wwbusch
after restart winbox does not find router (and webfrontend also does not work)
Sat Mar 25, 2023 8:19 pm
Hi Guys,
fighting with my first mikrotik router ATLGM LTE18.
i got the LTE connection running (works in german telekom network only with 7,8 FW, not before)
Now i tried to get the device reboot ready and after a reboot i can not access it via winbox or via webfrontend.
it replies to pings (i set ip to 192.168.178.254 which is in my network)
what am i missing?
If i do a full reset i can access the device via winbox. i set IP from 192.168.188.1 to 192.168.178.254 and reboot and can still access it after a reboot. i enable LTE and voila no access anymore???
Thanks for help
Wolf.
(dont want to send it back to the seller)
rextended
Re: after restart winbox does not find router (and webfrontend also does not work)
Mon Mar 27, 2023 12:07 pm
if you do not share something to read.......
wwbusch
Mon Mar 27, 2023 12:20 pm
i finally managed it today in the morning, somewhere in the firewall settings i needed to set "ethernet1" name to LAN in a dropdown list and enable Service for winbox and port 80 for my local adress range in LAN. The funny thing (i can reproduce it): if i reset the router to default config eveything is fine until i change LAN ip adress to my local net and reboot the router, than its not accessible anymore after a reboot.
Wolf
Users browsing this forum: diajad, Dude2048, mkx and 32 guests
