benoitc
dont-fragment option in vxlan
Sat Mar 25, 2023 4:21 pm
With this option can we imagine to setup a vxlan over the internet with a higher MTU ? Would it ref-fragment it when it comes?
Amm0
Re: dont-fragment option in vxlan
Sat Mar 25, 2023 5:24 pm
Haven't specifically tested it. But my thought be you'd only use don't fragment if you knew for sure you had a higher MTU available over the entire path & wanted it to fail if not.
If your WAN is 1500, VXLAN has to be 1450 (or lower if full path is lower) if you want to use dont-fragment.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], elvtechnology and 80 guests
