mambotech
Exclude ip address from firewall rules
Sat Oct 27, 2007 4:19 pm
I want to exclude an ipaddress from some of my firewall rules but I am not sure how to do this.
Thanks Mark
jonashi
Re: Exclude ip address from firewall rules
Sat Oct 27, 2007 5:22 pm
there are many ways. One of them is:
You can do it simply in winbox by check box by one click
ip->firewall->general ->add
in src address or dst addres (that depends on rule you are about to use) click on small box located on the left of address field, then appears exclamation mark (!) in there. This does mean that rule will work only with ip addressess whose do not satisfy that condition, in this specific case for example you want bypass the rule for a specific IP address lets say 10.0.0.1, then you should have that address in rule and exclamation mark before it in the box. That does mean IF IT IS NOT 10.0.0.1 THEN DO THE RULE. In case 10.0.0.1 rule is bypassed.
Hope that helps
Patrik
Chupaka
Sat Oct 27, 2007 11:16 pm
or just add a rule on the top of chain, with address=<your_address> and action = accept
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
saintofinternet
Forum Veteran
Forum Veteran
Tue Nov 19, 2013 2:13 pm
i have a similar problem
i have a firewall working with a WEB PROXY working at the same time. All traffic directed to port 6565. The IP Pool is 192.168.1.150-192.168.1.250
i also have a VPN where the IP pool is 10.10.1.1-10.10.1.20
now i just want to exclude all VPN users from the firewall and webproxy and allow them full access.
i just cannot figure out how to achieve this.
by professionals, for professionals....
Don't forget to give KARMA!!!
Chupaka
Tue Nov 19, 2013 2:52 pm
both in Filter and NAT :)
saintofinternet
Forum Veteran
Forum Veteran
Sun Apr 27, 2014 5:30 am
thanx !!! :-)
actually adding the rule in the NAT table only worked...
the same rule in Firewall table does not make any difference...
sorry for the very late reply.
Users browsing this forum: jahidhk, jweek, sindy and 108 guests
