Matess
x86 ros mangle stops working randomly
Tue Mar 28, 2023 10:32 am
We have a problem with non working shaper based on mikrotik routers. It randomly stops shaping some part of its queues. We are not able to simulate that... it just happens every few days and reboot is the only thing which will fix it. We have 3 diffeternt shaper servers on different locations and they all have the same problem.
I am unable to generete supout.rif - it is stucked at 2% for 5 minutes now.
Does anyone has a similar problem with shaping?
elbob2002
Re: x86 ros mangle stops working randomly
Tue Mar 28, 2023 11:09 am
Are they all the same version? 6.49.7 is the latest v6 stable release. There's been a lot of fixes between your version and the latest.
Matess
Tue Mar 28, 2023 12:28 pm
we had there latest v6 version, but that had a problem when updating. It needed reboot after change in mangle / queues. This version is capable of 1 week of working .
XhabvhQonirtm
Wed Mar 29, 2023 9:41 am
It seems like you're facing a persistent issue with the shaper servers based on Mikrotik routers. The random stoppage of queues is causing inconvenience, and even after trying to simulate the problem, it persists. Additionally, generating supout.rif seems to be stuck at 2% for a long time. It's a concerning matter, and I suggest seeking help from Mikrotik support or consulting with experienced network engineers to resolve the problem
Users browsing this forum: No registered users and 62 guests
