cdman
REST API PHP Class with examples
Mon Mar 27, 2023 3:06 am
Hi guys, as I am using mikrotik API from a long time, I wanted to check new REST API over HTTPS. So far it works great for me, and I am changing all my systems from regular API to REST API.
Since I did not found any ready to use PHP class solution, I checked HELP page here:
https://help.mikrotik.com/docs/display/ROS/REST+API
And created small PHP Class with several function to read, add, update, delete data. You can find it on github, with example script for usage
https://github.com/cdmanbg/php_routeros_rest_api
rextended
Re: REST API PHP Class with examples
Mon Mar 27, 2023 11:26 am
Thanks for the kindness
It is the sharing of knowledge that improves this world.
suvasishpaul
Wed Apr 12, 2023 2:21 pm
Your script is very dangerous from security purpose
because you disable SSL peer verification. Doing so might expose your requests to MITM attackers.
CURLOPT_SSL_VERIFYPEER => false,
Users browsing this forum: No registered users and 53 guests
