itgenolife
zerotier 1.10.3 for router os 7.9beta4 in 7.8
Tue Mar 28, 2023 2:53 am
Is possible use the plugin zerotier 1.10.3 for router os 7.9beta4 in 7.8?
psannz
Re: zerotier 1.10.3 for router os 7.9beta4 in 7.8
Tue Mar 28, 2023 9:18 am
My guess: no. If it is updated within 7.8, it would be with 7.8.1 or such.
Especially, since currently there seem to be breaking changes.
normis
Tue Mar 28, 2023 9:34 am
This question is so strange :D :D
If you need the changes in that version, just use that version. Why does the version number matter? It is just a number. You are afraid of "beta", because unstable? WELLL Zerotier 1.10.3 is also unstable just the same :D
zandhaas
Tue Mar 28, 2023 10:23 am
It's not such a dump question as you think.
I tried just that. Installing zerotier b9.4 but it's not possible. In the log I see: System 9.4b is required to install zerotier 9.4b
holvoetn
Re: zerotier 1.10.3 for router os 7.9beta4 in 7.8  [SOLVED]
Tue Mar 28, 2023 10:30 am
Pure logic.
The way Mikrotik has chosen to handle their packages, they are made for a specific version of ROS.
They go hand in hand.
Want to install the zerotier package with 1.10.3 version in it ? Then install ROS 7.9b4 as well.
Easy, no ?
normis
Tue Mar 28, 2023 12:11 pm
Zandhaas that is not what I was getting at.
I simply meant “if you are afraid of 7.9, you should also be afraid of packages it consists of”. Pure logic
Users browsing this forum: No registered users and 12 guests
