flnslrbit
Need help getting port forwarding to work
Sat Mar 25, 2023 5:48 pm
I am using a Mikrotik Groove to extend wifi coverage to an RV. I have a raspberry PI in the vehicle I would like to be able to connect to from my home network (when the RV is connected to our home network).
The groove is setup in CPE mode and is currently connected to my home network. I configured CPE and portforwarding using the Quick Set menu.
Using random subnets as examples
Home network: 10.0.0.0/24
Groove Wifi (WAN): 10.0.0.80
Groove LAN/NAT: 10.0.80.0/24 (Groove LAN IP/gateway is 10.0.80.1)
Raspberry PI: 10.0.80.80
I am able to access the webfig fine from my home network, but not able to ping or SSH into the raspberry PI from the home network. If I ping or SSH from RouterOS directly, I can access the RaspberryPI fine, so its definitely configured correctly, but as soon as I try to ping or SSH from outside of the 10.0.80.0 network, it cannot connect at all.
ssh -p 2222 user@10.0.0.80 just results in connection timeout
RouterOS config is as follows:
[admin@MikroTik] > export
# mar/25/2023 08:42:02 by RouterOS 7.8
# software id = M4F6-SY6L
# model = RBGrooveGA-52HPacn
add admin-mac=XXXX auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac disabled=no ssid=XXXX wireless-protocol=nv2-nstreme-802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
/ip hotspot profile
add name=dhcp ranges=10.0.80.100-10.0.80.200
add address-pool=dhcp interface=bridgeLocal name=dhcp1
add bridge=bridgeLocal comment=defconf interface=ether1
add interface=wlan1 list=WAN
add interface=bridgeLocal list=LAN
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal interfaces=wlan1
add address=10.0.80.1/24 interface=bridgeLocal network=10.0.80.0
/ip dhcp-client
add comment=defconf interface=bridgeLocal
add interface=wlan1
/ip dhcp-server lease
add address=10.0.80.80 client-id=XXXX mac-address=XXXX server=dhcp1
add address=0.0.0.0/24 dns-server=0.0.0.0 gateway=0.0.0.0 netmask=24
add address=10.0.80.0/24 dns-server=10.0.80.1 gateway=10.0.80.1 netmask=24
add action=dst-nat chain=dstnat comment=SSH dst-port=2222 in-interface-list=WAN protocol=tcp to-addresses=10.0.80.80 to-ports=22
flnslrbit
Re: Need help getting port forwarding to work
Sun Mar 26, 2023 6:49 pm
Still working on this, any insight would be great?
anav
Sun Mar 26, 2023 11:46 pm
What is this for??
Why do you have this set to your bridge??? Remove it.
/ip dhcp-client
The WAN is your WiFI not the bridge.................
Finally what is the purpose of your SSH connection??
flnslrbit
Mon Mar 27, 2023 12:53 am
This configuration was generated by using QuickSet
I have removed the defconf interface=bridgeLocal line but doesnt make any difference
Interface wlan1 is already in list=WAN
[admin@MikroTik] /interface/list> export
# mar/26/2023 14:52:52 by RouterOS 7.8
# serial number = XX
add name=WAN
add name=LAN
Users browsing this forum: No registered users and 52 guests
