0.0
add address=192.168.10.1/24 interface=guest_traffic network=192.168.10.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.0.10 mac-address=00:11:32:BE:DE:73 server=dhcp
add address=192.168.0.4 mac-address=DC:A6:32:D8:6F:04 server=dhcp
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.1 gateway=192.168.0.1
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=192.168.10.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
/ip firewall address-list
add address=0.0.0.0/8 comment="defconf: RFC6890" list=no_forward_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=no_forward_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=no_forward_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=no_forward_ipv4
add address=127.0.0.0/8 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=198.51.100.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=203.0.113.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=240.0.0.0/4 comment="defconf: RFC6890 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6890 benchmark" list=not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=192.168.0.0/24 comment="LAN addresses" list=lan
add address=192.168.10.0/24 comment="Gues LAN addresses" list=guest_lan
add address=192.168.0.0/24 comment="All LAN addresses" list=local
add address=192.168.10.0/24 comment="All LAN addresses" list=local
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="Guest network can only access the Internet" in-interface-list=GUEST out-interface-list=!WAN
add action=drop chain=forward comment="defconf: drop bad forward IPs" src-address-list=no_forward_ipv4
add action=drop chain=forward comment="defconf: drop bad forward IPs" dst-address-list=no_forward_ipv4
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface-list=WAN src-address-list=local
add action=dst-nat chain=dstnat comment="NAS/Synology Drive Server" dst-port=6690 in-interface-list=WAN protocol=tcp to-addresses=192.168.0.10 to-ports=6690
add action=dst-nat chain=dstnat comment=NAS/openvpn dst-port=1194 in-interface-list=WAN protocol=udp to-addresses=192.168.0.10 to-ports=1194
add action=dst-nat chain=dstnat comment=NAS/ssh dst-port=50314 in-interface-list=WAN protocol=tcp to-addresses=192.168.0.10 to-ports=22
add action=dst-nat chain=dstnat comment="NAS/hyper backup vault" dst-port=6281 in-interface-list=WAN protocol=tcp to-addresses=192.168.0.10 to-ports=6281
add action=dst-nat chain=dstnat comment=NAS/managment dst-port=5314 in-interface-list=WAN protocol=tcp to-addresses=192.168.0.10 to-ports=5314
/ip firewall raw
add action=accept chain=prerouting comment="defconf: enable for transparent firewall" disabled=yes
add action=accept chain=prerouting comment="defconf: accept DHCP discover" dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting comment="defconf: drop bogon IP's" src-address-list=bad_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" dst-address-list=bad_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" src-address-list=bad_src_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="defconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment="defconf: drop forward to local lan from WAN" dst-address-list=local in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop LAN traffic if not from lan address range" in-interface-list=LAN src-address-list=!lan
add action=drop chain=prerouting comment="defconf: drop Guest LAN traffic if not from guest lan address range" in-interface-list=GUEST src-address-list=!guest_lan
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 protocol=udp
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" jump-target=bad_tcp protocol=tcp
add action=accept chain=prerouting comment="defconf: accept everything else from LAN" in-interface-list=LAN
add action=accept chain=prerouting comment="defconf: accept everything else from GUEST LAN" in-interface-list=GUEST
add action=accept chain=prerouting comment="defconf: accept everything else from WAN" in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop the rest"
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="defconf: TCP port 0 drop" port=0 protocol=tcp
add action=accept chain=icmp4 comment="defconf: echo reply" icmp-options=0:0 limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: net unreachable" icmp-options=3:0 protocol=icmp
add action=accept chain=icmp4 comment="defconf: host unreachable" icmp-options=3:1 protocol=icmp
add action=accept chain=icmp4 comment="defconf: protocol unreachable" icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 comment="defconf: port unreachable" icmp-options=3:3 protocol=icmp
add action=accept chain=icmp4 comment="defconf: fragmentation needed" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 comment="defconf: echo" icmp-options=8:0 limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: time exceeded " icmp-options=11:0-255 protocol=icmp
add action=drop chain=icmp4 comment="defconf: drop other icmp" protocol=icmp
/ip ipsec policy
set 0 disabled=yes
/ip ssh
set strong-crypto=yes
/ip tftp
add disabled=yes real-filename=MikroTik-20230305-1857.backup req-filename=MikroTik-20230305-1857.backup
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Paris
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.fr.pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool graphing
set page-refresh=60
/tool graphing interface
add disabled=yes
/tool mac-server
/tool mac-server mac-winbox
/tool traffic-monitor
add disabled=yes interface=eth_wan name=traf1
Am I missing something in the configuration or there is a problem with the HW offloading?
Thank you.
collateral
Re: WAN/LAN traffic interaction on HAP AX^3
Thu Mar 30, 2023 4:11 pm
I post an update.
Since the 06/03/23 the official documentation as been updated, and and this sentence has been added.
Currently, HW offloaded bridge support for the IPQ-PPE switch chip is still a work in progress. We recommend using, the default, non-HW offloaded bridge (enabled RSTP).
I guess that they are working on it. In any case it is a bit sad to release a product before it is ready, especially because there is no mention of this in the product page and I purchased it before update of the documentation.
I hope the will fix it soon.
Users browsing this forum: almdandi, holvoetn, jfh, mkx, panayi, pellerb and 60 guests
