bablur
Traffic Balancing Issue in Bonding
Tue Mar 28, 2023 6:17 am
I am facing an issue with traffic balance in bonding member port, Bonding between Mikrotik to Huawei switch using 2 ports.
For load balancing I execute a command load-balance src-dst-mac in Huawei ether trunk but problem is not solved.
The service is running in Mikrotik for PPPoE.
I am requesting, Please provide the solution for load balance.
mkx
Re: Traffic Balancing Issue in Bonding
Tue Mar 28, 2023 3:24 pm
A single PPPoE session always uses same SRC and DST MAC address pair (reversed in opposite direction), hence Tx hash policy always selects the same physical link (bond member). The only way to see traffic move to another physical link is if the active one fails.
bablur
Wed Mar 29, 2023 5:58 pm
Please suggest me a smooth suggestion what should I take which will be improve to load balance on the both physical port, Currently one port getting 700Mbps other 200Mbps and both physical ports are in single bonding
bablur
Sat Apr 01, 2023 6:26 am
Dear Support,
Please suggest the next what should I do.
mkx
Sat Apr 01, 2023 1:32 pm
If you really want reply from official Miktotik support, open a ticket. https://mikrotik.com/support
This is a community forum and MT staff doesn't read all of it ...
Users browsing this forum: Bing [Bot], kivimart, lurker888, mrbroadband and 84 guests
